» Another of C.T. engines cleaned ---- Cox Tee Dee .09 --- Just today (3/26/2024) more Cox partsby Yabby Today at 7:47 am
» Indexing COX cylinders
by balogh Today at 7:23 am
by Yabby Today at 6:33 am
by latole Today at 5:44 am
» 1/2a Skyray plans?
» Postage stamp backplates
» Parts Cox TD-4
Need help identifying a Cox Pt - 19 Variant
Re: Need help identifying a Cox Pt - 19 Variant
Ron,
I believe it is too. And since it's an open nose-painted pilot version, it may be somewhat earlier than I said. '65-'68 if memory serves.
I don't think that an odd color mix would necessarily be more valuable to a collector, it's just kind of an oddity I think.
There are some questions I have regarding the QZ Trainers, perhaps that should be its own thread?
Thanks again you guys.
John
John
john cole- Beginner Poster
Nice pics, its pretty easy once you've figured it out....I think its one of the many things that make this forum so fun.
Rats, I was looking for green? I wouldn't call it green, its definitely a different blue then the later models and does have a slight greenish tint to it, but its still more blue then green. This color was somewhat common during the mid-late sixties.
I don't know who put this together, but its probably the most complete breakdown of the PT-19, domestic version:
1st version (1960-1965)
Motor –Baby Bee with Thimble-Drome etched into the aluminum tank. Black rubber spinner, early round tip Thimble-Drome nylon prop.
Firewall – Tank mounted motor and opposite the color of the fuselage. Tab on the back to indicate the angle of the motor. Beginner-Advanced.
Fuselage – Open at the front to allow motor to tip out during crash. No reinforced areas and very thin and light. Note: The earliest version of Fuse in 1960-61 has far less panel line detail present. The initial lines are there but that is it.
Pilots - assembled from 2 pieces. Left and Right halves with mounting tabs on the shoulders. They were not painted and were injected in the color opposite the fuselage.
Windshields – separate units attached to the top of the fuselage with two tabs to locate. Plastic welded. Color: The yellow was a more Canary Yellow and the blue has a grayness.
2nd version (1966-1970)
Motor –Baby Bee with Thimble Drome etched into the aluminum tank for early portion of the run. Toward the end this etching was not on the tank.
Firewall – Tank mounted motor and opposite the color of the fuselage. Tab on the back to indicate the angle of the motor. Beginner-Advanced. Fuselage – Open at the front to allow motor to tip out during crash. No reinforced areas and very thin and light. Panel and rivet detail continued from the 62 and on version. Toward the end of the run for this model the area around the motor may be trimmed away more to alleviate warping from exhaust.
Pilots - assembled from 2 pieces. Left and Right halves with mounting tabs on the shoulders. Painted but with the color of the plastic that they were molded from left exposed as the color of the shirt they were wearing. One guy in a Blue shirt and the other in Yellow per plane.
Windshields – separate units attached to the top of the fuselage with two tabs to locate. Plastic welded. Color: The yellow changed and was a more standard and darker or School Bus yellow and the blue changed to a lighter Blue.
3rd version (1970-1973)
Motor –Baby Bee with integral tank as on earlier versions. Firewall – Tank mounted motor and opposite the color of the fuselage. Tab on the back to indicate the angle of the motor. Beginner-Advanced.
Fuselage – Same but with a cross bar added to join the left and right sides in front of the motor. Also the opening for the motor is smaller if looking at it from the top.
Pilots - assembled from 2 pieces. Left and Right halves with mounting tabs on the shoulders. Painted with the color of the plastic that they were molded from left exposed as the color of the shirt they were wearing. One guy in a Blue shirt and the other in Yellow per plane.
Windshields – separate units attached to the top of the fuselage with two tabs to locate. Plastic welded. Wing- Rubber band posts are reinforced somewhere during this run.
Color: Same as version 2
4th version (1974)
Motor –Initial version had Baby Bee but changed to a motor with a plastic back plate. Primarily In Red plastic.
Firewall – Tank mounted motor became unit with a plastic back plate and required a different and deeper firewall to make up the difference in length. Yellow in color. May be a blue. Not sure but all eventually became black.
Fuselage – Initial units had no integrated tank for Baby Bee but changed to integral tank. Initial filler and overflow nipples were the same size in front of the windshield and later changed to 1 nipple with a larger overflow and floating valve out of black plastic. Side lugs were added for to strap rubber bands under the wing from front to back. Tank: Molded in plastic matching the fuselage with an offset triangular shape to drain fuel on the right side and keep motor fed using centrifugal force. Pilots /Windshields – Assembled a complete and separate interior that included the windshields. Mounted from inside on two posts that were mushroomed with heat to keep this in place. Heads were larger and shirts on the pilots were orange. This was a more complete pilot with full torso. Instruments are a sticker on the dash. Elevator – 2nd position and slower adjustment for pushrod added. This may have been added during the end of the 3rd version.
Color: Blue became darker.
5th version (Early 80’s)
Motor – Motor with a plastic back plate.
Firewall – Deeper firewall continues to make up the difference in length from the Baby Bee. Black in color. Tank: Molded in clear/white plastic much like a film canister and now round in shape with an offset single nipple drain. No longer triangular in shape and motor can starve during nose up situations.
Fuselage – Completely different fuselage. Rivet detail and lines have changed although it looks traditional. Windshields are only a very vertical frame and Pilots shoulders are formed into the back of the cockpit. Big Dudley Do-right heads that are heat welded in place from below. The heads nearly always break off. Overall a thicker and more durable fuselage.
Color: Same Darker Blue and the yellow is School bus or Safety yellow.
6th version (Early 90’s)
Motor –Cox Sure Start. Firewall – Deeper firewall but this version is different to clear the snorkel on the Sure Start motor and the wire on the landing gear is formed differently. Tank: Round tank continues. Does not stay attached to the fuselage. Pops off easily. Fuselage – Again different with increasingly cruder detailing. Opening for the Bellcrank changed with rounded windows for strength. Pilots are molded in as well on this version but even a step cruder on the detail Wing- Much thinner and very flexible with a Tip weight. Rudder: Will not transfer to older PTs and does not locate the same. Color: A little darker blue and schoolbus yellow continues
4th version (1974)
John,
Thanks for taking the time to post those pictures. My initial question has been answered. That's why I really like this forum. I get to learn a lot more about the hobby. Andy
anm2- Gold Member
Mudhen- Gold Member
john cole wrote:Andy;
Hello, new member here, and I can help with your question.
A green version didn't officially exist, but what happens is that during production, the hoppers that hold the various colors of styrene beads get changed out and/or refilled. There's a transition period where injections are made to clear the old colors, and these parts are then minced and recycled (usually into control handles). Some yellow and blue were mixed at some point, because this green variation was the result. These parts were then passed along for assembly, either deliberately or by mistake. You can scrub away as much as you want to, but it's still gonna be green.
My greenish version is an early 70's model, and has color swirls in hte 'blue' parts, similar to what your stabilator has.
Hope this helps.
John
I think I got such a control handle
Lieven
OVERLORD- Diamond Member
batjac- Diamond Member
Mark, they are just 2 rubbery plastic plugs that fit in the holes to prevent from moving the cable that goes through the holes. First choose the holes you will use for the line space, then feed your line through and immobilize the line with he plugs.
Lieven
Lieven
This model is currently on eBay, the photos clearly show the fade of green into blue. I don't think Cox would send it out the door like this. It also looks like where the body is not discolored was covered by the cardboard hold downs.
http://www.ebay.com/itm/RARE-COLOR-Cox-PT19-Flight-Trainer-049-Gas-Engine-Powered-Control-Line-Airplane-/191255741444?&_trksid=p2056016.l4276
crankbndr- Top Poster
I think Mark Boesen addressed that coloration once. Somewhere around here. Within the past year, I believe.
» I know there are a few here who can relate
» Not a cox (?) but need help identifying
» Canadian Variant P-51 Build
» My newest adventure...
» The latest BTC-4 variant (a.k.a. Mark’s Most Recent Folly)
