» Wen Mac .049 - Conditioning.by MauricioB Today at 9:54 am
by HalfaDave Today at 9:34 am
by rsv1cox Today at 8:27 am
» Enya .09 II Questions
by sosam117 Today at 8:24 am
by crankbndr Today at 8:03 am
» Testers Sprite engine swap
» Post edit??
Thermal Hopper questions
I found a TH on ebay for not to much money only to find that the tip of the needle valve is broken off and lodged in the spray bar. Anybody know where I can find both the bar and needle? I checked Cox International. I tried to tap out the broken end using a small punch to no luck, then tried to clip off the end of a pin and try that with the same result.
Also, does the housing for the reed just pop off? It looks like it is staked on and I don't want to damage it further, it doesn't look to heathly as is.
Also, I bought one of CI's mounts for it, however 2/56 machine screws don't seem to fit?
It seems like I saw Kim flying an airplane with this set-up.......An oldie but a goodie.
Re: Thermal Hopper questions
Are you going to run it or restore it for display? If it's a runner you can use Tee Dee fine thread assembly from Texas timers:
http://www.texastimers.com
For that matter you can use a stock tee dee assembly. PM me your address and I'll send you one for free.
JPvelo- Diamond Member
JPvelo wrote:Are you going to run it or restore it for display? If it's a runner you can use Tee Dee fine thread assembly from Texas timers:
PM sent
» Used Thermal Hopper $165 and up
» Space Hopper .049/Thermal Hopper .049
» thermal hopper
» Thermal Hopper Question.
» Thermal Hopper
» thermal hopper
» Thermal Hopper
