» Indexing COX cylindersby davidll1984 Today at 7:56 am
by Yabby Today at 7:47 am
by Yabby Today at 6:33 am
by latole Today at 5:44 am
» 1/2a Skyray plans?
» Postage stamp backplates
» Parts Cox TD-4
early wen mac questions
chevyiron420- Gold Member
Re: early wen mac questions
The early Wen-Macs used a "fiber" gasket between the cylinder and the aluminum head, it's hard to measure exact, but about .030 is pretty close and the fiber gasket on the bottom of cylinder, between case is about .015.
I don't know who sells gaskets, but you can make them out of gray automotive carburetor gasket material. Usually a hot plug works best, for fuel use a high percentage oil (22-28%) preferably all caster, if not and your turning some high revs with small props expect these babies to wear fast!
good luck
good luck
p.s.
i think we've posted in a different forum in years past, 049 collectors?
Welcome to the best li'l engine forum on the 'net!
Phil.
Bill Schmidt (Wen Mac Bill) sells gaskets to suit. bschmidt08@hotmail.com
He also has a lot of information about getting them running well. If you PM me your email address (private message- where it says "PM" under my picture on the left) I will forward some documents to you which Bill sent me.
Mark I think you are right!Mark Boesen wrote:p.s.
» Norvel for speed?
» Early TD .010
» Early Greetings
» OS FS 90 - One of Max's early four strokes
» Early Bird Gets the .020 !!
» Early TD .010
» Early Greetings
