» Anderson Baby Spitfire - looking for the aft tank and gasketby Boats13 Today at 8:18 pm
by akjgardner Today at 7:53 pm
by roddie Today at 7:00 pm
by sosam117 Today at 5:55 pm
by roddie Today at 1:08 pm
by latole Today at 9:36 am
» Indexing COX cylinders
by Yabby Today at 6:33 am
» 1/2a Skyray plans?
» Postage stamp backplates
Texaco and Exhaust Throttle Sleeve
Can you use a throttle sleeve on a Cox Texaco? I am using the Texaco on an Ace Whizard and was wondering about adding throttle. Do I really even need it?
Sorry, one other question- If you use a throttle sleeve and fly at mixed throttle, does an exhaust throttle save fuel and give you a longer flight time?
Thanks in advance,
Scott
Thanks in advance,
Scott
rainyday101- Bronze Member
Re: Texaco and Exhaust Throttle Sleeve
Welcome to CEF Scott. The throttle sleeve works on almost all COX cylinders maybe except the old thin wall ones, and as such will fit the Texaco too,
You may need it if you fly RC and want to idle between 2 stunts or while diving, I think this will allow an idle low enough for taxiing on the ground.
Because the exhaust throttle reduces rpm by throttling the engine exhaust rather than throttling the carb thus msking the fuel rich, it will save you fuel-and cut performance too,
Thank you for the reply. I wasn't sure with the Texaco because of the lower RPM. I will be ordering 2 throttle sleeves so we you have 3 channel control. When I was a kid we always flew 2 channel with Black Widows and no throttle, now I can't imagine not having a throttle!
» Help identifying Throttle Sleeve
» WTB or WTT: Cox 020 with throttle sleeve
» A TeeDee .051 cylinder that a .049/.051 throttle sleeve won`t fit
» Throttle Sleeve, ACE OR COX Setup??
» WTB: 020 PeeWee Throttle Sleeve
