by roddie Today at 1:39 pm
by roddie Today at 1:08 pm
by latole Today at 9:36 am
» Indexing COX cylinders
by Yabby Today at 7:47 am
by Yabby Today at 6:33 am
» 1/2a Skyray plans?
» Postage stamp backplates
» Parts Cox TD-4
Cleaned up and ready for prime time
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Cleaned up and ready for prime time
If the intake timing is symmetrical around 45° before TDC then the same mod will work on any engine with a removable front (such a the HB for instance). I have only measured the timing on the Enya .09 IV myself, and it is indeed perfectly symmetrical around that 45° point. So by rotating it 90° (in the running direction) it will be centered around 45° after TDC, and hence an identical timing to before the mod if the engine now spins the other way around.
I don't think that all the larger engines are that symmetrical, but probably they are close enough to give about the same performance in either set-up.
I'm going to try it Kris on a few on my Enyas from a .09 on up just to satisfy my curiosity. I have a few McCoy's too with four bolt front ends, but I'm not sure if the top and bottom holes are equidistant.
Bob,
Glad to see you ran that .29 I wouldn't worry about that trash you sucked in. Unless it was full of sand or metal shavings it just got burned up and spit out. Enyas are tough. I have a later model .29 5224? That was in similar shape mounted in a Bi-Slob. I fueled that crusty tank up and ran all the crap through the engine. It ran very well!
I need to keep my eye out for a couple of those, you may have some competition on E-bay just kidding, I always ask before I bid if I know someone else is looking.
Cribbs74 wrote:Bob,
Glad to see you ran that .29 I wouldn't worry about that trash you sucked in. Unless it was full of sand or metal shavings it just got burned up and spit out. Enyas are tough. I fueled that crusty tank up and ran all the crap through the engine. It ran very well!
I have an Enya .15 mounted to an old Spitfire that has been through several shifts & hadn't run for 35 years. Never cleaned or oiled when it was put away. It had lived in the roof, hung on the shed wall, sat in my Mum's garage, in the top of the wardrobe.
I decided a couple of years ago to check it over. It was locked solid and encrusted in old dried castor and years of dust & grime. I soaked it in WD spray and gently worked the prop until it started to move. Finally got it turning over free, squirted some fuel in the tank, primed the engine and away she went, not a problem. Is spat & smoked and dripped dark brown goo for a while but eventually cleared its throat & took off running fine.
The best way to clean an engine is with heat & fuel, by running it
Yes, running it is the best way to clean them up, a little patina on the outside just shows that they have lived.
There is one thing that one should be careful with though, the wrist-pin can get stuck on the conrod and then it will wear out the holes in the piston...
So it is sometimes advisable to remove the backplate and check that the conrod moves freely on the wrist pin.
rsv1cox wrote:And Lieven I don't know how I missed your referanced post but I did. I guess you have no complaints regarding the test stand?
I plan on the same, mount it on a board and bolt it to the work mate. I will be devising a whole new mount for a larger open top fuel tank and integrated throttle control.
Bob, what mounting is concerned, I bolted a piece of wood under the plywood. Then it can be clamped between both table tops of the Workmate.
OVERLORD- Diamond Member
Oldenginerod wrote:pkrankow wrote:Are those the engines that rotating the nose provides reverse rotation of the engine?
I think that all the Enyas with the 4 bolt front housing can be rotated 90 degrees for reverse rotation. Having said that, I have never heard of another brand doing the same, even with the similar front housing. I would imagine the timing may end up a little different.
Enya actually sell (sold) matched pairs of counter-rotating engines for use in twins.
Another manufacturer who used to turn the front housing was K&B. The K&B 3,5 marine has the venturi on the left side. The engine must have a crankshaft designed for it because this engine turns the "normal" way. The front housing was turned to clear for the muffler.
That's funny, I guess they could take a lefthand crank and convert that to regular running with the front end, and it would end up like that...
Surfer_kris wrote:Yes, running it is the best way to clean them up, a little patina on the outside just shows that they have lived.
Good advise Kris. I have seen this first hand with pistons ruined by caged wrist pins. Thankfully Bobby Brooks usually comes up with replacements either new or used.
And Lieven, that's a great idea, no need to drill holes on the work mates table top.
And Rod, my old Enya .29 on my Fledgling was the same way after about the same amount of time. I just removed it and used a little heat and Remoil to free it up. It's never been apart, but I had always cleaned it after flying it. I did remove the fuel tank and cleaned the gunk out of it.
Cribbs74 wrote:Bob,
I probably worry too much about whats left in the fuel tank especially after a few years of no use. But I think of all the engines that I have ran without cleaning with no adverse results.
I must admit, I search Enya's every day, the .29 being my favorite. Unless it's the "Special" I will let you know if I find one.
OVERLORD wrote:rsv1cox wrote:And Lieven I don't know how I missed your referanced post but I did. I guess you have no complaints regarding the test stand?
Clever packaging, ends folded down affixed to the crimped base. Fit in an envelope.
Looks to be solid and simple once firmly bolted down. I liked Lievens idea of a bottom rail for attachment to a work-Mate type bench. I will improve my one line fuel system and check it out.
I think that Mark B. recently posted a picture of a MECOA stand that looked to be really good also.
Found it.
http://www.mecoa.com/tatone/teststands/teststands.htm
Page 2 of 2 • 1, 2
» needle setting OS15FP max rc
» Enya .15-II TV Old Stock --- cleaned
» Flew yesterday, first time in a LONG time....
» Cleaned two Enya Glows as well
» WEN MAC WITH TEE DEE UPGRADE
Page 2 of 2
