The 90 degrees out of phase Enya .29 Cox_ba12
The 90 degrees out of phase Enya .29 Pixel
» New Space Bug From Parts
by getback Today at 8:24 am
» Me or the tree
by rsv1cox Today at 7:05 am
» Who want´s it ?.
by fredvon4 Today at 6:33 am
by Admin Yesterday at 7:16 pm
» 200,000 Posts!
by Admin Yesterday at 7:13 pm
» BJMR Twin Lizzie
by fredvon4 Yesterday at 6:50 pm
» Cox chrome chassis
by fredvon4 Yesterday at 6:41 pm
» Wen Mac P-38 on Ebay: So, it didn't get to $1000, But Close
by rsv1cox Yesterday at 5:14 pm
» Wen Mac Lotus - dusty but not ran
by rsv1cox Yesterday at 10:13 am
by fredvon4 Mon Nov 29, 2021 6:23 pm
by duaneh Mon Nov 29, 2021 1:28 pm
» Uncle Wayne
by ChaseBanner Mon Nov 29, 2021 9:35 am
November-2021
MauricioB's
".049 Babe Bee "in action""
Forum Store
CEF Ear Savers
The 90 degrees out of phase Enya .29 Empty
The 90 degrees out of phase Enya .29 Empty The 90 degrees out of phase Enya .29
Post  rsv1cox Wed Jan 04, 2017 9:24 am
I have to try it, but I'm unsure about the prop. Why can't I just reverse it and achieve the same results with pulling power while running backwards? I know that Cox sells left hand propellers but I never see them outside of 1/2A.
The 90 degrees out of phase Enya .29 Oop_en11
The 90 degrees out of phase Enya .29 Oop_en13
The 90 degrees out of phase Enya .29 Oop_en12
Look Ma, no head gasket, no case gasket either or a venturi insert.
The 90 degrees out of phase Enya .29 Oop_en10
I couldn't make up my mind as to the orientation of the NVA. I decided the needle toward the bottom rather than adjusting it between the rotating prop and the cylinder. Would work better in C/L on vertical beams that way too. There has been discussion here relating to the position of the hole in the spray bar. Some say straight down may not be the best option. It's a crap shoot anyway as you can't see in there. Sometimes I put a magic marker dot 180 out, but in later engines Enya actually stamped a dot there, a big help.
The 90 degrees out of phase Enya .29 Oop_en14
2019 Supporter
2020 Supporter
The 90 degrees out of phase Enya .29 Empty Re: The 90 degrees out of phase Enya .29
Post  balogh Wed Jan 04, 2017 12:14 pm
Bob,
I am a bit perplexed at the 90 degrees off-set of the Venturi, but need to think it over a bit deeper. The porting on the crankshaft of rotary valve engines may have been originally set so as to have the Venturi and cylinder axis in parallel. If you rotate the venturi by 90 degrees the venturi porting will not be open when the piston moves upwards and designed to suck in the fuel-air mixture, so I am afraid the engine will not work in this 90 degree off-set assembly.
2019 Supporter
2020 Supporter
Post  rsv1cox Wed Jan 04, 2017 12:21 pm
@balogh wrote:Bob,
This gives a little history. Bottom of page one and some on page two.
https://www.coxengineforum.com/t10471-cleaned-up-and-ready-for-prime-time
2019 Supporter
2020 Supporter
Post  fredvon4 Wed Jan 04, 2017 12:24 pm
Think about when the intake port first opens when rotating the crank counter clockwise and then after shifting the crankcase venturi opening by 90 Degrees where the Crankshaft port will now Open first, if rotated Clockwise...
2019 Supporter
2020 Supporter
Post  balogh Wed Jan 04, 2017 12:48 pm
Sorry I missed the "history" but it really looks to make sense with clockwise rotation..
2019 Supporter
2020 Supporter
Post  pkrankow Wed Jan 04, 2017 1:10 pm
This is a test stand run right?
The prop, reversed, with reverse rotation, will present the proper edge leading into the rotation. The airflow will be away from the engine. This may cause cooling concern as there will not be a strong air blast, instead a less strong air draw, over the cooling fins. It likely will be fine with no issue on the test stand. I would be surprised if the airflow is inadequate for cooling.
Post  rsv1cox Wed Jan 04, 2017 2:09 pm
@pkrankow wrote:This is a test stand run right?
Yes, test run only just to prove the concept to myself. I don't want to harm the engine. As soon as the test is over the front end gets rotated back to the proper position. I love these little pot bellied external intake Enyas.
I'm going to wait until I receive the new test stand too. Test both at the same time. Smile
2019 Supporter
2020 Supporter
Post  Oldenginerod Wed Jan 04, 2017 3:05 pm
Does it use a head gasket?  I think most of my Enyas that I've stripped down don't use a gasket.  The head just laps to the liner.
Post  rsv1cox Wed Jan 04, 2017 3:10 pm
You have to look real close Rod, but on most later models they are there. I have actually had a couple come loose. I have a picture somewhere.
2019 Supporter
2020 Supporter
Post  rsv1cox Wed Jan 04, 2017 3:17 pm
@fredvon4 wrote:Think about when the intake port first opens when rotating the crank counter clockwise and then after shifting the crankcase venturi opening by 90 Degrees where the Crankshaft port will now Open first, if rotated Clockwise...
Bob Allan talks about the size of that port Fred, it's comparatively huge.  He thinks that it is one of the things that makes the .29 so special.  It's cut rectangular not oval like most.
The 90 degrees out of phase Enya .29 Oop_en15
BTW, I would love to have a wood burning cast iron stove made in that design for the shed.  Firebox the front end opening etc. Smile
I gotta get out of the house......... Sorta nice today, snow the next couple then the bottom falls out over the weekend temperature wise.
2019 Supporter
2020 Supporter
Post  Cribbs74 Wed Jan 04, 2017 8:53 pm
Bob,
While it appears that having the needle on the bottom would make it safer, the reality is it will cause you to access it from an awkward angle. I have had needles that pointed down and it was uncomfortable at best to adjust. Just a suggestion.
2019 Supporter
2020 Supporter
