» My plane for the Travelling Engine III
by Jason_WI Today at 5:40 pm
» Torches and Pitchforks Hero.......
by batjac Today at 5:10 pm
» Bag of parts Thimble Drome
by Oldenginerod Today at 2:50 pm
» Mini Devil Ressurection
by getback Today at 2:44 pm
» Pee wee 020
by getback Today at 2:39 pm
» Old Babe Bee acquisition -need some help
by getback Today at 2:18 pm
by rsv1cox Today at 12:54 pm
» Need help finding
by mandiares Today at 11:00 am
» Custom 1963 Cox PT-19 and HELLO!
by ikuraprime Today at 8:57 am
» Arden .099 and .19
by Ken Cook Today at 8:52 am
February-2018
coxaddict's
"Another Twin Born 2-2-2018 weight 4 oz."
Speed Contest 2018
The Traveling Prop
World of Aviation
Hydro-bat by Vic Smeed
Re: Hydro-bat by Vic Smeed
Post  getback on Mon May 22, 2017 8:49 am
Good Fun !! Way to go with ingenuity of the putty Knife ! Watching with interest Popcorn
View user profile
Post  fit90 on Mon May 22, 2017 12:15 pm
[quote="roddie"]
OVERLORD wrote:Thanks guys. Only the batteries have any weight. The small servo is very light and the 2.4 gHz receiver even lighter. Vic Smeed's model had a weight of 8 to 9 Oz. That's 230 to 250g. At this stage, it weights 81g.
For sealing, the article says to dope and cover in tissue the hull, then paint. I was thinking of doping the Inside and outside, then to coat with PU varnish all with sanding in between. I like to finish the model with Oracover.
You may remember I bought a Hobbico 200mAh 6.6V 1C LiFe receiver battery a few years ago. Its weight is 15gr. It may require a regulator to drop the voltage to a safer 6V though. It's a TINY battery-pack...
See the below photo for a size-reference on the battery..
Hi Roddie,
I have been using the LiFe batteries for about two years now. I haven't had any problems. The LHS owner says that they drop to about 6V under load. I haven't tested them under a load so I can't verify that. At least I haven't had any jittery servos. I have experienced that before when the voltage was too high.
fit90
View user profile
Post  Forgetful John on Mon May 22, 2017 12:48 pm
Greetings,
A diode, 1N4001 comes to mind, will drop 0.6 Volts in the forward direction and handle about 1 Amp in current. Put it in series with the (+) wire in a location where it goes to the receiver. If you put it at the battery though, it will block the charging.
FJ
Forgetful John
Bronze Member
Bronze Member
View user profile
Post  roddie on Mon May 22, 2017 8:55 pm
Thanks both; Bob and Forgetful John for the info. It would seem safer to use a diode. So.. a short extension-harness for the diode would be in order and would stay connected to the receiver.. and the battery charged independently. I hope I've got that correct..
Post  Forgetful John on Tue May 23, 2017 7:33 am
10-4, Roddie, that is correct. If you connect the diode backwards, it simply will not work, no damage, just reverse it.
FJ
Forgetful John
Bronze Member
Bronze Member
View user profile
Post  GallopingGhostler on Tue May 23, 2017 10:34 am
If one has one of those aircraft switch harnesses with charge cord, could simply splice a diode or two into the power line to the receiver. Then when in "off" position for charging, the diodes are bypassed. Those 1N4001 are cheap. Been a while since I last checked, but AFAIK 1N4002, 1N4003, 1N4004, etc. could be substituted.
http://www.vishay.com/docs/88503/1n4001.pdf
Difference is their breakdown voltages, 1N4001 = 50 V, 1N4004 = 400 V. Tired w/ Coffee Read Smile
Account Deactivated by Owner
View user profile
Post  roddie on Tue May 23, 2017 1:34 pm
Thank you again.. and thanks Lieven for a bit of a side-track here. I have always had a huge interest in the most compact/lightest-weight RC gear. A nano-servo should work fine with that small rudder. My ElectriFly (Great Planes) ES50 nano-servos are rated at 16.7oz-in (1.2kg-cm) at 4.8V with an operating voltage of 4.8-6v. Weight is 9gr. If you browse RC "Park flyers".. you'll find feather-weight gear if you need any.
Post  OVERLORD on Wed Jun 07, 2017 4:26 am
The past weeks I tried to figure out how te make a light and good working rudder linkage. Originally, the rudder stock is extended above the rear deck and the linkage is above the deck with an idler to connect to the servo in the RC compartment. I think this was to preserve the watertight compartments on both sides of the pylon.
I don’t like this exposed linkage and shortened the rudder stock. The horn will be mounted at 45° otherwise it hits the transom.  The fact that the rudder is at an angle gives a funny circular movement of the rudder horn: left to right but also up and down. I first tried to mount an aluminium bent horn and a 0,8mm piano wire but the piano wire is to stiff. This makes it to move too much sideways. That way the push rod could not slide into a fixed tube.
I then wanted to make a quadrant, operated by 2 wires connected to the servo. But this is complex, a bit obsolete and heavy. I found out that the cable which is lead out wire, is strong enough on its own to push/pull the rudder horn. I came up with this:
The rudder horn is made of 1 end of a tie wrap and the cable runs in a thin brass tube trough the watertight compartment. This should work with the servo in place.
View user profile
Post  roddie on Thu Jun 08, 2017 4:03 pm
Lieven, I believe that your angled rudder-pivot will cause the transom to lift on the turning-side. That's not good! Because the pivot is angled; the rudder is not only deflecting water from side to side.. but also "down" when turning. Is it too late to make a wooden-wedge stand-off for the transom, to mount the rudder-tube against? That would solve some issues.. One; it would allow for making the pivot-angle perpendicular.. eliminating the "lifting" forces.. as well as simplifying the linkage-geometry. It would also allow more space for mounting the horn parallel with the transom. I fear that the exposed part of your flex-cable could flex during pushing (turning port) directional-input. If you only run the boat in a clockwise (right-turning) circuit.. it would be less critical. Have you considered installing a rubber-boot pushrod-seal? It allows angular-movement of the pushrod.. while keeping water out of the hull.
I pack the inside of the pushrod-seal in my boat, with petroleum-jelly. It doesn't leak.
Note the distance between the rudder's pivot-post and the boat's transom. You could replicate this with a stand-off wedge-mount that's closer to vertical. I love the inward transom-angle styling on your model.. but it just doesn't afford itself to the function of a conventional rudder-mount unless modified.
Post  OVERLORD on Sat Sep 02, 2017 2:27 pm
After a summer break, I continued building the Hydro-bat. I sheeted the central top starting from the transom. Before finishing, I glued an aluminium front bumper that is about 2mm more forward than the hull. The aluminium plate was covered with scrap balsa and sanded flush.
After sanding, I cut out a templet to mark where to cut out the hatch for the radio compartment. The hatch will not be flat but curved and therefore, the canopy that is fixed onto the hatch has to keep this panel in shape. I decided to not make the Vic Smeed canopy but to use a plastic hemispherical one. After marking, I cut out the top to fit.
After trial fitting, I removed the canopy again to fit the dashboard. I copied the dashboard out of a 70's Jaeger car dashboard catalog. There are pictures of it on the internet and there is a large choice.
Made to the wanted size, I cut out the pic of the dash and glued it on thin balsa. The dashboard top was cut out of a black sheet of drawing paper.
roddie wrote:Lieven, I believe that your angled rudder-pivot will cause the transom to lift on the turning-side. That's not good! Because the pivot is angled; the rudder is not only deflecting water from side to side.. but also "down" when turning. Is it too late to make a wooden-wedge stand-off for the transom, to mount the rudder-tube against? That would solve some issues.. One; it would allow for making the pivot-angle perpendicular.. eliminating the "lifting" forces.. as well as simplifying the linkage-geometry. It would also allow more space for mounting the horn parallel with the transom. I fear that the exposed part of your flex-cable could flex during pushing (turning port) directional-input. If you only run the boat in a clockwise (right-turning) circuit.. it would be less critical. Have you considered installing a rubber-boot pushrod-seal? It allows angular-movement of the pushrod.. while keeping water out of the hull.
Roddie, I read about the influence of a tilted rudder. But this is really in ideal conditions. This boat will jump up and down and I don't know what else. I think that when the water is pushed down by the rudder blade, it willkeep the nose down. Initially, I thought of installing one of those Hong Kong aluminium rudders. I got 2 of them. They are well made and look good. But it's all about the joy of making things myself. Thanks for thinking of all that!!
The next things to do will be the canopy rear fin and cover both sides !
Lieven
View user profile
Post  Ken Cook on Sat Sep 02, 2017 3:34 pm
Lieven, welcome back and as usual your model is nicely done. You seem to enjoy the unusual, pretty cool. Ken
View user profile
Post  getback on Sun Sep 03, 2017 8:49 am
Good to hear from you Lieven , The bubble really gives it the spaceman effect / i like the dashboard you got for it too . Is the radio already in ? and how do ya access it ? Very Cool Build Glad to see you're back at it . Babe Bee .049
View user profile
Post  OVERLORD on Tue Sep 05, 2017 4:49 am
Thanks for your comments. The radio is not in there yet. After covering, I now have to cut out again a hatch to have access to the radio compartment. I like the bubble canopy too. It comes from those kids toys you get out of a distributor after you put in a coin. You could also use fishing floats from the make BULDO. I think the plastic will be a better quality.
http://www.buldo.com/index-en.html
To keep the curved shape of the hatch, I need to make a fin behind the canopy. At work, i get carried away and I make scetches of what I could make. I end up with antennas of different sizes. I will probably copy the shape of the pylon. That will be the most practical.
Today I fixed the engine and the boat weights 195g with the tank
View user profile
Post  pkrankow on Tue Sep 05, 2017 1:08 pm
The top one:
Do you read Schlock Mercenary?
http://www.schlockmercenary.com/
Although it could be Spaceman Spiff from Calvin and Hobbs...
View user profile
Post  roddie on Tue Sep 05, 2017 2:10 pm
Looking VERY COOL Lieven! The bubble-canopy is reminiscent of your last VTOL model. I LOVE that!
Post  OVERLORD on Thu Sep 07, 2017 12:57 pm
Glad you like it!! No Phil, I've never read those comics. It's the first time I see them. They do come from a creative mind. And Roddie, I know I repeat myself but it's just an easy thing to use.
What about this:
View user profile
Post  pkrankow on Thu Sep 07, 2017 5:06 pm
I like it.
I don't know how practical it is as that pin can snag, poke, or bend. You are not a young kid with clumsy tendencies so it might be fine.
View user profile
Post  OVERLORD on Sun Sep 10, 2017 9:47 am
I started covering the top sides. on the proto, those were covered with short pieces of 3mm balsa with the grain crosswise.
That is rather difficult to accomplish with immediate good results. None of these pieces are rectangles. And it needs careful sanding to get the curve back lengthwise. I made a pattern from paper for 1 side and cut this out in 1,5 mm balsa. That way, I save some weight and also, the sheet bends easier.
The sheet was cut to size at the transom and the edge was shaved and sanded at 90° to the bottom. sheet. There were some gaps of 0,5 mm or less due to inaccurate cutting of the sheet. I made tapered strips that I inserted with glue in these gaps. After drying and sanding that gave an all wood finish.
View user profile
Post  OVERLORD on Sun Sep 10, 2017 10:01 am
Near the pylon, I made some mistake in cutting the fore and aft member. The top sheet sagged and that bothered me since then. To remedy that, I glued another sheet on top and sanded it down. That gave the proper surface. On the pictures, the brighter wood is what's left over from the glued on sheet.
View user profile
Post  roddie on Sun Sep 10, 2017 10:03 am
Tedious work.. reminiscent of the cowling you made for your Caudron Speed model.. and countless other works of skill and patience that you've exhibited in your model-building. This one is no exception.. and looks to be almost ready for finishing. Popcorn
Post  roddie on Sun Sep 10, 2017 10:10 am
Can you devise a small fixture for sanding the 45-degree angles into the edges of the deck and the side-sheeting?
Post  fredvon4 on Sun Sep 10, 2017 12:45 pm
I like this project a lot and truly wish I was not so far from a good body of water
Back when overlord was doing the bubble canopy I though it would look painted as R2D2 but he did such a cool job of the instrument panel all that work would be hidden
I can not wait for miniaturized anti gravity units... I love all the Star Wars different transports, racers, and cycles in the different movies
Now where did I store that flask of Quarks and the one with 2 micro grams of Dark matter?
Trusted Seller
View user profile
Post  roddie on Sun Sep 10, 2017 9:19 pm
fredvon4 wrote:I like this project a lot and truly wish I was not so far from a good body of water
Phred.. you're awesome! Until the anti-gravity generators are perfected.. I'd suggest you look into acquiring a drone/quad-copter like the one that "Ian's" been playing with. They're literally plug n' play.. and CHEAP for a decent entry-level craft including a camera. They don't fulfill the "pride" involved with building a "one-of-a-kind" craft like Lieven is building.. but they certainly would assist in taking aerial photos/vids of one in action. Think of it as a "tool" that you can have some serious fun with.
Post  OVERLORD on Mon Sep 11, 2017 3:10 am
roddie wrote:Can you devise a small fixture for sanding the 45-degree angles into the edges of the deck and the side-sheeting?
I suppose you could. It'll have to be a bit universal and adjustable maybe? On this particular model, I don't know what the exact angle is and also, the angle varies from front to back. When the panel is glued onto both frames, front and transom, it is in fact twisted.
This is for Fred:
https://www.youtube.com/watch?v=pI2j4KEPQI4
View user profile
Post  OVERLORD on Wed Sep 13, 2017 5:40 am
The hull is finally finished.
View user profile
