» Cox 1911 Pusher questions
by Madguns Today at 3:14 pm
» Cox Curtiss 1911 pusher on eBay
by Madguns Today at 3:04 pm
» Hasbro gassers
by getback Today at 8:37 am
» Hasbro "the Great Gassers"
by roddie Today at 7:08 am
» Couldn't help myself.
by Oldenginerod Today at 7:01 am
» Modified SIG Twister
by Cribbs74 Yesterday at 10:14 pm
» Vintage Dune Buggy
by Bill steklenski Yesterday at 6:03 pm
» Cox Ski Doo
by Bill steklenski Yesterday at 5:52 pm
» I can't believe I finally own one!!!!!!!!!!!!!!!
by duke.johnson Yesterday at 4:15 pm
» What is this?
by Ken Cook Yesterday at 3:41 pm
September-2017
"Cox Conquest gets a Run-Up."
Tach Race 2017 Updates
Ready for Tach Race 2017?
Profile Scale Reed Speed
The Traveling Prop
World of Aviation
Tee Dee .09 Roddie getting ready to bench-run
Page 4 of 4 Previous  1, 2, 3, 4
Re: Tee Dee .09 Roddie getting ready to bench-run
Post  roddie on Fri Sep 08, 2017 6:56 pm
balogh wrote:Good point, Roddie, I use brake cleaning spray, connecting its sprayer with a silicon tube to the bottom spout of the venturi, and by sealing the intake side with my finger, pressure-flush the 3 orifices.
TD-s are easy to diagnose with orifice clogging problems if they run weakly and do not seem to want to react to needle valve adjustment. When I notice that - although rather seldom, because I  use, as a rule,  filter in the fuel line - I immediately remove and clean the venturi including the 3 orifices, and blow through the anodized spray-ring too to make sure its single orifice is also clog-free.
Brake-cleaner spray is one of the chemicals missing from my arsenal. There isn't much that I "don't have".. but that's one.. along with carburetor-cleaner. I haven't done a brake-job in decades.. but I should get some carb-cleaner spray. General Motors parts department used to sell the best penetrant that I've ever used. "Heat-Valve Penetrant" was what it was called.. and it was specifically formulated to lubricate the heat-riser valve associated with the automatic-chokes on GM's pre-fuel injection engines of the early 1980's. It contained colloidal-graphite.. and would penetrate where nothing else could.
Actually; the only aerosol spray-solvent that I have on hand is WD-40, an old can of TV-tuner cleaner and a very small container of a product called "De-Ox-it Gold".. which is/was a better cleaner/spray for rheostats associated with audio-systems.. more for "carbon-residue" than anything else. Now that everything is "electronic".. these special physical-lubricants/penetrants are getting harder to find.
Post  roddie on Fri Sep 08, 2017 7:14 pm
dckrsn wrote:That's a big one. Thumbs Up
Way ta go Roddie.
Thanks Bob. I'm learning as I go here. The plastic carb looks ok.. though I know that they can be prone to cracks causing air-leaks. I'm hoping for the best naturally. I'll again; flush the NVA while it's off the engine to be sure that it's clean. I've never removed the crank from a model engine. This engine will be the guinea-pig. If it's relatively "clean".. I'll just reinstall it. Some of my Bee engine's cases have sticky cranks that I know could use a de-varnishing. I just need to be more comfortable with the dis-assembly process.
Post  Ken Cook on Fri Sep 08, 2017 8:37 pm
Removing the drive washer is not a difficult task. As Ron mentioned, he taps on the prop screw. I don't use the prop screw because it can bend. I use a allen socket screw. Most of the time I place the crank in a vise between two wood blocks and press the screw out. Loosening the collet retainer is the easiest however the tool can do damage to the collet and or the threads of the case if not careful. Putting the drive washer back on is the problematic part. It can go on out of square. I use the same allen socket head and place a nut on it. Screw the allen socket head back into the crank and holding the socket with a allen key, back the nut back down onto the drive washer. This goes easier with a washer and or spacers under the nut due to the .09 having the centering extension on the front. Don't forget the thrust washer in between the case and the drive washer. If a older TD it's phenolic. I don't make a habit of removing this part unless absolutely necessary. The splines will cut again on install and this can be problematic if it's not tight.
View user profile
Post  KariFS on Sat Sep 09, 2017 1:50 am
Roddie, Ken's advice is spot on as always. I would like to add that be sure to turn the bolt all the way to the bottom of the prop bolt hole. Snug, but not tight. That will make the life of the threads easier as the tapping impacts are then transferred mostly via the end of the bolt to the bottom of the hole instead of to the threads.
Also when re-installing the drive plate, use the bolt and a nut as Ken suggests, again to preserve the threads on the crankshaft. Since the bolt is stationary in the hole, the process only causes static axial force to the threads. Hard to explain but anyway it is much easier to damage threads while turning than with an axial pull. So if you use a nut and bolt, the possible damage will occur to the nut and the area of the bolt where the nut is, instead of damaging the thread in the crank. Ouch my head hurts because of all the science lol! Also remember to lubricate the thread before tightening the nut.
Sorry if this is all "basic" to you, but maybe it is useful to some future readers anyway Smile
View user profile
Post  Surfer_kris on Sat Sep 09, 2017 6:31 am
Removal of the backplate is the "easy" part, just be careful with the last tap as there is a risk that the crankpin will hit the support as the crank comes out free. The tougher part is indeed to get it back on properly, with the prop-plate perpendicular to the axis of the crank. It doesn't take much error at the prop-plate to have a prop that is not tracking well. The prop-plate tends to deform at the back, deformed by the spline on the crank, and I usually deburr that before putting it back on.
I rarely find a real reason to remove it though. An engine that has been sitting for some time can feel a little tight (from old oil) but this will go away quite easily as soon as you run it again. So it only need to come off if one has to replace the thrust washer, or if there is another serious problem.
Surfer_kris
View user profile
Post  roddie on Sat Sep 09, 2017 9:08 am
Thanks once more.. guys! I appreciate this guidance/advice very much. I removed the crank last night.
I sat the rear of the case flat on my bench-vises' anvil, installed the slotted prop-screw fully.. and tapped gently using a small "tack-hammer" to avoid bending the screw. The crank came out of the case with no issue. I don't see much in way of "varnishing" on the crank. The crank "bore" looks very clean. This is as far as I've gotten.. as of this post.
When I reinstall the thrust-washer and drive-plate later; I assume that I should try to match-up the original grooves that the spline cut into the drive-plate if possible. I can feel the splines engaging with the two pieces apart from the engine. Common-sense tells me that re-fitting in this way would insure the drive-plate goes back-on to the crankshaft squarely.. and with less effort than if randomly located causing new grooves to be cut into the aluminum.
The thrust-washer is a phenolic one. Its' thickness measures .019" across the center.. but thins-out to .017" at the outer-edges. It has some significant wear.. and looks like the engine might have seen a good share of electric-starter use?
Here's a photo of the side (I assume..) facing the case/collar-ring..
and the side facing the drive-plate..
Should this part be replaced before re-assembly? If so; what would an alternate material be.. and its' approximate thickness?
Post  balogh on Sat Sep 09, 2017 9:24 am
Roddie
Matt sells stainless steel thrust washers for 09-s.
View user profile
Post  Surfer_kris on Sat Sep 09, 2017 10:05 am
If you are not going to use an electric starter, then the phenol washer one will be okey. Once running the prop will keep the crank in the forward position anyway. It is only on throttled engines that the crank will move back and forth at low carb settings. If you replace the washer, don't make it too tight, there should be some play, fore and aft, to allow for a proper lubrication of the crank.
And yes, do try to match the splines with the previously made grooves in the thrust-plate. Good luck!
Surfer_kris
View user profile
Post  Cribbs74 on Sat Sep 09, 2017 10:14 am
This exactly ^^^^
If it were me I would give it a light sanding of 1000grit and re-assemble. It's a runner. The crescent shaped cutout on the wrench will remove the carb body collar, but not really needed at this point as you can get to everything now.
Trusted Seller
View user profile
Post  balogh on Sat Sep 09, 2017 11:04 am
Roddie,
good luck, you are almost there. Looking forward to hearing the first brrrrrrrppppoooouuuuiiiiiiiiiiiiiiiiiiii...from your bench-run video!
Until then here is a vid I just shot today and youtube-d on my 09 in action with the Cosmic Wind minus its landing gear - as a precaution for  the deep grass on the only accessible field.  (The Sony headcam will not be better than that... Mad ). Sorry I did not want to poach your thread, just to give some more inspiration to a.s.a.p.  fire up your 09
K
View user profile
Post  Ken Cook on Sat Sep 09, 2017 11:14 am
Put it back together, there's nothing wrong with it.
View user profile
Post  roddie on Sat Sep 09, 2017 11:28 am
Surfer_kris wrote:If you are not going to use an electric starter, then the phenol washer one will be okey. Once running the prop will keep the crank in the forward position anyway. It is only on throttled engines that the crank will move back and forth at low carb settings. If you replace the washer, don't make it too tight, there should be some play, fore and aft, to allow for a proper lubrication of the crank.
Thanks Kris. I will likely be hand-propping this engine.. unless I can wind a coil of music-wire to make a starter-spring for it. I really LOVE the cam-spring that you made and recently posted!
I just looked at ExModel Engines Tee Dee .09 parts.. and it might make good sense to place an order for the SS thrust-washers, a pkg. of head-gaskets and needle/spring while they're still available. I'll have to see how and if this engine is a runner beforehand. If it runs good.. I might also consider the aluminum carb. This is an older engine and its plastic-carb is on borrowed-time. With shipping/sales tax from nearby CT.. I'd be looking at $30-35 for all of those parts.
A few years ago I scored some OEM Cox parts from a LHS that was closing after 70+ years in business (since 1939!). Amongst two small boxes of parts.. there were "two" Tee Dee .09 mufflers at 40% off the marked price of $5.. making them $3 ea. One package was open and missing a few small parts. CEF member Mark McRiley (batjack) wanted them both.. so I mailed them out to him. There was also some Aero-Gloss dope.. which I mailed-off to Ron Cribbs.
I wish I'd gotten the HS owner's personal phone#.. because he was certain that he had another box of Cox parts stowed-away in the backroom somewhere. I gave him "my" phone#.. but never heard back from him. The HS phone is no longer in service. I can only imagine what might have been in that last box which he couldn't find.
Post  roddie on Sat Sep 09, 2017 11:36 am
balogh wrote:Roddie,
Until then here is a vid I just shot today and youtube-d on my 09 in action with the Cosmic Wind minus its landing gear - as a precaution for  the deep grass on the only accessible field.  (The Sony headcam will not be better than that... Mad ). Sorry I did not want to poach your thread, just to give some more inspiration to a.s.a.p.  fire up your 09.
Nice flight Andras! Plenty of power there.. and the tuning seemed to sound a bit on the "rich-side"?? No worries with posting that here my friend!
Post  balogh on Sat Sep 09, 2017 11:39 am
I just looked at ExModel Engines Tee Dee .09 parts.. and it might make good sense to place an order for the SS thrust-washers, a pkg. of head-gaskets and needle/spring while they're still available. I'll have to see how and if this engine is a runner beforehand. ...............
Roddie you bet it WILL be a runner...you'd better stock parts still available from Matt, Bernie, ebay and elsewhere because the TD09 was one of the smallest production run COX engines, and it slowly goes extinct..unlike your obsession that will certainly grow the more you run it...
and yes, it was slightly on the rich side, I just want to avoid lean-runs when the tank nears to empty, as best as I can.
View user profile
Post  roddie on Sat Sep 09, 2017 11:44 am
Ken Cook wrote:          Put it back together, there's nothing wrong with it.
I still have to remove that Medallion head and install the Tee Dee one that Bob sent me. That'll be sometime this afternoon..
No one commented on what I mentioned about the "fluttering" of the ammeter needle on my panel while trying to start this engine previously... Huh... Anyone ever experience that? I thought it might be a sign of poor continuity.. or a coil/element that might be on it's way out...
Post  balogh on Sat Sep 09, 2017 11:59 am
Roddie the well-used COX clips - if you use one - are infamous of their tricky habit of popping off the head when you flip the prop...maybe yours did not hop off, just loses contact with the head...I could not think of anything else than that..I experienced that on bench starting even when the bench is held down on a table or something fixed...let alone in an airplane that you hold with one hand only while flipping the prop with the other. The COX clip best likes to hop off most often when the engine fires up and then the prop will hit the clip wire just to make the biggest damage possible...Murphy's law.
View user profile
Removal of the Medallion head
Post  roddie on Sat Sep 09, 2017 5:30 pm
First use of my Wagner heat-gun since I bought it a few years ago (on sale.. Smile ) I used the low (750 degrees F) setting and heated the cylinder and head for about one minute.
A gasket had been installed..
doesn't look too bad..
comparison; Medallion head "left"-Tee Dee head (from Bob)-"right". Notice the light-reflection showing the difference in the combustion-chamber shape..
I'm glad to finally get that old head off.. slow progress I know.. but it's better than rushing and breaking a part that can't be replaced.
