» Indexing COX cylindersby balogh Today at 1:10 am
» 1/2a Skyray plans?
» Postage stamp backplates
by sosam117 Yesterday at 6:58 pm
by Cox International Yesterday at 12:27 pm
» Parts Cox TD-4
by latole Yesterday at 7:43 am
Sure Start Throttle Question
I am talking about the sure start throttles on the choke tube that Bernie sells at Cox International. Question is, will on of these mount to a Killer Bee backplate?
rainyday101- Bronze Member
Re: Sure Start Throttle Question
Hi rainyday, yes it does:
The only thing you need is an O ring sunk into the groove of the choke tube where it attaches to the air intake on the backplate, to secure air-tight mating.
The screw tabs on the choke tube may bend a bit though because the KB air intake tube is a bit longer than on the Sure Start. But otherwise it works.
Thanks much! Just curious why you have the sure start choke tube throttle tied to the exhaust ring throttle?
It was a double throttling experiment when the intake and exhaust throttling were synchronised. It works quite well.
balogh wrote:It was a double throttling experiment when the intake and exhaust throttling were synchronised. It works quite well.
Interesting concept. Thanks again for your help!
» Sure-Start Throttle
» .049 sure start back plate with throttle
» Ace R/C Throttle question
» Throttle question
» Maples Throttle Question
» Throttle question
