Arden .099 and .19 Cox_ba12
Arden .099 and .19 Pixel
November-2021
MauricioB's
".049 Babe Bee "in action""
Forum Store
CEF Ear Savers
Arden .099 and .19 Empty
Arden .099 and .19
Arden .099 and .19 Empty Arden .099 and .19
Post  ticomareado Fri Feb 16, 2018 8:02 pm
I have accumulated a few Arden .099s in various conditions, some glow, some ignition and even a fixed compression diesel conversion.
In order to do a decent clean up/rebuild on these I need to disassemble them. They are fragile engines with magnesium crankcases and screw in back plates and I'm really at a loss on how to completely break them down without botching the things up or starting a magnesium fire with my micro torch.
Any advice from experienced restorers of these machines would be appreciated.
ticomareado
ticomareado
Account Under Review
Arden .099 and .19 Empty Re: Arden .099 and .19
Post  getback Sat Feb 17, 2018 8:26 am
Hey man , put down that mico torch and get the hair drier / monokote heat gun something of that sort .. i found this will give you some ideas .. http://www.machineconcepts.co.uk/engines/arden/arden.htm Babe Bee .049
2019 Supporter
2020 Supporter
Post  Ken Cook Sat Feb 17, 2018 8:52 am
As you've mentioned, the Arden is very fragile. In fact, so fragile I probably wouldn't run it unless it's been well used. The mounts break very easily. They were made with low quality magnesium and most who own them don't use them. I have seen a handful running but due to the metallurgy of these, they're usually shelf queens. The .19 is also loud . If there's no reason to take the engine apart, I would offer it a good soaking avoiding wrenching on it. My flying partner Dan Banjock used wd-40 to keep it looking like it's original patina. Most of the time however, the cases are very discolored. A heat gun would offer the best results if trying to free the engine up.
