» Draco Goes Flying, But Misses the Eclipseby HalfaDave Yesterday at 9:59 pm
by crankbndr Yesterday at 7:26 pm
» Enya .09 II Questions
» Testers Sprite engine swap
» Post edit??
Engine MP Jet .061
Engine MP Jet .061
I was watching this engine, and they indicated a couple of videos, including one of Rusty's, then I see two positions of the cylinder cover, in the same video the cylinder cover is initially placed correctly as it comes from the factory, and immediately afterwards the cylinder lid is seen in the same video in another position.
I do not understand exactly what happens and I turn here and Rusty if you can comment on that detail, because the video is very interesting.
Thank you!
Photo 1:
Cylinder cover in normal position: grooves parallel to the wind flow.
Photo 2:
Cross cylinder cover: cooling slots perpendicular to the wind flow.
Video:
Thank you!
Photo 1:
Photo 2:
Video:
MauricioB- Top Poster
Re: Engine MP Jet .061
I'm curious too Mauricio, that doesn't happen by accident.
Great running engine Rusty, leaned out pushing 21K.
The head part with the cooling fins is a clamp that holds an insert with the glow plug. As the clamp is held by for screws you have a total of four different possibilities of placing the head. Rusty then at one point forgot about the rotation and put the fins across the airflow...
I have one where I have enlarged the RC carb a little, it will spin the APC 5.7x3 at +21000 rpm on 10% nitro. It is great little engine...
It is evident that this engine was already presented in the forum through Rusty, here I found the thread and also his answer:
https://www.coxengineforum.com/t3259-breaking-in-the-mp-jet-061#54621
» **Black Lynx Engine Giveaway Jan-June 2020** Cox Engine of the Month
» *Cox Engine of The Month* Submit your pictures! -June 2014- *ENGINE GIVEAWAY*
» *Cox Engine of The Month* Submit your pictures! -June 2016- *ENGINE GIVEAWAY*
» **Black Lynx Engine Giveaway June 2018** Cox Engine of the Month
» **Black Lynx Engine Giveaway Jan-June 2021** Cox Engine of the Month
