Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Cox_ba12
by cstatman Today at 1:13 pm
by rsv1cox Today at 12:40 pm
by balogh Today at 12:16 pm
by balogh Today at 12:10 pm
by rsv1cox Today at 8:12 am
by rsv1cox Today at 7:59 am
Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Empty
Page 5 of 6 Previous  1, 2, 3, 4, 5, 6  Next
Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Empty Re: Aluminium fuel tanks for Cox Tee Dee .010 & .020
Post  balogh Sat Jun 23, 2018 6:32 pm
Mauricio for Android phones you can download the free RPM Gauge application from the Play store:
Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Screen10
Post  MauricioB Sat Jun 23, 2018 10:05 pm
Thank you very much András, download the application! I already have it on my cell phone!
Thanks again! cheers Thumbs Up
Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Dsc03510
Post  1/2A Nut Sun Jun 24, 2018 12:52 am
I have put together the TD .020 tank version. There was a issue with the small O
ring fitting inside the crank case. Perhaps after anodizing the tolerances are off
enough to cause pinching of the O ring and potential leaks. The O ring was oiled
and carefully assembled I tried to shove it in with a thin guitar pic it just would
not stay inside the crank case as I evenly tighten down the tank screws. Took
it apart and tried rolled the O ring added more oil no luck so just did my best
and tightened it down and did a leak test here are the results.
Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Imag7814
Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Imag7815
Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Imag7816
Filled the tank up wiped it all down let it sit for a few mins here are the results:
I will have to order another O ring kit for the TD .020 and try again.
Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Imag7818
I use 1/2oz tanks with my TD .020's pulling the fuel out shows how much it holds in represented bottle.
This is a good amount of fuel over the stock tank kudos!
Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Imag7817
The O ring fits flush to the base of the fuel tank face this is the problem is allows migration.
I recommend a sight design change as shown in this example the O ring has separation from
the front face of the back wall and can not migrate out when the screws are tightened.
This works very well from my use with TD .010's and .020's backplates no O ring leaks nor pinching of the rubber.
Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Imag7819
Here are my weight findings no fuel vs fueled.
Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Imag7820
I did buy a .020 carb body just to have in case I want to use a spring starter typically
I start this size and up with elect 1/2A starters.
And the two Silver Surfers together:
Aluminium fuel tanks for Cox Tee Dee .010 & .020 - Page 5 Imag7821
AmpAbuser
Published on Jun 24, 2018
TD .020 CNC Fuel Tank Test / 3.75 x 3 Prop
Peak to 20,994 rpm / 3.94oz thrust / .039w / 29w /60mph pitch speed
Small Cox Logo RC Plane Small Cox Logo
Post  balogh Sun Jun 24, 2018 1:02 am
If you run RPM Gauge on a split screen of your phone together with a video on a flight or a bench run , you can measure the engine rpm on-line.
Post  Cox International Mon Jun 25, 2018 11:00 am
1/2A Nut,
Sorry to hear of your troubles.
Our vendor said he tested the setup for leaks and could not see any. We don't have any 020 tanks left for us to check this but will pass along your suggestion in regards to recessing the seal.
Cox International
Cox International
Official Cox Dealer
http://www.coxengines.com
Post  Cox International Mon Jun 25, 2018 11:09 am
Forgot to mention that we are in the process of sourcing 0-rings (they are all metric lol) and we will get you a gasket kit when available.
Cox International
Cox International
Official Cox Dealer
Post  1/2A Nut Mon Jun 25, 2018 11:38 am
Thank you Bernie, yes slight recess off the wall of the tank will stop the O ring from migrating.
Also can you confirm the size allen head wrench for the rear plate screw on the fuel tank?
I used a .05 hex key, seemed to have a lil play in it, was a new fresh key / first time use.
Perhaps it is a metric screw?
Post  Cox International Mon Jun 25, 2018 11:46 am
Yep, everything Metric aside from the four 2-56 screws. The backplate screw is a M2-15 and takes a 1.3mm wrench.
Having a field day trying to source all the Metric parts and will mostly be from eBay / China.
Cox International
Cox International
Official Cox Dealer
Post  1/2A Nut Mon Jun 25, 2018 12:38 pm
Good to know, the 1.5M is more common / most folks have that in their key set.
I will source a 1.3M to insure I have torqued down the screw good and tight to
hold up to engine vibrations. Your vendor should consider setting up the fill / over
fill tubes like stunt tanks for rolls / inverted flight / hammer head stalls etc.
Post  Cox International Mon Jun 25, 2018 12:59 pm
Good suggestion and will pass it along.
Cox International
Cox International
Official Cox Dealer
Post  getback Tue Jun 26, 2018 10:38 am
Good test Brad , and to see where a problem is and to afix it before i pull the trigger on some these . 1.3 mm is off from what i have and for .20c more could bee added to the package being its odd here in the states. Huh... Two Cents
Post  1/2A Nut Tue Jun 26, 2018 3:14 pm
Thank you Eric! Thumbs Up
You can get the 1.3M allen wrench key on ebay for a couple of bucks, I have one in the mail on the way.
Same size is needed for the TD .010 tank too. I like these tanks for bench testing props all ready to go
in one piece. Will still use the nylon tanks for flying but may do up a sport design to suit one of the tanks for fun.
It's all about the fun and joy of the components, designing, building and flying that makes the hobby special.
Post  Cox International Tue Jun 26, 2018 3:19 pm
When we run production again we will switch to a slot-head for the backplate screw.
Cox International
Cox International
Official Cox Dealer
Post  Jason_WI Tue Jun 26, 2018 4:22 pm
I used a .050” allen wrench for the backplate screw. It is a bit loose but fit tight enough to tighten the screw.
Jason_WI
Jason_WI
Post  ffkiwi Wed Jul 11, 2018 6:02 am
Any indicative time for availability of the next batch?-I will take several of each size.
ChrisM
'ffkiwi'
ffkiwi
ffkiwi
Post  Cox International Wed Jul 18, 2018 2:28 pm
Sorry, just got back from a camping trip Smile
Probably in 2-3 weeks from now but will have to check how many are still available after pre-orders.
Cox International
Cox International
Official Cox Dealer
Post  Cox International Fri Jul 20, 2018 6:32 pm
We have received our next shipment of the carb bodies and tanks and have listed what is not presold here: www.coxengines.com Sorry, silver was all spoken for.
Cox International
Cox International
Official Cox Dealer
Post  1/2A Nut Fri Jul 20, 2018 7:53 pm
Hi Bernie, did he send any replacement TD .020 / O rings?
Post  Cox International Fri Jul 20, 2018 9:49 pm
1/2A Nut wrote:Hi Bernie, did he send any replacement TD .020 / O rings?
No but we have ordered them from a USA vendor and should have them in a couple of weeks.
Cox International
Cox International
Official Cox Dealer
Post  1/2A Nut Sat Jul 21, 2018 2:30 am
Great thank you Bernie!!
Thumbs Up
Post  Geist Flieger Mon Jul 23, 2018 11:01 am
Just ordered the both sets for the 010 & 020. Do I need a 1.3 mm allen key or has Bernie switched to a slotted screw for the back or the tank?
Geist Flieger
Geist Flieger
Post  Cox International Mon Jul 23, 2018 11:09 am
Thanks for the order and this batch still uses the 1.3mm hex key.
Cox International
Cox International
Official Cox Dealer
Post  Cox International Mon Jul 23, 2018 5:46 pm
We almost sold out over the weekend. Only these left in stock (all in red):
Two .010 Fuel tanks
One .020 Carb body
One .020 Fuel tank
Cox International
Cox International
Official Cox Dealer
Post  Cox International Tue Aug 07, 2018 3:11 pm
1/2A nut, can you please identify yourself to us so that we can send you the replacement O-rings? A screen name does not always correlate to a real name lol.
Cox International
Cox International
Official Cox Dealer
Post  1/2A Nut Tue Aug 07, 2018 7:24 pm
Yes thank you Bernie, email sent per your link with the full contact info.
