rc 1/16 049 powered bugy  - Page 2 Babe_b10
September-2020
"Traded an electric charger for this "Complete" (original) Cox Thimble Drome Olympic .15 engine. Right corner is photo as received."
rc 1/16 049 powered bugy  - Page 2 Empty
Page 2 of 2 Previous  1, 2
rc 1/16 049 powered bugy  - Page 2 Empty 4cox powered rc cars truck bugy racer f1
Post  davidll1984 on Thu Apr 09, 2020 10:54 am
rc 1/16 049 powered bugy  - Page 2 Image87
rc 1/16 049 powered bugy  - Page 2 Empty Re: rc 1/16 049 powered bugy
Post  davidll1984 on Thu Apr 09, 2020 10:58 am
custom built rc cars home made stuf fun to build Very Happy
Post  NEW222 on Thu Apr 09, 2020 12:16 pm
Nice little collection.
Post  davidll1984 on Thu Apr 09, 2020 7:43 pm
is just part of my 049 cox powered rc cars have jerobee tamiya cox kyosho original in box stored in room for them moistur control temp som of them is just display wit no box just deco art funtional wit actual rc gear mod y colect race cars from 70 to 90 wil use al of them in futur wit my son y want him continue my colection like y did y got stuf from my father an old men y use to fly wit died long time e go is my memory stuf y keap til y die hope my 1970 jerobee wil last 100 year wil stil work its special tee dee 049 mclaren body huger tire crome rims fuly upgrade is nice model y like it a lot is buried deap in box bubble wrap wit huge lods of hotweels wit some tresur hunt worth lot mony
rc 1/16 049 powered bugy  - Page 2 Empty no run for now snow
Post  davidll1984 on Fri Apr 10, 2020 11:59 am
rc 1/16 049 powered bugy  - Page 2 Image89
Post  davidll1984 on Wed Aug 12, 2020 10:58 am
new part from cox piston for tee dee engine kiler bee 2 for my cars project 1/18 2.0 .010 prop texaco piston and cylinder new red mufler wil post pic of my project is it normal kiler bee 2 use black back plate no screen in ventury tink its normal Very Happy very happy
Post  davidll1984 on Fri Aug 14, 2020 10:54 am
rc 1/16 049 powered bugy  - Page 2 15974210
Post  rsv1cox on Fri Aug 14, 2020 11:33 am
Wow, Nice David. All good stuff, thanks for sharing.
2019 Supporter
rc 1/16 049 powered bugy  - Page 2 Empty are you sayin the Cox Queen Bee carb??
Post  happydad on Sun Aug 16, 2020 12:39 am
davidll1984 wrote:rc 1/16 049 powered bugy  - Page 2 Image41
rc 1/16 049 powered bugy  - Page 2 Image42
davidII1984: Are you saying that the Cox Queen Bee carb fits the backplate, crankcase, of the standard .049 engine?
I thought the crankcase of the Queen Bee was larger? or is that engine a .074 Queen Bee?
happydad RC Plane Old Bugger Canada  Hand Shake  United States
happydad
happydad
I Support My Forum
2020 Supporter
Post  robot797 on Sun Aug 16, 2020 12:41 am
it does look like it
robot797
robot797
Post  davidll1984 on Tue Aug 18, 2020 8:41 pm
yes is part of Queen bee back plate and carb fit wit sort of home made pipe made of fuel primer it worked god just not lot of response to hi to low to fast to control drift dirt just stop if brake is used som time lost power to reciver imposible to catch not ful rpm sort of ritch run wil improove my desing wil try difren mod to rc engine low noise low rpm wit crazy top end rpm my cylinder is texaco wit open fin on ex port colector is from my ez bee pipe is team ae fuel primer very hard to find now it one old hard to find item fuel was feed by the oem modified.back plate not the carb is sort of valve in my first test tink of dual way of control rpm wit egr valve of gtp the carb used nex time wit egr valve difrent fuel tank tink fuel draw is in trouble dont want overheat engine
rc 1/16 049 powered bugy  - Page 2 Empty How?
Post  happydad on Tue Aug 25, 2020 10:12 am
davidll1984: how did you fit the .074 carb to the .049 backplate. I am assuming you mean the Queen Bee .074 R-C throttle?  The picture is very hard to see in that area. Dark.
I bought all the parts and want to try the same thing.
Happydad RC Plane  Jeep  Old Bugger          United States  Hand Shake Canada
happydad
happydad
I Support My Forum
2020 Supporter
Post  davidll1984 on Tue Aug 25, 2020 11:25 am
seal wit tube 4 new hole fore back plate use clear lexan for template engine is 049 moded hd crank texaco cylinder wit exaust fin open for the crank case braket is of team ae bugy it self it cool down the crank case litle
Post  davidll1984 on Wed Aug 26, 2020 9:37 pm
now its special cylinder is on my rj bee custum rc cars rc 1/16 049 powered bugy  - Page 2 Image209
rc 1/16 049 powered bugy  - Page 2 Empty What is special?
Post  happydad on Wed Aug 26, 2020 10:30 pm
davidll1984 wrote:now its special cylinder is on my rj bee custum rc cars rc 1/16 049 powered bugy  - Page 2 Image209
davidll1984:  what is different. Open exhaust port or special car glow head or ??
happydad
happydad
I Support My Forum
2020 Supporter
rc 1/16 049 powered bugy  - Page 2 Empty How do you mount the engine?
Post  happydad on Sat Aug 29, 2020 6:14 pm
davidll1984:  so I have sort of figured out how to make an adapter for the .074 carburetor to fit the back of the standard .049 engine, but I just realized: how do you mount the engine?: Do I see clamps on each side of the engine and do they have a heat sink. I am behind, but I am catching up. I just got a “new” car engine with a heavy duty crankshaft, not hardened, just the larger heavy duty Cox car crank.
Too many projects and too little time.
Happydad. RC Plane Jeep      Old Bugger                United States    Hand Shake Canada
happydad
happydad
I Support My Forum
2020 Supporter
Post  davidll1984 on Sat Aug 29, 2020 9:52 pm
is same type engine except my use clutch from 1/10 .18 engine way to heavy after lightened the part tink it can work it worked good as is rc 1/16 049 powered bugy  - Page 2 Image211
Post  davidll1984 on Sat Aug 29, 2020 10:01 pm
my only trouble is heat ring control wit try of exaust colector no good for its use crank is very tuff on 350-4 jerobee type engine flyweel is hevy litle to keep engine runing on low rpm is a good start for engine mod wit egr two bypass cylinder no spi or very litle wit ring point is low rpm wit tork hi comprestion head is neaded
Post  davidll1984 on Sat Aug 29, 2020 10:06 pm
cylinder is texaco wit exaust fin removed help flo in back presur from tuned pipe made of team ae fuel primer wit cars head now used on my tee dee for RJ bee tee dee powered
