Proper fuel oil mix Cox_ba12
by rdw777 Today at 2:33 pm
by rdw777 Today at 2:28 pm
by rdw777 Today at 2:21 pm
» Zoomslot Saucer
by andrew Today at 11:17 am
by 944_Jim Today at 9:27 am
Proper fuel oil mix Empty
Proper fuel oil mix
Proper fuel oil mix Empty Proper fuel oil mix
Post  OhBee Wed Mar 11, 2020 1:10 am
What fuel/oil mix could I, should I run in OS .15's AND Enya .35's? Only fuel I have is Cox 25 and 35% nitro. I know thats too much nitro for those engines. Don't want to buy umpteen different fuels for everything!
OhBee
OhBee
Proper fuel oil mix Empty Re: Proper fuel oil mix
Post  Oldenginerod Wed Mar 11, 2020 1:32 am
OhBee wrote:What fuel/oil mix could  I, should I run in OS .15's AND Enya .35's?  Only fuel I have is Cox 25 and 35% nitro. I know thats too much nitro for those engines. Don't want to buy umpteen different fuels for everything!
You'd probably want no more than 10% nitro for either of those engines. I think Enya actually recommend 5%. If you're talking older bushed or iron pistoned engines, then castor is in order, probably around 20%. Half castor half synth would be ok.
My experience is limited, so others may agree or disagree. Feel free.
Post  OhBee Wed Mar 11, 2020 1:57 am
Near what I was thinking based on my research,but felt safer asking the "experts" here! Wink yes bushed engines...but one newer OS is an aluminum piston in a plated bore.
OhBee
OhBee
Post  944_Jim Wed Mar 11, 2020 5:06 pm
I'll email you a link for taking two known fuel types and mixing.to get a resultant blend.
You only have add straight methanol and a bit of caster to bring your 25% down to 5% with required castor oil. Castor can be bought in 6 oz bottles at Walmart so you don't have to stock up on lots of chemicals.
It'll be in you inbox in a couple hours (after dinner).
Post  NEW222 Wed Mar 11, 2020 7:19 pm
I have run both aforementioned engines with success using Morgan's Omega 5% fuel. I also add 2 or so extra ounces of castor per gallon just because I want to add a bit of insurance.....
