» Draco Goes Flying, But Misses the Eclipseby HalfaDave Yesterday at 9:59 pm
by crankbndr Yesterday at 7:26 pm
» Enya .09 II Questions
» Testers Sprite engine swap
» Post edit??
piper l-4j wit cessna 150 wing miss monica tee dee .051
Page 2 of 2
Page 2 of 2 • 1, 2
Re: piper l-4j wit cessna 150 wing miss monica tee dee .051
Looking good David.
thanks bob my plane is on hold for now trouble wit my spectrum dx6i geting out of range almost crached my sukoi 26 m 3d plane rf lost signal at 100 feet from me it normal go to 1km no trouble so my controler is in trouble did try wit a othe plane same trouble thanks good my plane is safe can imagine new plane not trim yet is disaster for sur my new dx6e is at the drone chop wit my qav250 for setup wil try fix my controler send to spectrum wil take for ever no plane for me right now
davidll1984- Diamond Member
David you sure do have a lot going on.
I wish I had your youth and ability to juggle all those projects at once.
Litle hope for m'y litle miss monica went for flight wit the tigermoth no trouble wit his old hard To set dx6i m'y scroll buton wont work properly just change the part wit m'y new dx6i that haved range trouble tink wil continue the plane now
As always, I make a big mess on my work table Installing the Servo Brackets Extension wire new connector I still have work to do to relocate the servos inside the fuselage The gas tank is a little in the way Sometimes a thing At first glance simple may turn out to be more Complicated that we could first tink
Well it sure looks like a dense work table... ..I just recognized the 2 wing halves in which you replace the servos?
Thats nothing compared to mine at the time , i have been working off the bed till i can get myself talked into taking a break from the real world and cleaning it up !! I hope the radio don't give you problems in the air
Well I made some progress the engine is in place with the servo for its carburetor I have not tested on the plane but extremely efficient on the car on which I tried the modified engine the litle wasp .061 carb work so Good on tee dee .051 I believe that with the new silencer the performance should remain the same. I hope the gas tank is working well I find it far and a little low in the fuselage
Just the receiver to install and test after adjusting all the controls I will do an engine test
About ready i know your getting excited !!
I have to wait to receive a part for the voltage i have To use a bec To reduce the voltage of the system I have not test a 2 cell lipo direct To the Reciver Which can take from 3.5 to 8.5 volts Because the servos use an operating voltage of 3.0 to 5.0 volts the other 4.8 to 5v I am already afraid of over-boosting them
I want to use the stabilization system built into the nanolite receiver The as3x system consumes a lot of power Because as3x constantly corrects the plane so that the plane remains very stable. In the wind
The servos are used a lot and can easily overheat with too much current
Hooo Miss monica runs away NOOO
I haven't really worked on my plane for a while But after seeing this video Poor girl Well i mean plane
davidll1984 wrote:I haven't really worked on my plane for a while But after seeing this video Poor girl Well i mean plane
Heh heh it’s an L-4 and a 150, what a coincidence. Cool looking project you got here!
Lukemiester- Gold Member
Hihi lukemiester you followed well I was wondering if someone would notice this detail I wonder what we can call him he's a super cessna No it's a piper 150 I know it's weird it can be a super cub 150 No no no neither one nor the other It's been a while since I received the piece that threatens me to start the programming of controls Unfortunately I am missing an adapter cable to reprogram it correctly
With this piece I can adjust for 5 volts At least I can adjust the limit the controls trow just cant set as3x for now
“piper 150” got me voltage regulators are really smart to have if you have a receiver that needs lower voltage than 8.4. I assume that’s what you’re using...
I use a bec For the servo the ones I use for the aileron Needs less volt That the other servos with the as3x system the servos will already be very required .Too much voltage could damage them prematurely from over heat The nano receiver with as3x is able to take a small lipo two cells without problems In my tiger moth I use the same type of receiver but without as3x and its litle futaba servo can also take 8 volts I believe the small battery in m'y piper should give me at least an acceptable flight time With great stability the system works for us to correct much faster It's hard to explain, let's say it's like flying with a bigger model Who would not be affected by the wind As much as little one This gives me no power but allows me to avoid maneuvering certain channel like ruder for knife edge I choose the angle I want so I can focus on the other commands No, it's not an automatic pilot
i see what you mean. interesting voltage setup...
as3x is nice, i have it in a lot of my planes.
Surprise surprise the postman came by today I received a package with a surprise inside a measuring tape identify with the cox international logo I like the surprises thank you very much in this package I have pieces to personalize my little miss monica I can't wait to see the yellow or the white looks better on her one or the other she has both colors still undecided on the color scheme
Stil working i Will get a closer look at this later I can't wait to show you the final result and I'm going to have something different to show you soon it's a 4 stroke engine that's all I can tell you to keep the suspense a bit And that very unusual for me and in no way related to Cox engines or aircraft engine But I like the little things and engine the two put together and you have an eresistible temptation I cracked I needed one
Fledgling
Heard so many problems with spectrum stuff.
I got a cheapo futaba and radiolink, both 2.4 as my 27 and 35 MHz kit is old now.
Don't like the modern trim buttons, toooo slow when adjusting. The older kit is adjusted click by click quite quickly or instantly.
Coxfledgling- Gold Member
À tes the dx 6 e and its very difrent from m'y older dx6i that working Find its m'y trim buton that is broken but its al Good now an i have two dx6i the new one lost signal once and i was luky Not To crash the older one never lost its signal mabe the controler antena module is defective its a fragile parts mabe the signal range Not est correct The old controller I never changed anything in the programming but the other I changed the parameters in the more in-depth menus i was programing for a 3D heli and download one installation wit the USB port but tink it change the range or Somting deap in menue i like simple tings To i stil To this day use a old futaba wit cristal Not To often it was in m'y first .40 trainer that now has crack in the midle wing and it flex mabe m'y old ez bee can use this To keap the vintage feal wit the super long antena
Page 2 of 2 • 1, 2
» *Cox Engine of The Month* Submit your pictures! -July 2020-
» modified tee dee .051 for miss monica
» Cox .049 rc piper cub???
» On the Ramp Right Now!
» The Piper Cubs other half
Page 2 of 2
