» Cox Showcase Miniatures by rsv1cox Today at 12:03 am
by GallopingGhostler Yesterday at 11:52 pm
by GallopingGhostler Yesterday at 9:57 pm
by OVERLORD Yesterday at 4:46 pm
by getback Yesterday at 3:24 pm
by GallopingGhostler Yesterday at 1:50 am
by GallopingGhostler Yesterday at 12:14 am
» Beginners Ringmaster
by 944_Jim Wed Sep 20, 2023 11:04 pm
by rsv1cox Wed Sep 20, 2023 10:32 pm
» Just ordered a 3D printer
by akjgardner Wed Sep 20, 2023 8:22 pm
by getback Wed Sep 20, 2023 1:35 pm
» Fuel Proofing
by bsadonkill Wed Sep 20, 2023 12:31 pm
Percentage of Nitro used in a Norvel, R/C BB engine
Hi Gents
Although 99% of my questions and flights are Cox related I do have a few others I deal with too. Might someone know what is a good fuel mix percentage of Nitro that would be used in a Norvel, R/C BB engine?
If anyone knows would be greatly appreciated.
Thanks
Iceberg
Thanks
Iceberg
Iceberg- Gold Member
Re: Percentage of Nitro used in a Norvel, R/C BB engine
What size? 5-10% nitro works just fine . 40% nitro is my standard combat fuel and I use it in my Norvel 15's as well.
Hi Ken
It is a Norvel .15 with Ball bearings never been started.
Nitro % best you think?
Thanks
Darren
Thanks
Darren
About 10% nitro is fine, what is more important is the oil content and type. The cylinders are very rough when new, so for me it is all castor oil and 20-25% of it.
The stock engine throttles excellently (idles reliably at around 2200rpm) but the carb is a little restrictive on the high-end. So if you are after more power you can simply switch to a different carb, the MVVS .15 carb is a direct swap-in for instance. I wrote some of my findings on RCU quite some time ago, try a search there and you'll find lots of useful info.
Here is one of the threads on RCU, for instance: https://www.rcuniverse.com/forum/1-2-1-8-airplanes-70/9450797-norvel-15-big-mig-again-2.html
Here are my tach numbers from that time:
"Here are some numbers with the muffler on:
Stock carb, APC 8x4 prop, 10% nitro: 14400rpm
MVVS carb, APC 8x4 prop, 10% nitro: 15800rpm
With the MVVS carb the performance pretty hard to match by any other .15 engine, especially if you consider the low overall weight of the engine."
Do you have the spanner wrench for the head insert ? The design of this has changed somewhat over the years and the latest had a mill finish head clamp with peripheral holes around it. When new, due to heat cycling the clamp will loosen offering little to no compression. I actually put some Ultra Copper RTV around the threads and retightened and never looked back. This engine has a good deal of pinch when new and takes a bit of fussing with using a heat gun to pre heat the cylinder as it will lock up at top dead center.
Yes, as with all Norvel revlite technology cylinders, lots of castor and preheat is the way to go. Once run-in they are very reliable and easy starting.
» Norvel engine I.D.
» Sig Nitro Rascal/ Norvel Big Mig 074
» New stuff to do with your nitro engine
» Need Norvel engine help
» Researching a Norvel .061 Engine
