Fox 35 with ST NVA Cox_ba12
by rdw777 Today at 2:33 pm
by rdw777 Today at 2:28 pm
by rdw777 Today at 2:21 pm
» Zoomslot Saucer
by andrew Today at 11:17 am
by 944_Jim Today at 9:27 am
Fox 35 with ST NVA Empty
Fox 35 with ST NVA
Fox 35 with ST NVA Empty Fox 35 with ST NVA
Post  Jason_WI Wed Sep 09, 2020 3:04 pm
Is it recommended to cut down the wire portion of the Super Tigre needle valve to shorten it a bit when the Super Tigre needle valve is used on a Fox 35? Cut off at the bend then heat up and bend after the threads? I could also cut off straight, turn a knurled knob then braze to the needle.
Here is the needle valve assembly I bought off eBay.
https://www.ebay.com/itm/223916941736
What’s a good glow plug to use for the mid 50s Fox 35 CL version?
I’m going to assume 25% Cox fuel with ~20% oil (50% castor/50% synth) is sufficient to bench run it?
Jason_WI
Jason_WI
Fox 35 with ST NVA Empty Re: Fox 35 with ST NVA
Post  Ken Cook Wed Sep 09, 2020 4:01 pm
Jason, I only clip the needle valve if the engine is mounted profile. When I do this, I solder a knurled knob onto the shaft after I cut it down. This is a pain in the rear because they blue the needle which needs to be removed if soldered. Having a Super Tiger needle in the Fox takes away some power that the engine really needs. It chokes the throat area of the venturi down. Turning down a Super Tiger needle valve usually breaks due to it being too thing to begin with. I just file a flat on one side of it. Some people have opened up the venturi to accommodate the larger spray bar. I believe a Fox is around .127" and the Tiger is .156" that's a considerable difference. The trade off however is that the Tiger needle offers very reliable and good adjustment. The stock Fox is crude but can be made to work, just not at the level of the Tiger.
As far as plugs, you can use any standard length hot plug for bench running. The hottest plug you can use which is a Thunderbolt r/c long. A Fox plug works if your bench running it but not one I would recommend flying with especially if you plan on stunting it. If you have the engine running and you remove the battery and you hear the rpm's drop audibly, your plug isn't hot enough. K&B 1L, Thunderbolt rc long, Mccoy MC-59, Fox standard long or rc long, Enya #3, I don't care for Fireballs due to many issues I've experienced from poor threads to leaking posts, OS A3 to name a few.
As far as fuel, you don't need high castor fuel even in the old engine. I run 22% oil 50/50 in all my Fox's. I own about 30 Fox .35's and they've been running on that blend for 25 or more years. The issue here is that Fox changed the wrist pin on the later Fox's. Your Fox might have the brass end pads which are extremely susceptible to wearing out and cutting grooves into the cylinder. I would just keep your oil content at 25% all castor which is more than enough protection.  Your suggestion of 50% castor is WAAAAAAAAAAAY too much oil and in fact it probably would just shut off with that syrup.
Post  Jason_WI Wed Sep 09, 2020 4:19 pm
Sorry about the oil confusion. I meant 20% oil with 50% castor and the other 50% being synthetic. I updated my post.
I'm sure this one has brass pads but haven't taken it apart to check yet.
I can file flats on each side of the NVA to open up a bit. I bought 2 of the ST NVAs so if I mess one up i have a spare.
Jason_WI
Jason_WI
Post  Ken Cook Wed Sep 09, 2020 5:29 pm
Personally, I wouldn't take it apart as it can do more harm than good. The case is like a eggshell. The cases are not square nor is the cylinder liner. If you tighten one screw on the head incorrectly, it can distort the case which distorts the piston liner. The liner isn't indexed so providing a witness mark is a must as well. 20% oil is the bare bones minimum I would run the Fox on. Dukes fuel was that percentage all castor. Dukes Superfuel was 28% which really fouls things up but many insisted on using it. One thing that's important is that the backplate doesn't leak. They used cork gasketing on some of these and that can really squeeze out. If the small screw tabs on the backplate are slightly bent, don't try and straighten them as they will break instantly.
Post  Jason_WI Wed Sep 09, 2020 5:39 pm
It’s a ‘63 model. Was off on the years a bit.
Fox 35 with ST NVA F0eec810
Fox 35 with ST NVA Bfc7b710
Jason_WI
Jason_WI
Post  Ken Cook Wed Sep 09, 2020 7:12 pm
Jason, from what I see you have a rare version there. Aside from that carb setup, the "63" version is the 15th anniversary gold edition. The gold plating was not very bright in terms of yellowish gold. It was a plating and it's extremely prone to peeling off especially around the mounts. However, this one looks great. In addition, the fits were quite good on this version. It appears to be in great shape. A terrific example, treat it well.
Post  Jason_WI Wed Sep 09, 2020 7:37 pm
I have yet to find a true value on this version. I only have $15 in it as i got it in a group lot of engines a while back. The NVA I just bought costs more. Trust me this engine will be used for something special.
Jason_WI
Jason_WI
Post  Cribbs74 Wed Sep 09, 2020 9:01 pm
Ken,
I already mentioned to Jason about the rarity of the engine and the reply was “It’s worth it”
I agree, it’s worth it!
Post  Ken Cook Thu Sep 10, 2020 3:01 pm
You probably won't find a value on it. Control line in particular doesn't command what are high dollar prices. Yes, Ebay does a great job of inflating values making everyone feel they have fortunes sitting around. Those that would've used these engines are essentially past they're flying days leaving the next generation of flyers. The control line hobby was based on money in mind and there wasn't a lot of it. Duke set a goal to produce a engine that the average person could afford and he accomplished that task. I poke fun at Fox's but in truth, I love them. A collector wants new or unrun and generally the box as well. Having one in that condition would indeed raise the value considerably. I would just appreciate it for what it is. Mine sits on my shelf and I pick it up now and then for a flip or two.
Post  Jason_WI Thu Sep 10, 2020 5:59 pm
The ST NVA arrived today. Is it best to file some of the diameter off from each side to reduce the restriction in the venturi? Once installed I'll give it a test run at the farm as I'm sure this thing will bark with the open exhaust.
Is a 10-6 prop to much for this engine? I'm not sure I have a 9.5-6 prop as I read that was about optimal for the Fox 35. I can always cut one down too I guess.
Jason_WI
Jason_WI
Post  Cribbs74 Thu Sep 10, 2020 6:51 pm
Jason,
It will run without any filing. However as Ken mentioned peak performance is achieved if the air Flow volume is kept the same as the original needle. I would file some off of both sides. It’s going to be a tricky affair as it’s not very thick to start with.  Hole pointed downward in final config.
Prop size depends on how the .35 performs, and what kind of run you want ie: 4-2 or wet 2. If you think it’s not broken in then start with the 9.5. The 10x6 is the standard for Fox .35 so you can’t go wrong. They do like a little bit of a load.
Post  Jason_WI Sat Sep 12, 2020 3:51 pm
It runs! Man this thing barks!
10-6 MA prop, glowplugboy 35% nitro, 20% oil (18% castor and 2% techniplate)
I don’t know what these generally pull. Might need to file more from the NVA to open it up.
Fox 35 with ST NVA 44270710
Fox 35 with ST NVA 3e04e910
Jason_WI
Jason_WI
Post  Ken Cook Sat Sep 12, 2020 5:53 pm
You really want to keep your nitro below 15% ( This is good advice) if you want to keep the crankshaft from coming out. They're quite crude and can break across the cutout. Generally, if your getting a little over 12K on a 9x6 prop you have a strong runner.
Post  Jason_WI Sat Sep 12, 2020 6:09 pm
All I have is 35% Cox fuel. I do have a an old Top Flite 9-6 maple prop I can try.
Jason_WI
Jason_WI
Post  Cribbs74 Sat Sep 12, 2020 6:46 pm
Cool!
Serious Nitro though. It won’t last at that percentage. Listen to Ken. 5-10% is what we  use in the field. What you re-created was a 1960’s combat run. Still very cool!
If you can get 12K on a 9x6 I would leave the needle as is. Your almost 11K now so it will for sure do it. I would let it be and send it out.
They do bark, big difference from a Cox. It’s all torque
Post  Jason_WI Sun Sep 13, 2020 12:56 am
Ok. I’ll call it good before I grenade it.
Thunderbolt RC long plugs ordered.
Jason_WI
Jason_WI
Post  Ken Cook Sun Sep 13, 2020 7:50 am
Jason, I meant to inquire earlier on. Why don't I see the through hole in the case for the needle valve on the side view pic of the exhaust side of the engine? I noted the other side had a screw. Nonetheless, it looks great and they really are cool engines.
Post  Jason_WI Sun Sep 13, 2020 9:35 am
JB weld in the hole I had to clean out. Someone glued the carb into the venturi.
Jason_WI
Jason_WI
Post  Jason_WI Wed Sep 30, 2020 2:51 pm
Needle shortened. Required acid flux to get the knurled end soldered on. Hopefully not too short but too long would cause a problem with vibration with the added weight on the end.
Fox 35 with ST NVA 418bf010
Jason_WI
Jason_WI
Post  Cribbs74 Thu Oct 01, 2020 10:51 am
That’ll work Jason. Good job
Generally with ST NV’s they just get cut down and the end gets bent on a 90 degree angle.
What I like about Tigre needles is they get set once and only need minor tweaks one way or another to compensate fo temps/nitro content etc. to maintain the same engine run.
Post  944_Jim Thu Oct 01, 2020 2:51 pm
Jason,
I also have a Fox .35 (condition like new). I took some high-nitro fuel and cut it with straight methanol to get 5% nitro fuel. It would be good to compare notes as we both work toward getting these engines ready for flight.
I used Andy's two-fuel blend Excel spreadsheet to establish how much of each fuel and how much castor oil to make the appropriate blend.
The engine ran fine...well, as well as expected as I learn about big engines and their required break-in. Now it runs quite well, so I hope to hand it in an airframe and go fly BIG.
