Rear Bear 2020 Cox_ba12
January-2022
Mark Boesen's
Twin Needle Thermal Hopper with a Cage Mount.
Dick Russ Models
Forum Store
CEF Ear Savers
Rear Bear 2020 Empty
Rear Bear 2020
Rear Bear 2020 Empty Rear Bear 2020
Post  roddie Wed Oct 28, 2020 8:39 pm
Hangared..
Rear Bear 2020 20201011
Rear Bear 2020 20201012
Rear Bear 2020 20201013
Rear Bear 2020 20201014
I want to fly this airplane.. this year.. especially.
Rear Bear 2020 Empty Re: Rear Bear 2020
Post  Marleysky Wed Oct 28, 2020 10:20 pm
Nice! I see what you pun there!! nice job!
2020 Supporter
Post  rsv1cox Thu Oct 29, 2020 6:26 pm
Still looks great roddie, regardless of what you call it. Smile
2020 Supporter
Post  roddie Thu Oct 29, 2020 6:45 pm
@Marleysky wrote:Nice! I see what you pun there!! nice job!
Hi Rene, Smile I actually checked the crankshaft end-play this afternoon after reading thru Mauricio's "Cox Fun Model .049..." thread. This engine is my CEF Tach-Race engine of back a couple 3 years ago.. Laughing It's nice and tight.
I should make-up a shorter set of lines to re-train myself. I learned back in 1992 on 25/26ft. lines. The property (back then) had a clearance for a 55 foot diameter circle. I used to mark center-circle with the cover from a plastic pail.. with a long gutter-spike (6" L. AL nail) to anchor it. A "foot-feel" reference for the pilot. to stay within the safe-zone.
The Rare Bear has yet to fly.. due to multiple launching faults/follies. It's nose-heavy.. and the gear-mains are set back under the wing's leading-edge. It's the ragged-edge of being able to R.O.G. launch.. There's only been two instances where I've tried to fly this airplane. 1st was for the CEF Speed contest that it was built for.. and 2nd was just last year. Nose-overs plagued any attempts at R.O.G./stooge-launches.
I wonder if a break-away launch-streamer clipped to the top of the fin might help to keep the tail "down" until the model gains enough speed to be responsive to elevator commands.
Post  Cribbs74 Thu Oct 29, 2020 8:10 pm
Roddie,
Just re-angle the gear and extend it about an inch. That is all that is keeping it from getting off the ground. Don’t worry about looks.
2020 Supporter
Rear Bear 2020 Empty Rare RARE Bear...
Post  roddie Fri Oct 30, 2020 7:17 pm
Oh boy.. Roddie's had a challenging 2020.. as we all have. I just now noticed how I titled this thread.. I need a check-up.. from the neck up.. What? How about Rear Bar.. where the drinks are made just a little stronger.. Laughing
Post  roddie Fri Oct 30, 2020 9:07 pm
@Cribbs74 wrote:Roddie,
Hi Ron! Yea.. I'd need to remove the gear-blocks to REangle the struts forward. The struts are beefy 1/16" music-wire. The gear-blocks are made from 3/8" Cherry square-stock.
Rear Bear 2020 11-19-15
There's a walnut strip-spar built-into the L/E of the wing, which the gear-blocks mount to. It's very rigid when assembled.
Rear Bear 2020 11-15-11
Rear Bear 2020 11-28-11
I tried to find the balance-point tonight using a fixture that I'd made.. but the model just pitches fore/aft no matter how I set it. Maybe it's a Grumman F8F-2 thing.. Shocked There isn't too much safe clearance for the propeller if I angle the existing gear forward. I could forego the cowling.. and swap-in an "inverted-V" gear for in-between the engine and firewall.. but I'd really hate to resort to that.. you know?
Rear Bear 2020 20201017
Rear Bear 2020 20201018
