How to clean? Cox_ba12
How to clean? Pixel
» COX .020 RC PROJECT
by getback Today at 5:55 am
» Ignition Points for Ohlsson 23
by getback Today at 5:11 am
by roddie Yesterday at 6:51 pm
» some pics....
by roddie Yesterday at 6:21 pm
by GallopingGhostler Yesterday at 9:22 am
by sosam117 Yesterday at 8:58 am
by Oldenginerod Yesterday at 7:30 am
by GallopingGhostler Yesterday at 7:29 am
» Cox Rivets OWNERS FLIGHT MANUAL
by howardhb Yesterday at 7:03 am
» WILLY NILLY
by MANDALAY Sun Sep 15, 2024 7:28 pm
by rsv1cox Sun Sep 15, 2024 4:58 pm
» Thrust Washer
by davidll1984 Sun Sep 15, 2024 8:25 am
September-2024
F4D Phantom II's
"Surestart .049 geared opposed twin"
How to clean? Empty
How to clean?
How to clean? Empty How to clean?
Post  WingingIt74 Mon Feb 13, 2012 6:25 am
Can you soak old grungy parts, if so, in what?
WingingIt74
WingingIt74
How to clean? Empty Re: How to clean?
Post  PV Pilot Mon Feb 13, 2012 6:45 am
Denatured alcohol is a effective safe soaker solution Travis.
Model fuel works good for a week+ long soak solution, to break down some of the crud.
Hoppes #9 nitro solvent (gun cleaning solvent) works for a 2-3 day short soak and then toothbrush scrub, the quickest I found over the years. Right out of the bottle with a toohbrush scrub gets parts clean quick, no real soaking required if not needed.
To brighten brass quickly,,use a quick dip and scrub with Tarn-x.
To strip alum to a very clean satin finish, use Eagle 1 Etching formula mag wheel cleaner,,be carefull, this pulls a layer of alum off turning it black as the hydrofluoric acid works. It will require a re-polish,, but it gives you a clean slate to work with.
For a final cleaning before assembly,,I flush all of these solvents off with CRC quick dry electrical cleaner,,found at Wal-mart. I was buying Dynamite Nitro Force nitro cleaner 20 oz pressure cans by the double case when I was racing,,that is until I discovered the CRC stuff,, Wink
The CRC QD elec cleaner is a very fast evaporative solvent,as such, when it starts to dry it leaves a bit of moisture on the part. Parts placed under a light bulb will warm quickly and evaporate that. Compressed air works good for blowing and drying that off quickly. Heat gun, hair dryer, all work well. I usually just use compressed air to blow that off.
All these items can be found at Wal-mart, besides the Nitro force cleaner.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  WingingIt74 Mon Feb 13, 2012 7:21 am
What do you use for rust on the cylinders?
WingingIt74
WingingIt74
Post  Cribbs74 Mon Feb 13, 2012 8:22 am
Depends on the amount of rust, if it light just use fuel and a tooth brush. If it is moderate to severe then head down to your local auto parts store and pick up a container of this.
http://www.autozone.com/autozone/accessories/Evapo-Rust-32-oz-rust-remover/_/N-255s?itemIdentifier=643195
Throw the cylinder in it overnight and it will look brand new in the morning.
Works excellent, non toxic and no fumes. It's not cheap but, it is reuseable and it safe for all metals. Even removes rust from chrome without messing up the plating.
Post  GermanBeez Mon Feb 13, 2012 8:26 am
weell, there's always the trick with ethylene glycol and the cooking pot...
GermanBeez
GermanBeez
Post  WingingIt74 Mon Feb 13, 2012 8:30 am
cribbs74 wrote:Depends on the amount of rust, if it light just use fuel and a tooth brush. If it is moderate to severe then head down to your local auto parts store and pick up a container of this.
That looks like some good stuff. Does it have to flow over the part?
WingingIt74
WingingIt74
Post  Cribbs74 Mon Feb 13, 2012 8:40 am
Nope, just put a little in a cup and dunk it in. Walk away and check back in the morning. It must be totally submerged though. I use it for removing rust from motorcycle/car parts. It will start to rust again unless you get oil back on the cylinder.
Also Gun Blue works well for taking the appearance of scratches off the cylinders. It won't remove gouges or deep scratches but it will restore the black coating.
Gun blue is also anti corrosion control provided you don't get it wet. It will protect it from moisture in the air.
Post  WingingIt74 Mon Feb 13, 2012 8:58 am
I got some parts from Jeremy's uncle Randy. Seen a few pics, just trying to make a game plan Smile
WingingIt74
WingingIt74
Post  PV Pilot Mon Feb 13, 2012 9:51 am
Hoppes#9 nitro solvent will pull the rust off of the cylinder.
PV Pilot
PV Pilot
Post  microflitedude Mon Feb 13, 2012 9:56 am
GermanBeez wrote:weell, there's always the trick with ethylene glycol and the cooking pot...
Antifreeze? It works great. Overnight on low.
Of course, never eat out of it again, and if you get rid of the pot, smash the insert so nobody else tries to use it.
microflitedude
microflitedude
How to clean? Empty Penetrant tests
Post  jsesere Sat Feb 18, 2012 4:17 am
http://grassrootsmotorsports.com/tech-tips/55/
jsesere
jsesere
Post  andrew Sat Feb 18, 2012 8:19 am
jsesere --
Thanks for the link -- that's going into my folder of useful tips.
Post  DavidGurine Tue Nov 27, 2018 8:45 am
Hey! I do usually use only professional cleaning liquids. There are a lot of brands on the top of the market. I prefer Maguire's and Quick Silver. For example, MEGUIAR'S NXT GENERATION CAR WASH 1.89L is the best for old cars. I offer car parts and washing liquids on different sources which provide door-to-door delivery. I am also going to choose a dash camera here: https://autoexpertguides.com/best-dash-cam/ They deliver all the items with all the necessary certificates and sometimes add valuable presents.
DavidGurine
DavidGurine
New Member
New Member
