» Tiny Cox engineby Levent Suberk Today at 1:54 pm
» Thimble Drome Special
by Propfan Today at 1:47 pm
» Graupner/kyosho RC bike
by Levent Suberk Today at 1:28 pm
» cox 010 cylinder wanted
by robot797 Today at 12:05 pm
» Super Satan build
by oldguy Today at 10:19 am
» Jerobee Alfa T33 Can Am.... It’s all mine!!!
by Cribbs74 Today at 8:34 am
» Cox Postage Stamp Engine Mount
by NEW222 Today at 6:58 am
» Minnie Mambo Rescue
by dirk gently Today at 6:01 am
» covid 19 restoration
by getback Today at 5:57 am
» Sig Skyray
by oldguy Yesterday at 11:52 pm
» Can someone identify my Cox engine.
by dckrsn Yesterday at 9:20 pm
» Cox Thimble Drone Special "O-Forty-Five" rear motor
by Billyjackclark1982 Yesterday at 8:40 pm
Help me Find m'y lost Snowmobile engine
Picturs of the first engine y Reciver from california dan y have buy two Reciver only one Snowmobile engine and recived mont later one new beab bee wit 10 prop som one Reciver m'y engine message california dan plz if u recived wrong engine y no Snowmobile engine wort more mony than bee and y need them for spécifiques prototype so plz contact saler we need u say its you you must be australienne alredy no cuz m'y engine was lost To australia its just very sad To me
davidll1984- Platinum Member
Re: Help me Find m'y lost Snowmobile engine
Wow y found hi performance cylinder no3 twin bypas wit spi tapered. tee dee piston Not taper hemi glow plug cylinder was loose Not tight for the engine To fit inside its box exaust point wrong direction and heat sink al the rest is tight redy To run the engine was sale for parts
Last edited by davidll1984 on Tue Dec 01, 2020 10:57 pm; edited 1 time in total (Reason for editing : Corection)
Do you have a snowmobile to put it in?
no y dont have the snowmobil y have two new engine part of my colection y dont nead two but part good to keap spare parts just in case
Yeah it’s not real common, you live in the perfect place to run one. You may have to build one over time to keep the costs down. The track will be the hardest, but with 3D printing it may be possible to make one.
Hi David, There is a 1:8 scale RC (toy-grade) snowmobile that's made by "Inter Active" Company. I have one.
Not sure if the track/drive can be adapted to your Cox sled.. but it might be worth checking out. There's also a 1:5 scale RC sled sold under the "New Bright" brand.
I'd like to see the track being able to be removed by merely releasing the tension from the drive-system. The track tends to "stiffen" around the radii of the drive-cog and rear idler roller during periods of non-use.. resulting in a "flopping" action when running cold. I'd rather have the option of easily installing a track that's concentric.. which would run smoother.. saving energy.
What is the scale of the Cox snowmobile?
Lol yeah 3D print is what I meant.
Y dont no the scale of cox snowmobil y tink the smaler one wil be best just cant Find one for cheap To experiment wit rare toys last year canadientire was seling som sort one capt m'y attention tink it was To big for the litle cox engine power tink power compare To 1\18 size engine for cars like 280 To 370 max tink Snowmobile wit 280 size engine wil fit for Not sur of the size of new bright sled can u verify the size of the interactive 1\8 engine ?? Smal large long mesure t Not sur look if posible space inside engine beay for cox engine just the flyweel take lots of space y look for one used without controler in Good chape just cant Find one
Track patern Not the same excep the size look ok is the model hevy weight without batry ??is it posible To look inside more détail of the 1\8 bruched engine size if its posible To make it light like les than 500g without électrique stuf ?? Posible way To convert ??
Wil Find y am good for engine fit modification of al kind
Engine lost in transit chip To wrong place tink its swap customer like some one ordered one babe bee me two Snowmobile engine and Reciver of the wrong pacage swaped m'y engine for his and its theft police involve its bad so be kind contact california dan if by mistake u recived wrong engine lets say its chiping eror y dont no y just want To Find out wat hapened engine its exact same engines se on picturs wit al of of his détail no babe here complète difrent y cant remember tink you post Somting like wat je that engine or Somting just cant Find it was here y tink
you have To contact seler if Reciver somting wrong and it Good To everyone plz help
David,
A little difficult to understand that post. I am not sure exactly what you are asking or saying, but I think you are saying someone swapped your engine and sent you theirs? Don’t know why anyone would go to that length to take an engine. Not to me mention the logistics behind that would be something out of an Oceans 11 movie.
More than likely your engine was sent to the wrong person and they kept it.
Contact the seller and get a refund. Cut your loss and try again.
Just had to show this i have never seen one in Action
Daved i don't think anyone here has ur engine or they would speak up
Yes cribbs74 the person ho recived m'y engine have post in here after reciving m'y engine dint no wat it was asking by description wat he recived saying ordered one bae bee wit 10 prop and recived un nown To him Snowmobile engine y cant Find him. him is in here y wil Find
Do you have his username?
When did he make that post?
Y dont Find it tink y have reply on that post y have runing tru m'y post cant Find tink he change post name and edit the first text but wy cant Find m'y own comment ???
And y have kind of surprise yesterday Find one of m'y order went To exotic place crazy lol To jamaica far from Canada wat the hec is going on wit m'y stuf
davidll1984 wrote:Y dont Find it tink y have reply on that post y have runing tru m'y post cant Find tink he change post name and edit the first text but wy cant Find m'y own comment ???
He can’t change his name without going through Admin. He can edit the post.
davidll1984 wrote:And y have kind of surprise yesterday Find one of m'y order went To exotic place crazy lol To jamaica far from Canada wat the hec is going on wit m'y stuf
It's the combined postal systems David. Gone nuts as you say.
I will keep an eye out.
What?
You're saying someone who has your engine came on here and posted about it?
You need to contact Dan and have this sorted out. ASAP. Get a refund or a partial refund. If he doesn't want to work with you, open a claim on eBay and let them work it out. I know you're trying your best, but you may want to have someone type the messages for you as you're going to want them to be as coherent as possible.
I'm sorry you didn't get what you ordered, that sometimes happens. Probably an honest mistake. There's practically nothing we can do to help you get the correct engine. Maybe only if someone on here has Dan's phone number.
Remember, postal services are running at a snail's pace due to Covid.
