» "Me and Crazy Horse...Our Anniversary"by Kim Today at 3:23 am
by balogh Today at 12:55 am
» Original Box for P-51 Bendix Trophy Racer Value
by Wayne Brown Yesterday at 11:09 pm
» Cox P-51 Bendix Trophy Racer
by Wayne Brown Yesterday at 5:39 pm
» thread measurements
by MauricioB Yesterday at 5:33 pm
» Cox Thompson Trophy Winner
by Jerry Yesterday at 5:20 pm
» COX 010 TeeDee with RC carb, courtesy sosam 117
by rdw777 Yesterday at 3:08 pm
by robot797 Yesterday at 1:34 pm
» OS 10FSR Carb Needed
by Cougar 429 Yesterday at 1:14 pm
» AP .061 Hornet
by F4D Phantom II Sun Mar 17, 2024 10:01 pm
» dozens of old .049 TeeDee's, Medallions and a few others
by rsv1cox Sun Mar 17, 2024 7:46 pm
» Re-manufactured Enya .06-II for Boats13
by Boats13 Sun Mar 17, 2024 7:32 pm
Diy Anodizing
Page 1 of 3
Page 1 of 3 • 1, 2, 3
davidll1984- Diamond Member
Re: Diy Anodizing
What were you going for David? Something darker in a different color? In your picture the anodizing looks pretty universal without discoloring.
What was your process?
Qu’est-ce que tu allais faire pour David ? Quelque chose de plus sombre dans une couleur différente?Dans votre image, l’anodisation semble assez universelle sans décoloration.Quel a été votre processus?
Re: Diy Anodizing
Wel its anodize just The color is not rich enough y try wit acid méthodes posible the color is To Dilute m'y power suply Not Good tink y need more amp y try now green wit difrent power level and two anode bit more cars batry acid wit les water y have To hetch the parts litle wit drain opener drano wil let furent 2 h last time was just 1:20 Not mutch bether let part longer the best ?? Tink its m'y first try wit anodizing work its bit confusion
Re: Diy Anodizing
Looks great David. What is your process, how are you doing it?
Re: Diy Anodizing
Great job David!
Re: Diy Anodizing
Looks Good David ! I know this is a stupid question But have you fuel/nitro tested the items ?
Re: Diy Anodizing
do not need to Eric the Aluminum Oxide Layer (anodising) David is doing is the exact same way commercial anodizers do it. Once the Dye is sucked into the capillary tubes of the oxide it is mostly impervious to most solvents until deliberately chemically or mechanically stripped
Re: Diy Anodizing
I tink of try wil ses wat hapen i have one fail To tint and color fade To very light color after boil in water Not sur wy its norvel exaust parts its like the aloy made difrent ?? i made couple scratch test its resist abrasion wil test the fuel tank first
Re: Diy Anodizing
If you feel so inclined David. I think you got it figured out just right, and what you got so far looks like it is working great!
Re: Diy Anodizing
Yes as fredvon say it Should resist. the light I think should discolor the parts not the gas heat wil change color To tink Not tested
Re: Diy Anodizing
Very Good gives the truck some Bling ! What color is that ur using Daved
Re: Diy Anodizing
i use dolar store primo Bingo marker its posible To use just pen marker and make Drawing just for information can use sticker and make cool desing its Not that hard Now i no how To color m'y own mangusta ..... Lol I can build mutch bether engine internal components modification parts hard To Find i working on spécial new heatsink Somting for the tee dee and al difrent .049 i want To modify m'y cylinder for extrême cooling and color the parts
Re: Diy Anodizing
Nice job on that blue fuel tank David.
Re: Diy Anodizing
David I have too hard a time reading your posts...but...I must say your anodizing is good to go home brew method thumbs up brother
Re: Diy Anodizing
Good job David , those parts look great ! Now if we could only learn how to plate the inside of our cylinders with chrome .
Mike1484
Mike1484
Mike1484- Gold Member
Page 1 of 3
