Shuriken 1/2A engines Cox_ba12
Shuriken 1/2A engines Pixel
July-2021
"Rusty's RR-1 runs up on the Q-Tee on a beautiful Summer S.M.A.L.L. Day."
Forum Store
CEF Ear Savers
Shuriken 1/2A engines Empty
Wanted Shuriken 1/2A engines
Post  BlackWidow Thu Apr 22, 2021 9:22 am
I did a Shuriken search and nothing came up.... so hope I am not being redundant.
Looking for Shuriken parts - specifically, a backplate.  Airplane
Also, would like some advice on the physical difference between the Shuriken .050 and .061? Huh...
THANKS
Shuriken 1/2A engines Backpl12
BlackWidow
BlackWidow
Moderate Poster
Moderate Poster
Wanted Re: Shuriken 1/2A engines
Post  fredvon4 Thu Apr 22, 2021 9:28 am
2019 Supporter
2020 Supporter
Post  BlackWidow Thu Apr 22, 2021 9:34 am
Thanks.. Yes I have seen this.
Short of engine disassembly and careful measurements, there still seems to be no way to know the engine displacement?
The engine evaluation (by Mike Billinton) in Septreflight does not provide any information on determining engine displacement.
BlackWidow
BlackWidow
Moderate Poster
Moderate Poster
Post  fredvon4 Thu Apr 22, 2021 9:48 am
I think the last post has a sheet of the specs....the .061 was rear exhaust with different bore and stroke
Doug Galbreath used to work on high speed free flight and racing engines he may have a part or two. He retired but still has his web site up
http://www.the-printer.net/DookCat.html
Place and ad in flying lines flea market as many from north west had these for speed events, Paul Gibeault comes to mind
http://www.flyinglines.org/index.html
In a bit Ken Cook here on CEF will see your post and add his insight.
2019 Supporter
2020 Supporter
Post  BlackWidow Thu Apr 22, 2021 9:54 am
@fredvon4 wrote:I think the last post has a sheet of the specs....the .061 was rear exhaust with different bore and stroke
THANKS.. Funny enough, I just purchased this Shuriken MkII (gold) from Doug Galbreath's son, Howard.
It may have been run, but the condition is like brand new.
I have asked him to look through his parts to see if the backplate can be found.
Short of that, also trying to find another source for one.
You may be right on the .061 being the FIRE configuration, but in all my reading on the Shurikens, that isn't clear to me.
My interpretation is that the .050 and .061s were both available in either FISE or FIRE, but I could be wrong ? Shocked
BlackWidow
BlackWidow
Moderate Poster
Moderate Poster
Post  gkamysz Thu Apr 22, 2021 10:44 am
I don't think there were any .061 in gold. The gold engines were made after Baldwin and Van Arsdall split (marked "VE"). Before the split they were marked "BV".  By removing the head, the bore is easily inspected. .399 is just smaller than a typical Cox .049. The .441 bore will be visually obviously larger than a Cox .049.
I had a Shuriken for a while, but didn't take any notes on parts or the design before I sold it.
gkamysz
gkamysz
Post  Ken Cook Thu Apr 22, 2021 3:50 pm
Fred Baldwin posted on RC Groups some time ago. You can do a search for Shuriken and see what comes up. I spoke with him a few years ago and had probably a 1 1/2 long conversation with him. Fred had mentioned that certain parameters were met between him and his former partner Jim in which that no more engines would be sold and certain parts to be disposed of. Fred mentioned he kept a few parts. He might have what you need however, his track record for providing parts isn't a glorious one. There were two version backplates. I have no spare parts. I owned 4 Shurikens, 3 being .049's and one .050. I kept the worst .049 and still own the .050 which is essentially new minus the box. Mine are all side exhaust engines. The same pin spanner that removes the head button also removes the backplate therefore if you do locate one, you will need the tool.
Post  BlackWidow Thu Apr 22, 2021 4:11 pm
@Ken Cook wrote:               Fred Baldwin posted on RC Groups some time ago. You can do a search for Shuriken and see what comes up. I spoke with him a few years ago and had probably a 1 1/2 long conversation with him. Fred had mentioned that certain parameters were met between him and his former partner Jim in which that no more engines would be sold and certain parts to be disposed of. Fred mentioned he kept a few parts. He might have what you need however, his track record for providing parts isn't a glorious one. There were two version backplates. I have no spare parts. I owned 4 Shurikens, 3 being .049's and one .050. I kept the worst .049 and still own the .050 which is essentially new minus the box. Mine are all side exhaust engines. The same pin spanner that removes the head button also removes the backplate therefore if you do locate one, you will need the tool.
RC Plane THANK YOU!
BlackWidow
BlackWidow
Moderate Poster
Moderate Poster
Post  BlackWidow Thu Apr 22, 2021 8:03 pm
I was fortunate enough to contact Fred Baldwin and speak with him this evening.
GOOD TO GO!
My Shuriken will be made whole This Site Rocks!
BlackWidow
BlackWidow
Moderate Poster
Moderate Poster
Wanted Shuriken backplate
Post  Paulgibeault Fri Apr 23, 2021 10:50 pm
@BlackWidow wrote:I was fortunate enough to contact Fred Baldwin and speak with him this evening.
GOOD TO GO!
BW: I do have spare Shuriken backplates for sale, but they are a backplate ONLY and not a backplate combined with a radial mount.
Do let us know on your dealings with Fred Baldwin. As Ken Cook alluded to, Fred leaves a lengthy trail of broken promises.
He still owes me for bearings that I prepaid $100.00 for in good faith. Four phone calls over four years have produced nothing but empty promises & no refund of my money.
All I can say is exercise great caution if sending this individual ANY money. You have been warned. Good luck.
Paul
Paulgibeault
Paulgibeault
