» *Cox Engine of The Month* Submit your pictures! -December 2023-by MauricioB Yesterday at 9:02 pm
» Cox .020 SkyCopter
by duaneh Yesterday at 8:25 pm
» K&B greenhead .35
by rsv1cox Yesterday at 6:24 pm
by rdw777 Yesterday at 5:23 pm
by robot797 Yesterday at 2:49 pm
by Dave Rigotti Yesterday at 2:23 pm
by rsv1cox Yesterday at 12:42 pm
» Hoppers and Bugs
by cstatman Yesterday at 12:38 pm
by OVERLORD Yesterday at 6:21 am
by Ken Cook Yesterday at 4:31 am
» Spitzy 8 ? O&r
by Ken Cook Yesterday at 4:23 am
by kevin king Yesterday at 3:10 am
Something else
Something else
Well, the previous CL that I was making wasn’t doing it for me, and I have no interest in building FF models, so I needed something else.
But, as I said, the jig rib idea lets me do a model I've wanted to do for a while. So I downloaded the plans for the Red Wing, from the December ‘64 Flying Models:
https://outerzone.co.uk/plan_details.asp?ID=12878
And I did up a set of files to cut the ribs. Unfortunately, as a flying wing, it takes a LOT of balsa for the ribs. The ribs being so big, it’s hard to efficiently utilize the sheets, so there will be a lot of wastage. I figure I’ll use a total of five sheets of 1/16”, one sheet of ¼”, and some scrap 1/8” balsa.
The ADD Mark
The ADD Mark
batjac- Diamond Member
Re: Something else
You could save the Kapok trees and make it out of the 1/4" fan fold foam (blue FFF) if you can find it. There is a plan here http://www.frostracing.com/spadtothebone.org/PDF/Diamond_Dust.pdf for a larger coroplast one that you could substitute the foam foe using the plan from OZ for size. Just a thought.
aspeed- Platinum Member
Re: Something else
Well, that didn’t work….
I made time last night to cut the ribs for this project. They came out pretty good.
You can see that the rib pairs are perfectly matched without a lick of sanding. I couldn’t do that by hand without a lot of slow and careful sanding.
Then I tried to make my jig ribs. The ribs in my .svg file are dashed along the rib outline, as you can see above. That way, I can just pop out the L.E., T.E., and spar cutouts and slide the sticks through the holes to jig up the wing while I build. Then, once the wing is complete, I just cut along the dashed line and the wing is free and in perfect alignment. But, even though my .svg file has dashed lines around the rib outlines, the Cricut machine cut them as solid lines:
Confusing, but “Oh, well”. No biggie. I’ll just tape the ribs in place in the jig. That should hold them while I build the wing, and then I can just peel away the tape when I’m done. I’ll have to do some more experimentation to get the dashed lines to cut like I want.
The Perplexed Mark
The Perplexed Mark
Re: Something else
Here's the video of the wing ribs being cut. The ribs range in size from 5.25 inches to 14 inches long.
The Cinematographer Mark
Re: Something else
Looks like you bought got this thing wiped to do what you want , is that the same machine ? with upgrades ?
Re: Something else
getback wrote:Looks like you bought got this thing wiped to do what you want , is that the same machine ? with upgrades ?
Standard Cricut Maker machine, just as it came out of the box from Hobby Lobby. I have a couple of experiments on how to try and make the machine cut 1/8" balsa, it's rated for 3/32" max, but that's for another day.
The Box Stock Mark
Re: Something else
Mark, that's most impressive how it can cut circles across grain as it does. What is actually holding the parts in place as they're being cut? I see you had to ease the parts off of the mat.
Re: Something else
Ken, the mat that the balsa is on has a sticky surface. There are different levels of stickiness. The purple mats are the "stickiest" mats you can get for the Cricut machines, and that's what we need for doing balsa.
The Wicket Mark
The Wicket Mark
Re: Something else
Mark, my next question is how do you plot the pieces on the sheet. In other words, is it possible to orientate grain direction?
