Willy Nillie's Shoestring micro racer powered by COX TeeDee010 - Page 3 Cox_ba12
Willy Nillie's Shoestring micro racer powered by COX TeeDee010 - Page 3 Pixel
by HalfaDave Today at 6:36 pm
» Dremel/rotary-tool helpful tip thread
by roddie Today at 6:05 pm
» hobbyking "covering film" opinions?
by cmulder Today at 12:52 pm
» Your oldest "active" model?
by cmulder Today at 12:28 pm
» Old CL Gee Bee
by rdw777 Today at 12:12 pm
» Wen Mac XL-600 Fan Jet - Something different
by rsv1cox Today at 9:16 am
» So where is George the Gallopying Ghoster?
by getback Today at 8:56 am
by balogh Today at 7:41 am
» "Kim's Breezy Hill Editorial"
by rdw777 Yesterday at 9:23 am
» Cox red tank mount for beam mount 049 engines
by ffkiwi Wed Jan 15, 2025 4:25 pm
» My knock-off Gee Bee of Robert's Gee Bee post
by rsv1cox Wed Jan 15, 2025 10:38 am
» My knock-off Gee Bee of Robert's and Bob's Gee Bee posts
by rsv1cox Wed Jan 15, 2025 10:31 am
January-2025
akjgardner's
"BW on my Hawker Tempest"
Willy Nillie's Shoestring micro racer powered by COX TeeDee010 - Page 3 Empty
Page 3 of 3 Previous  1, 2, 3
Willy Nillie's Shoestring micro racer powered by COX TeeDee010 - Page 3 Empty Re: Willy Nillie's Shoestring micro racer powered by COX TeeDee010
Post  rdw777 Wed Dec 25, 2024 11:26 am
I like it Andras!!…. Decorations are spot on, Just enough to show them off…. A very thoughtful build that I know will perform well…. Love to hear the high rpm .010’s zipping around Small Cox Logo Small Cox Logo Small Cox Logo
2025 Supporter
Post  balogh Wed Dec 25, 2024 11:46 am
Thank you, Robert. I am confident the laser printed stickers are well protected by the external transparent film heat-shrunk on the balsa.
We have near freezing temperatures here so the maiden flight is yet to come.
The Shoestring No.2 is powered by a brand new old stock COX TeeDee 010 ( red delrin mount, black steel carb, taper bore in cylinder) with a nice pinch at the Top Dead Center..I gave it a break in run in my unheated garage, about  2×3 minutes with very rich fuel-air setting that kept it in "4 stroke" run near 15k rpm until the castor in the exhaust cleared up from the greyish metal particles and became clear. There still is a pinch indicating the taper geometry stays, but the surfaces are much smoother and subsequent wear of the piston and cylinder mating surfaces drops to minimum.
At the end I peaked it up to  ~26k that, given the thick winter air, will presumably rev up to the specified ~27k in summertime when the air density will be less by ~12%. (As we know it follows from the Rule of gases that each ~27.3C change in gas temperature will entail 10% change in gas density, if the gas pressure is unchanged. Propeller shaft power is directly proportional with air density,  and also proportional with rpm on the 3rd power, on the other hand..so a roughly 12% air density reduction at 32...35C air temperature in summer ( that I am already yearning for) will expectedly cause a  jump in engine rpm from 26k to 27k.
Weather permitting, the maiden flight is coming soon..
2025 Supporter
Post  rdw777 Wed Dec 25, 2024 3:30 pm
Nice Andras, more oxygen in the colder, denser air….I first noticed this as a teenager on my two stroke dirt bike….. Seemed to have more power on cold days…..
2025 Supporter
Post  balogh Wed Dec 25, 2024 4:09 pm
That is right Robert, the richer charge may offset the impact of heavier load on the prop shaft.
2025 Supporter
