» STUKA bomb dimentions neededby latole Today at 9:36 am
by roddie Today at 9:29 am
» Indexing COX cylinders
by Yabby Today at 7:47 am
by Yabby Today at 6:33 am
» 1/2a Skyray plans?
» Postage stamp backplates
» Parts Cox TD-4
Ringmaster Jr. Build.
Page 1 of 4
Page 1 of 4 • 1, 2, 3, 4
Another hotel job!
I am in Idaho and believe it or not the LHS carries Brodak items so I decided to buy a Ringy Jr. And build something to fly here.
I started last night and here is where I am at. The wing was started around 5:30 mountain time this evening and is probably the quickest wing build I have ever done. Thanks to laser cutting and good wood it's actually straight too.
Power will be a Fox .15 although it's coming out nose heavy so I may go to a Cox TD .09 when I get home.
Shipping should be fun!
Re: Ringmaster Jr. Build.
That is impressive Ron.
How do you build all that in one evening?
How did you align and glue the ribs to the leading and trailing edge without using a jig? Please give me some pointers.
Theo
Theo
Theo Kleynhans- Gold Member
Theo Kleynhans wrote:That is impressive Ron.
Theo
Theo,
The wing you see uses three different types of adhesive. 30 min Epoxy, SigMent and thin CA
Epoxy was used for the bellcrank mount, leading edge splice and joiner. CA on the ribs and SigMent for the sheeting and wing tips.
I was lucky in that all my wood was arrow straight so that makes it really easy to build a straight wing without a jig. I am pretty good at sighting along the LE/TE for straightness and don't do any final glue work until I am sure it is straight.
So no real tips, but as far as the speed os concerned, I had zero distractions.
Do the ribs have removeable prop tabs to hold them level like my Skyray kit? No need for a jig on that either. Looks good. I'm wanting a Junior size plane too.
You Dog you Man that's putting the pedal to the medal in building . Nice looking Build Ron
RknRusty wrote:Do the ribs have removeable prop tabs to hold them level like my Skyray kit? No need for a jig on that either. Looks good. I'm wanting a Junior size plane too.
No, I was hoping they did. A lot of TLAR going on, but sighting down the LE and TE it looks near perfect.
They didn't provide tip weight in the kit, so I am going to have to figure that out. I thought maybe it was a mistake, but it's not on the parts list either.
Rusty,RknRusty wrote: I'm wanting a Junior size plane too.
The Sig Akromaster is only $28 through the sig website, I just ordered 2 to have on hand. I don't know if I will build two .15 size planes or one .46 sized bipe.
Ron,
Nice build! I'm jealous, I just got back from idaho last night . I wish I could stay a month. Are you doing any fishing while you 're there?
JPvelo- Diamond Member
Thanks Jim,
No fishing here. It's all business. Not sure what is was like where you were, but it's high desert here. Not one lake around.
Here is day 3 progress.
Man! Awesome build! I never had anything like THAT when I was traveling for work. Great job on the build.
The Envious Mark
The Envious Mark
batjac- Diamond Member
Very nice, Ron. I don't how you do it. Do you have a big enough suitcase to take it home?
lieven
lieven
OVERLORD- Diamond Member
A quick build and it looks like neat work. That is the stage I get to and then ............ stall on finishing.
I am looking more and more at profile planes with a view to electrifying but trying to do it neatly so that it doesn't look "lashed" together.
Covering and painting seems to drag on for me.
I will be starting the bigger Ringmaster soon but it will be electrickery.
Ian I'm glad your distaste for profiles is reforming. I agree, their appearance leaves something to be desired but they fill a need to get good quality planes off the table and in the air. And they're such versatile platforms for experimenting and learning.ian1954 wrote:A quick build and it looks like neat work. That is the stage I get to and then ............ stall on finishing.
And yea I get bogged in the details too.
RknRusty wrote:Ian I'm glad your distaste for profiles is reforming. I agree, their appearance leaves something to be desired but they fill a need to get good quality planes off the table and in the air. And they're such versatile platforms for experimenting and learning.ian1954 wrote:A quick build and it looks like neat work. That is the stage I get to and then ............ stall on finishing.
I have to say that I am anti-the purely slab sided but I watched some snippets of one Windy was building. Can't find the original video that this was extracted from but
Windy Using Aeropoxy Light: https://youtu.be/HE4p_5kMXeg
There is profile and profile! Surprising what a bit of balsa, plywood, aeropoxy and "profiling a profile" can do. It starts some way into the video.
Jim, progress looks good and yup, she is shaping up to be a Ringmaster Jr. Seems your missing a wing spar though. Mine has a spar through those open rectangular holes in your wing ribs.Cribbs74 wrote:Thanks Jim, No fishing here. It's all business. Not sure what is was like where you were, but it's high desert here. Not one lake around. Here is day 3 progress.
George,
I was wondering when someone would catch that. Yes, no spar or should I say rib ripper. The strength of the wing relies more on that solid leading edge. I removed it to save weight and my ribs if it ever gets plowed in. I don't crack up much these days, but everyone does once and a while I suppose. Once covered it will be a strong wing still.
Do you still have the Enya on yours?
I left the Rib Ripper out of the Sterling Yak-9 too. Similar wing, same reason, to hopefully spare added misery if I ever crash it. Most of the guys at Stuka would object, but the Yak has an incredibly strong wing without it. It's a nice strong stick too, I'm not sure if it's spruce or what. It helps that the rest of it is made of baseball bat wood.
Speaking of Stuka, I promised long ago to post when I finished and flew it. I don't recall if I ever did. Better send them the video. I think I'm gonna put one o' them Ring Jr. kits on my Christmas list too. After flying the crap out of the Yak I'm kind of excited about those old designs.
Rusty,
A Jr. flightstreak would be a fun one. I like the Jr Nobler too.
I wasn't able to do anything this evening as I need some finishing supplies and was unable to make the LHS after work.
Tomorrow and Sunday I will be back at it.
I have wanted to build a Jr. Ring for a while as it has subtle features that set it apart from the S-1.
I sure hope this thing starts to get a little more tail heavy as I finish. I chose the Fox as it's the lightest I could think of. I have a .15 schneurle that I would have loved to use, but it's heavier. The Cox .09 will probably be a perfect fit however, I am not sure how well it will draw fuel. I am pretty sure fine thread .09 needles don't exist. I have an .09 Medallion though....
With the backplate pressure tap I think you can use the stock needle. I've heard the TD 09 is a great fit for a Jr. Streak. I don't know, I'm tossing ideas around including the Ring, Streak and my profile Hyper Viper clone. I have a TD 09 and a Thunder Tiger 15 so I can do two juniors. What do they fly on, 50' or so lines? I'll ask my old Florida buddy Fit90 Bob about tapping the 09. He gave me the one I have. 66Malibu Steve gave me the TT 15 brand new.
I must be the only CL modeler in existence that doesn't feel the love when looking at a nobler. I'm weird. Wayne wants to give me one with a B-40 in it.
The Ring is new on my list of wants but I could go full size for that. I'd want to put a Fox 35 on it if I built it. I have an Enya 35 and an OS 35-S that I don't know much about, but have the notes Ken gave me on them. But I like your thinking about a Ring needing to be a Fox powered plane
The idea juggling Rusty.
Rusty, you're not alone. There's just something about the Nobler's lines that turns me off. So I guess we're both weird.
The Eccentric Mark
Ron, the Tee Dee .09 is somewhat funny. It will run on suction with no problems however my statement about funny is in regards to weight. I feel it would work on the laser cut version you have. I have a plane here that utilizes the .09 with a slight and I mean slight difference in wingspan than the JR Ring. Seeing that the Fox is already in the bearer width, would a Tee Dee .09 drop in or would it be too wide? Fly it on .012's. Ken
The Eccentric Mark
The Eccentric Mark
Hahaha, so there we have a picture of "Not Weird."
Thanks for reeling us in Mr. Chapman!
Ken, You may very well be correct about the bearers, good news about the suction though.
The Nobler would (in my opinion) look a lot better if the cockpit was slid forward and the turtle deck profile was tapered down.
Not to hijack Ron's build post, but the B-40 is an exceptional engine. Truly one of my favorites and non existent. I don't feel that we may see anymore of them being produced. If one is available to you I highly encourage you to use it. Rusty, you own the MAX-S, the FP.35, the Fp.40. The B-40 was designed to replace the Max-S .35. The B-40 interchanges with the .40 case LA's, The MAx-S. the Fp.35-.40. It's identical in bolt pattern and nose length. It was a modern engine with a slight bit more power to fly the classic designs. These are made by the same manufacturers that produce the Double Star. The Double Star however essentially had the same footprint as the Fox .35. While the Double Star version was a direct drop in replacement for the Fox .35, it really made the same power thus rendering it not so favorable. Brodak used to sell this engine in a plastic bag. The Brodak .40 however had undergone some changes and many things were taken into consideration.One being AAC construction. A superb design over conventional iron piston engines. Bob Zambelli has the #1 first production Brodak .40 engine and it's still running today. I can't tell you how many flights are on that engine. Everyone in our club has flown that engine several times not to mention the times Bob has used it. Some feel the earlier versions make less power than the newer ones produced. I own a early version and it really is a one flip starting engine. Smooth, extremely light (Weight of a Fox .35) and substantial power over the Fox. I don't use the stock muffler. Ken
Ron, mine is from the original Sterling kit wood (until I crashed it LOL, now has "good quality" balsa in it.) In mine, the leading edge is of fairly soft wood, so spar does add strength. Perhaps in yours, Brodak chose a harder balsa. Regarding splintering wing ribs, when I decided to take out a flight box with it, I ended up making new ribs anyway.Cribbs74 wrote:George, I was wondering when someone would catch that. Yes, no spar or should I say rib ripper. The strength of the wing relies more on that solid leading edge. I removed it to save weight and my ribs if it ever gets plowed in. I don't crack up much these days, but everyone does once and a while I suppose. Once covered it will be a strong wing still.
I put the OS .15FP-S back on it, but am replacing with Fox .15X. The OS FP and Enya III share the same bolt pattern, they are close enough I didn't drill any new holes. I'll probably end up plugging existing with 1/8" dowel and redrilling new for the Fox .15X. I was surprised how strong the Enya .15-III is, had same lap times on a Masters 8x6 prop as I did with the OS .15FP-S with 8x4 prop.Do you still have the Enya on yours? Ron
» First Baby Ringmaster build
» Brodak Ringmaster S-1 build
» Baby Ringmaster build (Maiden flight report!)
» Simple Baby Ringmaster build
» Baby Ringmaster build thread.
Page 1 of 4
