Info for Glo Bee tachometer Cox_ba12
by Jerry Today at 7:35 pm
by cmulder Today at 6:40 pm
by cmulder Today at 6:36 pm
by cmulder Today at 4:52 pm
by 706jim Today at 2:47 pm
» Cox Sure Starter
by roddie Today at 12:50 pm
» Cox works tuned engines
by Yabby Yesterday at 4:58 pm
» Half A Starter Question
by SABOO Yesterday at 1:06 pm
Info for Glo Bee tachometer Empty
Info for Glo Bee tachometer Empty Info for Glo Bee tachometer
Post  jorigger Thu Jul 18, 2013 5:17 am
Hello Guys,
i need of buy one tachometer.
This Glo Bee is the best in the market ?
Thanks
Giuseppe - Italy
jorigger
jorigger
Info for Glo Bee tachometer Empty Re: Info for Glo Bee tachometer
Post  Kim Thu Jul 18, 2013 9:06 am
Not sure if all would agree that it is the best, but I've used one for 5 years now, and it is still running fine. I like it because it's easy to hold on to with oily hands. The small REAL inexpensive one from China works fine also.
Like so many things in this hobby, it depends on your personal preferences...
And...by the way...Welcome to the Forum !!!
Post  jorigger Thu Jul 18, 2013 9:17 am
Kim wrote:Not sure if all would agree that it is the best, but I've used one for 5 years now, and it is still running fine.  I like it because it's easy to hold on to with oily hands.  The small REAL inexpensive one from China works fine also.
Hi Kim, thank you very much for this you reply with you informations and and also for the Welcome.
Regards
Giuseppe - Italy
Last edited by Admin on Thu Jul 18, 2013 11:25 am; edited 1 time in total (Reason for editing : fixed quote tags)
jorigger
jorigger
Info for Glo Bee tachometer Empty Re: info on Glo Bee Tachometer
Post  JayeLK Thu Jul 18, 2013 10:56 am
I bought a Magnum Digital Mini-Tach.  It seems to be best at telling me the RPM of the florescent light in the garage.
It was the only one the Local shop had. It works OK, but, having never used another type, I can't really say it is any worse or better than any other, either.
If you take a few precautions, it does the job.  It only gives RPMx100, and needs to be used outdoors or with a constant good light source behind the prop.  It also seems to work best the closer you place it to the prop hub.  Other than that, it is good.
Jaye
JayeLK
JayeLK
Moderate Poster
Moderate Poster
Post  jorigger Thu Jul 18, 2013 11:38 am
JayeLK wrote:I bought a Magnum Digital Mini-Tach.  It seems to be best at telling me the RPM of the florescent light in the garage.
Jaye
Hi Jaye, thank you for this information. I don't know this Magnum, but i want find in internet.
Thanks and Regards
Giuseppe - Italy
jorigger
jorigger
Post  dinsdale Fri Jul 19, 2013 6:39 am
Jaye
Rpm x 100 is fine. That's probably about as good as an el cheapo will measure anyway. They all need a non-fluorescent light source.
dinsdale
dinsdale
Account Deactivated by Owner
Post  Kim Fri Jul 19, 2013 7:03 am
Yeah, for all practical purposes, 100 rpm increments pretty well get the job done.  The Glo-Bee has 10rpm measurements, but they jump all over the place when in use, and I only use them if I've got two engines running nose-to-nose in the Tach Race.
Got this Ebay Tee Dee yesterday, and hit it with the Glo-Bee early this morning.  Looks like it ought to be a good runner!
Info for Glo Bee tachometer Sam_4515
Post  jorigger Fri Jul 19, 2013 7:18 am
Kim wrote:Yeah, for all practical purposes, 100 rpm increments pretty well get the job done.  The Glo-Bee has 10rpm measurements, but they jump all over the place when in use, and I only use them if I've got two engines running nose-to-nose in the Tach Race.
Thank you very much for this comunication.
Regards
Giuseppe - Italy
jorigger
jorigger
