Static discharge associated with C/L handles/flying Cox_ba12
by Goozgog Today at 8:56 am
by GallopingGhostler Today at 12:32 am
by sosam117 Yesterday at 2:35 pm
» Audie Murphy's wife Pamela
by GallopingGhostler Yesterday at 12:25 pm
by getback Yesterday at 10:59 am
by 944_Jim Yesterday at 9:46 am
by getback Yesterday at 5:56 am
» 400ft altitude
by GallopingGhostler Yesterday at 1:25 am
» Unknown cylinder
by Cox International Fri Mar 24, 2023 4:45 pm
» Odd Size Machine Screws
by GallopingGhostler Fri Mar 24, 2023 10:18 am
by MauricioB Fri Mar 24, 2023 8:34 am
Static discharge associated with C/L handles/flying Empty
Static discharge associated with C/L handles/flying Empty Static discharge associated with C/L handles/flying
Post  roddie Tue Sep 24, 2013 7:55 pm
Here's a GOOD read... I searched CEF and didn't find anything on this. We all should know NOT to fly in the vicinity of elec. power lines... but you can still get zapped from atmospheric electrical discharges... even if the weather isn't "immediately" or "noticeably" threatening...
http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=103&topic_id=385707&mesg_id=385707&page=
Static discharge associated with C/L handles/flying Empty Re: Static discharge associated with C/L handles/flying
Post  RknRusty Tue Sep 24, 2013 9:03 pm
roddie wrote:Here's a GOOD read... I searched CEF and didn't find anything on this. We all should know NOT to fly in the vicinity of elec. power lines... but you can still get zapped from atmospheric electrical discharges... even if the weather isn't "immediately" or "noticeably" threatening...
I read that some time back. I was surprised so many people had experienced being shocked. And most said it was in humid conditions, just the opposite of what I would have guessed. My Sullivan Insta-Just handle has enough metal in it to be susceptible. It'll probably happen to me while I'm flying in my upcoming contest.
Post  roddie Tue Sep 24, 2013 9:11 pm
Don't even "think" that Rusty....Shocked
Post  Cribbs74 Tue Sep 24, 2013 10:42 pm
Never even considered that. I'll let you know if it's true! lol!
Just kidding... Thanks for the info Roddie.
Static discharge associated with C/L handles/flying Empty Re: Static Discharge
Post  JayeLK Wed Sep 25, 2013 2:08 am
It used to happen to me all the time flying in Denver on summer afternoons.  The thunderstorms would roll in and you knew it was time to stop for the day when you pulled into a wingover and got zapped through the adjustment loop on the back of my EZjust handle.  Spent the rest of the tank flying level as close to the ground as possible holding onto the handle by your fingertips with your wrist at a ninety degree angle to get your palm as far away from the cables as possible.  Then packed up and got out of the park as fast as we could.
The storms didn't even have to be visible as clouds in sight.  Just the build up in the afternoon was enough.
The voltage gradient in the air can reach very high numbers, as much as several hundred volts per inch.  Think about having even fifty volts per inch and sixty foot lines, that's 36KV between your plane and you at the top of a wingover.  Breakdown of dry air is on the order of thirty KV per cm, so you can easily get a shock from those metal cables.
There was an article in some magazine of the time that took advantage of this gradient.  They had designed sensors for the wing tips and tail that measured the gradient and used it as an autopilot to keep an RC plane level, well at least level compared to the atmospheric gradient.
Jaye
JayeLK
JayeLK
Moderate Poster
Moderate Poster
