Horizontal Propeller For Landing Babe_b10
June-2019
robot797's
"cox 049 gasoline"
Speed Contest 2019
The Traveling Prop
Horizontal Propeller For Landing Empty
World of Aviation
Horizontal Propeller For Landing Empty Horizontal Propeller For Landing
Post  NEW222 on Fri Jan 17, 2014 10:39 pm
Sorry for the stupid question, but I was wondering the way to get the propeller to stop at a horizontal position while landing a plane without gear. I do have quite a bit of time before flying season, but wanted to know. I know there is a simple way to do it, but cannot remember. I have searched online and read that the propeller should be horizontal while at T.D.C., then another post as it was nearing T.D.C.. Thank you.
View user profile
Horizontal Propeller For Landing Empty Re: Horizontal Propeller For Landing
Post  Cribbs74 on Fri Jan 17, 2014 10:46 pm
Don't over think it.
When the engine is static, coming up to TDC as in you just feel the compression starting lock the prop down.
Basically when the engine quits the prop will stop as it tries to go through another compression stroke.
Don't feel stupid, I did it wrong for over a year before I was shown how to do it properly.
Trusted Seller
View user profile
Post  Mark Boesen on Fri Jan 17, 2014 11:26 pm
You should do this for all planes landing gear or not, even trike gear, it will save help save props on a hard deadstick.
It's also a great way to balance out a non-balanced prop (side mount engine only) if plane seems to shake more then normal rotate prop 180, as this can also be an effective additional counter balance.
Rotate prop clockwise until you feel piston start to compress, loosen prop nut and readjust prop horizontal, slightly tighten and check, re-adjust if needed and retighten.
Post  balogh on Sat Jan 18, 2014 2:28 am
Is it not rather counter-clockwise i.e. the same direction the headwind will turn the prop after the engine stops?
View user profile
Post  Mark Boesen on Sat Jan 18, 2014 9:18 am
Lol, I guess it would depend on how you looked at it. When looking at it from the front or face the prop rotation for a right hand prop is counterclockwise and I think that's the way most describe it.
But you're correct, if you're in the cockpit it would be clockwise. Likewise if the left front tire was flat on your car, that would be from the drivers (North American) perspective.
So lets just say you'd move prop the opposite of normal rotation up to the compression.
Post  ian1954 on Sat Jan 18, 2014 12:09 pm
What a confusing thread!
For those of us who speak English - substitute "antiiclockwise" for "counterclockwise".
ian1954
ian1954
View user profile
Post  dckrsn on Sat Jan 18, 2014 1:32 pm
ian1954 wrote:What a confusing thread!
I have nothing against clockwise.  Cool
View user profile
Post  ian1954 on Sat Jan 18, 2014 1:46 pm
Neither do I. It is definitely a good film (movie?)
Horizontal Propeller For Landing Clockw10
ian1954
ian1954
View user profile
Post  balogh on Sat Jan 18, 2014 2:25 pm
For those of you who speak English, please refer to this link:http://www.thefreedictionary.com/counterclockwise
View user profile
Post  Cribbs74 on Sat Jan 18, 2014 2:29 pm
Well, it stars John Cleese so it has to be good!
Trusted Seller
View user profile
Post  NEW222 on Thu Jan 23, 2014 8:23 pm
Thank you for the help and replies.
View user profile
