Propellor Performance Question Cox_ba12
» 400ft altitude
» Unknown cylinder
by Kim Yesterday at 11:15 am
» Odd Size Machine Screws
Propellor Performance Question Empty
Propellor Performance Question Empty Propellor Performance Question
Post  anm2 Sun Jan 19, 2014 8:09 pm
I understand propellor pitch, however, I do not understand the impact of propellor pitch and propellor size on engine performance and flight. Can anyone explain the advantage of using a larger prop as it pertains to flight performance? For example, if I were to use an engine swinging a 7X4 propellor at 1200 RPM how would my flight performance differ from the same engine swinging a 4X2 Propellor at 22K RPM? Does the larger prop and pitch provide more power to lift a heavier model? Thanks, Andy
anm2
Propellor Performance Question Empty Re: Propellor Performance Question
Post  pkrankow Sun Jan 19, 2014 8:46 pm
OK, you can visit the Master Airscrew site for more detail...
http://masterairscrew.com/
I'll try to be brief and hit the high points.
Pitch is the theoretical distance the propeller will travel if it doesn't slip in one complete revolution.
Diameter is measured to the circle the propeller tips theoretically trace out.
For a 2 blade propeller this is the length through the hub of the prop from tip to tip.  For a 1 blade it is theoretical, and for more than 2 blades it is just harder to measure.
If you do some simple area math (geometry) on a propeller, you find that diameter increase will increase the circle of air that is moved.  If a larger circle of air is moved the more thrust is generated, so a larger propeller may provide more thrust at a given RPM.
Pitch at a given RPM will translate to a theoretical maximum speed which the airplane will not exceed because once the propeller is traveling the pitch distance in the air it will resist moving faster, ie: farther per revolution than the pitch, per rpm.
With an IC engine diameter will change the RPM the engine operates at due to flywheel effects.
With an electric motor the motor/esc will attempt to maintain the set RPM.  In a properly set up electric driveline the RPM on the ground will be the same as in the air at a given throttle setting.
Now a little mind blowing thought:
With small IC engines that operate at very high RPM reving the engine up with a small prop ends up producing more thrust than running a large prop.  At a certain size (about .09?) the engine operating RPM is lower due to larger prop sizes SO increasing diameter will have less effect on RPM SO increasing diameter can dramatically increase thrust because the thrust lost to RPM loss is less than the thrust gained from more area swept per RPM.
This is a whole lot of not easy to wrap a brain around.
Post  anm2 Sun Jan 19, 2014 9:01 pm
"With small IC engines that operate at very high RPM reving the engine up with a small prop ends up producing more thrust than running a large prop.  At a certain size (about .09?) the engine operating RPM is lower due to larger prop sizes SO increasing diameter will have less effect on RPM SO increasing diameter can dramatically increase thrust because the thrust lost to RPM loss is less than the thrust gained from more area swept per RPM."
The response I pulled out in quotes gets to my question. So with an .049 engine, the RPM loss due to propellor size actually decreases thrust. So why would someone use an 8X4 propellor on a Texaco Engine? How would that be better than an 5X3 Propellor? I have actually read that a texaco engine with an 8X4 propellor only does about 9000 RPM or less. Are they doing that only to decrease fuel consumption? Thanks, Andy
anm2
Post  andrew Sun Jan 19, 2014 9:22 pm
You're correct, the Texaco engines are slowed down to lower fuel consumption.
The guys have given you a good explanation of diameter vs pitch. Phil hit the nail on the head WRT to diameter. A quick calculation shows that a 5" prop has ~ 56% more disk area than a 4" prop; a 6" prop has 44% more disk area than a 5" prop and a 7" prop is 36% larger than a 6" prop. These percentages convert roughly to the volume of air being moved when comparing diameters.
The load imposed on an engine is significantly greater as we increase diameter, consequently to realize higher rpms, we either need to reduce the diameter for a given pitch or find a more powerful engine. That's on the pulling side.
The big killer is parasitic drag -- parasitic drag increases roughly with the square of the airspeed, so it takes more than twice as much power to go twice as fast. Conversely, a 6x4 turning 15K will not give twice the speed of a 6x2 @ 15K. To continue to drive your speed up, you'll need to find increasingly higher rpm and/or move to a larger diameter (to shove a greater volume of air) in order to overcome the the greater drag.
Static thrust measured on a stand will help with comparing props and engines, but without adjusting for drag, you cannot make a straight jump to aircraft performance.
Post  RknRusty Sun Jan 19, 2014 9:40 pm
Three greenies given out. To Phil and Andrew for compiling an eloquent answer that clearly explained it, and saving me from a brain hemorrhage while trying to come up with answers that wouldn't have been as elegantly to the point. Also for the comparison between the effects on an IC as compared to an electric. And a greenie to Andy for grasping the concepts right off the bat.
I boldly thought I knew so much about the effects of props from flying 1/2A. But when I started flying CLPS with bigger engines, not running at full scream, I was suddenly confused again and could predict nothing when trying different props, pitches and diameters. And have only recently(I'm slow on the uptake) realized the differences fixed RPM electrics offer.
Post  anm2 Mon Jan 20, 2014 5:51 am
Thanks for everyone's response. The last question I have concerns .049 diesels. Is there an advantage to using a .049 diesel? Realizing that diesel provides greater torque allowing you to put a larger prop on the engine without the corresponding drop in RPM. Does it change the flight characteristics at all using a diesel with a large prop with less RPM vice a glow engine spinning a small prop at high RPM? This assumes that both are creating the same amount of thrust. Thanks, Andy
anm2
Post  pkrankow Mon Jan 20, 2014 7:19 am
Diesel is a more energy-dense fuel than alcohol, so when running at the proper RPM more torque is generates using less volume of fuel. Diesel also burns slower than alcohol so the peak of the power band is at a lower rpm.
While I have messed with diesel some, I have not had reliable performance.
Post  balogh Mon Jan 20, 2014 7:58 am
"......Now a little mind blowing thought:
Phil"
If you want to achieve the highest flight speed you must select the propeller dia/pitch combination that allows the engine to run at its rpm where the highest engine output is generated. Too large dia/pitch prop will cause the engine to run below, too small dia/pitch prop will cause the engine to run above the rpm where the engine power is maximum.
Refer to the performance charts on this site (click on Performance on the left): http://www.mh-aerotools.de/airfoils/cox_frameset.htm
(The engine output required to pull a plane at a given speed is proportional to the third power of speed)
Post  Surfer_kris Mon Jan 20, 2014 7:59 am
Diesel engines are better in many aspects. You get a much higher thrust (at low speeds) compared to the high revving glow engines on small props. The reliability is much higher too, a good diesel engine never quits in the air, it may hit and miss but it rarely stops suddenly like a glow engine can do.
For a good reliability you need a good diesel engine of course. The "conversion heads" with teflon seals have nothing to do with the proper stuff. Wink
The down side with diesels is that fuels are hard to come by, and the exhaust residue has a "scent" that only a mother can like...
Surfer_kris
Surfer_kris
Post  ian1954 Mon Jan 20, 2014 10:31 am
When a diesel is set up correctly, PAWs in particular, Oliver Tigers (very expensive) - they are first flick starters and very, very reliable. I have used these in combat, team race and stunt. (Many years ago)
However, they are not very flexible with RC throttles. Works but not as wide ranging or responsive as a glow.
The fuel smells wonderful - the oily residue lingers on your clothes for days - a constant reminder.
Persistante extraordinairement parfum - l'un des plus agréables odeurs dans le monde!
There is a knack to getting it right and making the most of the relationship between the needle valve and the compression screw. The settings for cold starting and running when warmed up are different.
ian1954
ian1954
