» Zoomslot Saucer by Levent Suberk Today at 2:08 pm
by andrew Today at 11:17 am
by akjgardner Today at 10:38 am
by 944_Jim Today at 9:27 am
by rsv1cox Today at 9:11 am
by Kim Sun Sep 24, 2023 6:29 pm
Veco .19 with T.C.C.
Re: Veco .19 with T.C.C.
Gotta have some of that TCC... what is that?
Temperature Controlled Clearance
Whatever that is supposed to be!
Lol yeah what is TCC?
Totally Chromed Cylinder?
Edit: nevermind, I see now
Probably an early fancy term for ABC/ABN fits. Such as when the P/C has a tight pinch when cold, and a perfect fit when hot. Or maybe visa versa. Is the Veco an ABC?
Close but no cigar!RknRusty wrote:Probably an early fancy term for ABC/ABN fits. Such as when the P/C has a tight pinch when cold, and a perfect fit when hot. Or maybe visa versa. Is the Veco an ABC?
Temperature Controlled Clearance (TCC) was WAY before ABC/ABN. It was an advertising gimmick for a tapered cylinder. By adding taper, the fit was more loose except near the top of the stroke which helped it run cooler. I believe someone tested it by running the engine on a flywheel right out of the box...it did not overheat. Other engines started using either a tapered piston or a tapered cylinder but VECO had already captured the spotlight with TCC. If I remember correctly, this started in early/mid fifties.
gcb- Platinum Member
Thank you George - a fine answer!
I always wondered if developments like tapering cylinders and pistons were planned or discovered by accident.
» Veco .35/.35C
» Veco 19 RC
» Veco 1 3/4" Wheels
» Various Cox Engines In VECO GP -19 Box
» The Bipe has arrived. Thanks Roger....
» Veco 19 RC
