» Enya .09 II Questions
» Testers Sprite engine swap
» Post edit??
Bought a Comanche, but as it is 50 years old, needs a little TLC
Just as the thread title says, I need to reglue the fuselage studs, and wonder how to have the screws bite into the plastic without freezing on.
I need a rear elevator as the one on it is missing a tab, possibly can make one and glue it on the same way Jay Mendoza suggests.
New tires, as the ones on are fossilized, and a nice clean up of the plane. What products are best? It has a lovely patina, so that stays.
The engine is frozen with the piston on the UP position. Tips?
swift53- Moderate Poster
Re: Bought a Comanche, but as it is 50 years old, needs a little TLC
Tips on the tight engine. Just heard about this one, less messey than the green anti freeze soak. they said to put engine in a plastic zip-lock bad and put it in a pot of boiling water to heat up the old castor. I guess you would remove the baggie and carefully remove the engine (USE GLOVES) and squirt a few drops of Nitro Fuel on the cylinder slots and see if it loosens up. I'd use the antifreeze soak if the engine is really covered in old castor( ran hard and put away wet) I have, on a mildly castor coated engine, just used a Hair dryer (monocoat gun). Hold the engine in a gloved hand, hold nozzle of hairdryer right on the cylinder, rotating back and forth under High heat until you smell the castor, then set the dryer down and attempt to rotate the prop, very very carefully. If there is resistance, go back and add some oil or fuel to cylinder slots and heat it up again. Once it "breaks free" splash more fuel or oil on piston and flip or spin prop till its smooth. ( My 2 Cents) If you want to get it to run, you really need to clean it up, inside and out, you'll be surprised at the gunk inside an old engine
Larry Renger wrote a very good article on the care and feeding of 049's, located here: http://www.mccookfieldfac.com/helpful-info/cox-engines.pdf
it is the linc at the very bottom of the page for "Instruction Sheets" on the Left hand column.
Last edited by Marleysky on Thu Nov 09, 2017 10:07 pm; edited 1 time in total (Reason for editing : linc location)
Great tips! The engine loosened up with the hair dryer. Has very nice compression.
I am having a bit of difficulty opening the rear of the crankcase
Don't want to force and damage...Once open, how is the inside cleaned?
Thank you.
Regards, Alberto
Thank you.
Regards, Alberto
Alberto
There shouldn't be any problems getting the rear open. Should just be a matter of removing the four screws and it should come right off, either tank or backplate. Will probably just be stuck on the gasket. As for cleaning, if it doesn't look too bad just flush it with a little fuel or alcohol. Automotive carb cleaner is good too, although a little harsh, expecially if used in place of the alcohol.
It is not held by four screws, it is screwed on just like the cylinder...it's a 1.5
Hair dryer?
Regards, Alberto
Hair dryer?
Regards, Alberto
Ah, so you have the Comanche .15. That's a Sportsman 15 engine isn't it? I was thinking of the .049 version.
Yes, it is a Sportsman 1.5.
[quote="swift53"]It is not held by four screws, it is screwed on just like the cylinder...it's a 1.5
Hair dryer?
Regards, Alberto[/quote
Here’s the instruction sheet: https://dbabd7f0-a-62cb3a1a-s-sites.googlegroups.com/site/nitroengine/Cox%20Sportsman%2015.PDF?attachauth=ANoY7cqt77vvlaEp0kajTuK2NTpL7M-wtXMySYAD_DGwDlombhWEIxqa5GiJc9DoZzawY-CrdcTlv1Ivz9jHLpkjXQ7rvi_uP3mbfGYnQQyZ5wP9tFswgaBeI8-OfzbAK0WklVUFTW7nbKz4_HQm7Zo0lALgslPXOPoYHmSmhJbKZnoTKFT85LqUFpW8P9tlv6in8Nkw_rJWRanrnmbKLdYVBisa6AbZKQ%3D%3D&attredirects=0
Looks to me like that “rear intake” cover is threaded into the crankcase. So, yes, a little heat will help loosen any built up castor oil varnish.
Hair dryer?
Great instruction sheet!
Thank you
Regards, Alberto
Thank you
Regards, Alberto
Big Comanche tips
I just scored one on Ebay myself. My engine was frozen up as well.
I dismantled the engine the best I could. The hardest part is removing the reed valve assembly. If you don't have a cox spanner for this you will end up nicking the aluminum as I did. No big deal if you do, as you cant see it once installed in the plane.
I got mine off by clamping the engine mounting lug very tightly in a bench vise to secure the engine from moving. I then too channel locks to the reed valve assembly and squeezed very hard while slowly applying torque to remove the assembly. Lefty Loosy.
Couldnt hurt to heat up the engine with a heat gun or liberal use of a torch.
Once you have that off its all down hill.
You can then submerge the engine in Lacquer Thinner over night. Once its had a good soak I then used some penetration oil on the cylinder (glow head off) and let that sit over night. After that was complete I installed an old propeller and turned it by hand to free up the cylinder. It worked.
The other parts need to soak in the thinner for a while to break up the oil. Use a sewing pin to clear the fuel jets on the venturi. I just test ran mine yesterday. It is LOUD. Also bit my finger. I can see why they stayed with the smaller engines after this guy.
My plane has a broken / missing vertical stabilizer so I'm going to make one from polystyrene sheet.
Madguns- Bronze Member
That is Very special the engine from database ... Sportsman .15 (2.5 cm³)
Manufactured in 1958-1965 (#110)
This engine is similar to the Olympic, but has plain bearings, which resulted in a lower price ($7.98 in 1658, to be exact). The aluminum parts were not colorfully anodized as its stronger brother, the Olympic. Again, Dale Kirn was responsible for the design of this engine which followed the Space Hopper and Olympic design philosophy.
The engine was also used as a product engine in the beautiful "Big Comanche" C/L model. This was the only .15 powered ready to fly C/L model Cox ever manufactured. Here, the engine was equipped with a longer needle valve and a spinne >>>> http://www.mh-aerotools.de/airfoils/cox_frameset.htm Nice !!
Mudhen- Gold Member
I think we have something going on. Comanches are great airplanes, there ought to be a section started
that focuses only on these models.
We can share modifications, solution to damaged parts, etc.
Possibly a new thread?
Regards, Alberto
Regards, Alberto
Some photos...
dang, don't know how to on this site. Please help!
Thank you
Thank you
here you go Swift52... https://www.coxengineforum.com/t8191-posting-pics?highlight=how+to+post+photos+on+cef Us the search Box..
