by roddie Today at 1:39 pm
by roddie Today at 1:08 pm
by latole Today at 9:36 am
» Indexing COX cylinders
by Yabby Today at 7:47 am
by Yabby Today at 6:33 am
» 1/2a Skyray plans?
» Postage stamp backplates
» Parts Cox TD-4
My new addition "Red Arrow"
TDbandit- Platinum Member
Re: My new addition "Red Arrow"
It definitely looks nice.. but I don't see any fuel-fill/vent nipples.. Is that a photo from Matt's site.. or is that your engine?
It's mine just got it in, hasn't had a drop of fuel put through it yet and the fuel nipple and vent are on the other side of the needle sorry I should of turned the engine around. I put it on a white background to get the colors to show up better and didn't realize that this pic closely resembled the one on his site sorry for the confusion (Bandit)roddie wrote:It definitely looks nice.. but I don't see any fuel-fill/vent nipples.. Is that a photo from Matt's site.. or is that your engine?
Last edited by TDbandit on Thu Dec 18, 2014 6:06 pm; edited 1 time in total (Reason for editing : origion confusion)
LOOKS Nice Bandit ! Should do you a good job // I put an engine together the other night and it had too many inlets Have fun with it !! getback
Nice engine. I just checked Matt's site, and
it looks like you got the last one.
Enjoy!
Enjoy!
dckrsn- Diamond Member
"Nods" Hopefully he'll make more. if this one does well I wouldn't mind to get another one. (Bandit)dckrsn wrote:Nice engine. I just checked Matt's site, and
Enjoy!
Bandit.
Is the "Red Arrow" a high performance unit or does it just run standard gear? It looks as if it has open exhaust ports from what I can make out, so what cylinder does it run? Is it one of those that has been modified for SPI?
I haven't run it yet so I don't have any figures on it performance wise but it has a #1 cylinder with SPI, standard compression head though. I'll have some figures on it as soon as my test stand comes in and I get it broken-in (Bandit)Oldenginerod wrote:Bandit.
Rod, I was wondering the same thing. I compared engines on Matt's website. It says it has a #1 cylinder which would be a pre-96 BW. It also says it has SPI, so it must be a NOS Cox cylinder with a standard long skirted piston. The RPM rating is up to 17.5k.Oldenginerod wrote:Bandit.
http://www.exmodelengines.com/product.php?productid=17877&cat=279&page=1
Then on the same page he has the Taipan Serpent, and it has a new Tee Dee cylinder converted from a Surestart, open exhaust and lowered ports for SPI with a standard piston. Also has the stunt tank, Merlin head and Killer Bee crankshaft. The RPM rating is up to 20k.
http://www.exmodelengines.com/product.php?productid=17872&cat=279&page=1
Maybe the limited availability of NOS #1 cylinders is the reason it's out of stock now. But he does have NOS #1s in stock for $14.95.
http://www.exmodelengines.com/product.php?productid=17775&cat=267&page=1
That's my best guess on it.
And the Bandit posted while I was writing this. In any case, I like it. For the price I would choose it over the Serpent, plug the vent for inverted flying and add a merlin head. It should compete closely with the Serpent, if not outrun it. You just have to use a needle on the syringe to fill the tank with a plugged vent.
After you mentioned this, I took a closer look at the engine and you are correct it has a stamped #1 BW cylinder. I have a few OEM TD heads so once I get er boken-in I'm going to try one and do an RPM pull on it and see what it does compared to the standard one. This is gonna be interesting and sorry for breaking in front of ya. (Bandit)RknRusty wrote:Rod, I was wondering the same thing. I compared engines on Matt's website. It says it has a #1 cylinder which would be a pre-96 BW. It also says it has SPI, so it must be a NOS Cox cylinder with a standard long skirted piston. The RPM rating is up to 17.5k.Oldenginerod wrote:Bandit.
» Three new addition
» New addition!
» First tach of my Red Arrow .049
» cox turbo arrow 3
» My Toy Bow & Arrow Set Hot Wire Cutter
» New addition!
» cox turbo arrow 3
