Plane size for MCcoy 098  Cox_ba12
Plane size for MCcoy 098  Pixel
by fargophil Today at 9:21 am
» New Space Bug From Parts
by getback Today at 8:24 am
» Me or the tree
by rsv1cox Today at 7:05 am
» Who want´s it ?.
by fredvon4 Today at 6:33 am
by Admin Yesterday at 7:16 pm
» 200,000 Posts!
by Admin Yesterday at 7:13 pm
» BJMR Twin Lizzie
by fredvon4 Yesterday at 6:50 pm
» Cox chrome chassis
by fredvon4 Yesterday at 6:41 pm
» Wen Mac P-38 on Ebay: So, it didn't get to $1000, But Close
by rsv1cox Yesterday at 5:14 pm
» Wen Mac Lotus - dusty but not ran
by rsv1cox Yesterday at 10:13 am
by fredvon4 Mon Nov 29, 2021 6:23 pm
» Uncle Wayne
by ChaseBanner Mon Nov 29, 2021 9:35 am
November-2021
MauricioB's
".049 Babe Bee "in action""
Forum Store
CEF Ear Savers
Plane size for MCcoy 098  Empty
Thinking Plane size for MCcoy 098
Post  getback Mon Jan 05, 2015 11:45 am
I posted before that I had one of these / Well I ran it yesterday and was getting 12.000 rpm on a 7X4 top flite prop 25% sig fuel , It starts easy and I just kindy like the noise it makes ! So what plane would be a good subject for it ? ( stunt Cl of coarse ) Here is a pic ...  Plane size for MCcoy 098  Wp_20110  Plane size for MCcoy 098  Wp_20111  Thanks , Getback Huh...
2019 Supporter
2020 Supporter
Thinking Re: Plane size for MCcoy 098
Post  706jim Mon Jan 05, 2015 11:35 pm
Why Stuntman 23 of course!
706jim
706jim
Post  Mark Boesen Mon Jan 05, 2015 11:59 pm
Post  GallopingGhostler Tue Jan 06, 2015 1:04 am
Post  gcb Tue Jan 06, 2015 3:28 am
@getback wrote:I posted before that I had one of these / Well I ran it yesterday and was getting 12.000 rpm on a 7X4 top flite prop 25% sig fuel , It starts easy and I just kindy like the noise it makes ! So what plane would be a good subject for it ? ( stunt Cl of coarse )
 Thanks , Getback
The only plane that pops up is Walt Hughes' "Little Missle". That plan shows the McCoy .098 in it.
The landing gear consists of a "belly wheel". Per OTS rules you can extend it to get ground clearance but it is supposed to be in the same position, I believe. The plane itself is a swept wing with twin rudders.  Tom Dixon has plans.
gcb
gcb
Post  roddie Tue Jan 06, 2015 8:52 am
Hi Eric, I couldn't find a plan for this.. but Brodak has the kit. It's the "Circus Prince".. a 26.75" span profile stunter for .09/.25 glow power. It features a built-up wing with laser-cut ribs and 1/2" fuse. Personally.. I think it's a bit small for a .25  Shocked  but if you've got other .09's or .15's... it gives you some options for different power combos to mess with.
Plane size for MCcoy 098  Circus12
http://brodak.com/circus-prince-kit.html
Post  getback Tue Jan 06, 2015 5:11 pm
2019 Supporter
2020 Supporter
Post  getback Tue Jan 06, 2015 5:42 pm
The baby clown I have the all American is in my Q The 23 is too small for this engine and I have one with a medallion on it , The Circus Prince don't sound right and $$$ I like the Rascal but I don't see the rib configuration so how do you know what to make the ribs size to?? I have seen this on a few models and just stay away cause I don't know ??Mad Would like to see the 99 Or I will go with the All American Smile Eric Thanks U All !!
2019 Supporter
2020 Supporter
Post  roddie Tue Jan 06, 2015 6:10 pm
@getback wrote: I like the Rascal  but I don't see the rib configuration so how do you know what to make the ribs size to?? I have seen this on a few models and just stay away cause I don't know ??
Eric, Look at the Rascal drawing again. You can see the separate rib profile which is also the same in the side-view.. so that's all you'd need to go by. They're all the same size by the looks of it. If the plan is full-size.. just trace it and make a template.
Plane size for MCcoy 098  4718-a10
Post  GallopingGhostler Tue Jan 06, 2015 6:27 pm
@getback wrote:
I cant get the 99 Stuntliner to download , insufficient data ??
PM me your E-mail address and I'll E-mail it to you.
@getback wrote:I like the Rascal but I don't see the rib configuration so how do you know what to make the ribs size to?? I have seen this on a few models and just stay away cause I don't know?? Mad [/list]
Roddie's reply came in while I was typing this and is spot on. Rascal rib pattern is shown below the right wing tip. All ribs are the same, trim W1 to fit 1/16" plank at wing root. You can eliminate the leadout holes for the right side wing ribs. Ribs are 1/16" sheet. Trailing edge is very simple, of 1/8" sheet balsa. You just round the back side and that's it.
If you can't download a copy, PM me and I'll E-mail it to you.
Post  706jim Tue Jan 06, 2015 7:15 pm
@roddie wrote:Hi Eric, I couldn't find a plan for this.. but Brodak has the kit. It's the "Circus Prince".. a 26.75" span profile stunter for .09/.25 glow power. It features a built-up wing with laser-cut ribs and 1/2" fuse. Personally.. I think it's a bit small for a .25  Shocked  but if you've got other .09's or .15's... it gives you some options for different power combos to mess with.
DON'T try to fly the Circus Prince with that McCoy 0.09.
It will be terribly underpowered; at least that's what I found when I tried to fly mine with the Fox "Rocket 0.09".
Installing the Fox "15" really woke this plane up (same mounting bolt pattern as the 0.09) and "PDQ" suggested that it would be a rocket with a 29.
But not an 0.09.
706jim
706jim
Post  GallopingGhostler Tue Jan 06, 2015 9:22 pm
Eric, here's an engine test on your engine, also known as the 1950 Duromatic McCoy "9".
http://www.sceptreflight.net/Model%20Engine%20Tests/McCoy%209.html
Doesn't give horsepower figures, but they got between 11,000 to 12,000 RPM depended on which 7x4 prop make and fuel used. Tests were done without proper break in.
The Debolt All American at 140 square inches wing area is a perfect match, as it lists the McCoy "9" on the plans.
I looked at the specs on the Circus Prince, it has 200 square inches wing area, wow! Shocked No wonder why it flies well on a Fox .15 Cool That is the same wing area as my 30" wingspan Ringmaster Jr.  Smile
Post  Mark Boesen Tue Jan 06, 2015 10:40 pm
I love the Outer-zone web site, i was on it last night for a while. I also agree with the All-American, cool little plane, classic design, would be an easy build and should fly great!
Post  getback Wed Jan 07, 2015 4:28 pm
Thanks For the link Mark ....But I still cant get a download don't know why the others are no problem .
2019 Supporter
2020 Supporter
Post  GallopingGhostler Mon Jan 12, 2015 11:19 pm
Eric, yesterday I E-mailed you the plan, plus PDF printout of the Outerzone description page and a tiled version for 8-1/2 x 11 paper. Did you receive it? - George
Post  getback Tue Jan 13, 2015 7:38 am
No I did not George , But my computer friend came by yesterday and got it for me , I tried scaling it this morn. and at 24" WS it is impossible to read and the lines are jacked real bad and I still need 2 more inches .                                                       Plane size for MCcoy 098  Wp_20113    Well it came out upside down but you can see and I think the center of wing is at #12 on the rule ??? Eric
2019 Supporter
2020 Supporter
Post  GallopingGhostler Tue Jan 13, 2015 8:02 am
Please check your E-mail's spam folder. It may be there.
Post Note: I re-sent the E-mail with this time only the All American plan attached. Previously I had a PDF printout of the Outerzone description page and a tiled printout for standard printer paper. Eric, please let me know if you received this, and please check your spam folder if you don't see it. Also, the plan on my computer is very clear, provides a very clear printout, so it looks like something may be borked on your computer. - George
Last edited by GallopingGhostler on Tue Jan 13, 2015 8:10 am; edited 3 times in total (Reason for editing : Added additional comment.)
