» STUKA bomb dimentions neededby Gordinir8 Today at 5:23 am
» Indexing COX cylinders
by balogh Today at 1:10 am
» 1/2a Skyray plans?
» Postage stamp backplates
by sosam117 Yesterday at 6:58 pm
by Cox International Yesterday at 12:27 pm
» Parts Cox TD-4
The twins strike again!
Not Cox, but interesting. Looks like the real deal.
http://www.ebay.com/itm/Very-Nice-Home-Built-OK-Cub-098-Nitro-Oppsed-Twin-Model-Engine-W-Flywheel-/372099469497?hash=item56a2db50b9:g:FNAAAOSwyXhZ2sQO
Re: The twins strike again!
Oldenginerod wrote:Not Cox, but interesting. Looks like the real deal.
They seem to be OK (USA) engine cylinders, right?
MauricioB- Top Poster
Yes Mauricio. OK Cub .049 cylinders. I have seen this done with Cox parts before but never with OK Cub parts. It seems that the engine is built correctly to run, whereas many that we see on ebay are not able to run.
Oldenginerod wrote:Yes Mauricio. OK Cub .049 cylinders. I have seen this done with Cox parts before but never with OK Cub parts. It seems that the engine is built correctly to run, whereas many that we see on ebay are not able to run.
If it's true Rod, it seems that this works, it would be great if there was a video, even help the seller.
I have an OK, I give it to a friend, it is an engine with very little use, but I have no manual, what is the ideal fuel for this engine? Do you know?
The best fuel would be the same as for your Cox engines. It should include castor oil and no more than 35% nitro. If you try to run the engine with more nitro something may break. My opinion on ideal fuel for these engines is, 20% oil (1/2 castor) and 15% nitro. Don't load the engine up too much. The needle valves on OK engines are very blunt so are difficult to adjust accurately. Extra nitro may help stabilize the adjustment.
Oldenginerod wrote:The best fuel would be the same as for your Cox engines. It should include castor oil and no more than 35% nitro. If you try to run the engine with more nitro something may break. My opinion on ideal fuel for these engines is, 20% oil (1/2 castor) and 15% nitro. Don't load the engine up too much. The needle valves on OK engines are very blunt so are difficult to adjust accurately. Extra nitro may help stabilize the adjustment.
Thank you very much for the information, when I march you promise to show the operation!
» DONE !!! [strike]Want to buy: A "barrel-throttle" Medallion .049[/strike]
» *Cox Engine of The Month* Submit your pictures! -May 2023-
» Flying the twins
» cox geared twins
» Flying the twins
» cox geared twins
