» Testers Sprite engine swap
» Indexing COX cylinders
» 1/2a Skyray plans?
Exercising my TD .051
TDbandit- Platinum Member
Re: Exercising my TD .051
Man! Look at it suck down the level of the fuel in the syringe! That thar's a mighty TD you got there...
The Amazed Mark
The Amazed Mark
batjac- Diamond Member
Haaaaa, that sounded good to me. Too bad we don't have "Smellivision" as I could use a good wiff of burnt nitro to brighten up these winter blues
Yeah, I also liked watching the fuel dropping thru the zip tie gauge as she ran.
Yup, it's a Tee Dee.
Finest little Cox engine ever. Now, Bandit, I can't recall, is this a new P/C or already broken in?
After Fit90 Bob gave me my first Tee Dee I had a helluva time cranking it. I'd never had a rotary valve engine before. But when I finally got it going with a flimsy nylon Top Flite 5x3, the needle was leaky so it was up and down really quick and I could see the prop flexing in and out with every change in speed. Scared the hell out of me and I had to resist the urge to dive under the table Lol. After I got the hang of it, I started telling everyone who would listen, Once you go Tee Dee, you'll never go back! And it's true, I had graduated from Black Widows and Bees. Then not too much later I was saying the same thing about bladders. I was in a whole new world of high performance. Never mind that Norvel later swept me off my feet. Bob corrupted me with that brand new Big Mig too.
Rusty Speed
Rusty Speed
It's just about fully broken in. It's got maybe 5oz through it since changing out the P/C set after a crash damaged the old cylinder at the exhaust port back in the 90's.RknRusty wrote:Yup, it's a Tee Dee.
Rusty Speed
Yup the little Tee Dee is the most angry sounding engine that Cox has made and it also responsible for a few bandaids too on my part lol. (Bandit)
Hah, yeah me too, just recently got buzzed by an APC prop. The soft underbelly of the base of my thumb. Had to fly it with a rag wrapped around my hand. Luckily I travel with bandaids... if you can get them to stick.TDbandit wrote:Yup the little Tee Dee is the most angry sounding engine that Cox has made and it also responsible for a few bandaids too on my part lol. (Bandit)
Ouch, aside from the master airscrew "razor prop" as I call em APC's cause some of the worst prop bites out there with that thin sharp tip, not forgiving at all. I always keep bandaids in my kit along with gause pads, med tape and the like. As soon as I get some more time on er i'm gonna do a tach run with it. Then it's going in my wildcat since it's almost finished. We still need to come up with a little fly-in btw Spring and summer is fast approaching! (Bandit)
Hey, I got the pic but no sign of a video. Wouldn't mind seeing it run 'cos I have an .051 (my only Tee Dee) and I've never got around to running it. I don't think I'd ever mount it to a plane. Tee Dees are just too few and far between out here, plus the falling AU$ is quickly making them even less affordable to import.
Try refreshing the page it should show up. (Bandit)Oldenginerod wrote:Hey, I got the pic but no sign of a video. Wouldn't mind seeing it run 'cos I have an .051 (my only Tee Dee) and I've never got around to running it. I don't think I'd ever mount it to a plane. Tee Dees are just too few and far between out here, plus the falling AU$ is quickly making them even less affordable to import.
Wow the fuel consumption was amazing. That was actually cool. Thanks for posting.
Yeah it's amazing how fast they suck fuel the TD's are quite thirsty. (Bandit)batjac wrote:Man! Look at it suck down the level of the fuel in the syringe! That thar's a mighty TD you got there...
The Amazed Mark
Sure they are..mine gulps 2 oz/60ccm in a flight of about 10-11 minutes. True though, that a TD 049/51 produces plenty of power.
[/quote]
........Yup the little Tee Dee is the most angry sounding engine that Cox has made and it also responsible for a few bandaids too on my part lol. (Bandit)[/quote]
TeeDee 051 a.k.a. Te(rribl)e Dee ...Pictured here is my right ring finger after a close encounter 2 years ago with the prop on a screaming TD051..the skin is pretty thin there and the bone was nicely visible...took some time for the medics at the ER to decide whether to sew or just patch it up..luckily the latter sufficed.
Yeah that sounded pretty good / that 51 really used up the fuel , balogh was that 10-11 mins or u mean laps I think once broken in and a smaller prop. so you can tweek it at a higher rpm will get you alittle better fuel mileage . Thanks for the vid Bandit , Eric
Eric, I meant this one on my vid and many others....
Here's the direct link to the video for those who can't view the embedded viewer
https://youtu.be/PhVMZCJeos4
Last edited by RknRusty on Sat Feb 07, 2015 10:38 pm; edited 1 time in total (Reason for editing : Added Youtube link)
Not a problemgetback wrote:Yeah that sounded pretty good / that 51 really used up the fuel , balogh was that 10-11 mins or u mean laps I think once broken in and a smaller prop. so you can tweek it at a higher rpm will get you alittle better fuel mileage . Thanks for the vid Bandit , Eric
It's tacking around 20k with the cox grey 5x3 right now on Cox superpower 25% but as I said, I'm being easy on it. Once it gets some more time on it' i'm gonna go to a bladder setup with an APC and see what she does but I'm gonna wait till it warms up a little more before I do so. Fuel consumption won't improve much more but it's power will go up (Bandit)
Were you able to get the video to show up? Might just of been a bug. (Bandit)Oldenginerod wrote:Hey, I got the pic but no sign of a video. Wouldn't mind seeing it run 'cos I have an .051 (my only Tee Dee) and I've never got around to running it. I don't think I'd ever mount it to a plane. Tee Dees are just too few and far between out here, plus the falling AU$ is quickly making them even less affordable to import.
TDbandit wrote:Were you able to get the video to show up? Might just of been a bug. (Bandit)Oldenginerod wrote:Hey, I got the pic but no sign of a video. Wouldn't mind seeing it run 'cos I have an .051 (my only Tee Dee) and I've never got around to running it. I don't think I'd ever mount it to a plane. Tee Dees are just too few and far between out here, plus the falling AU$ is quickly making them even less affordable to import.
EDIT: Bandit, I edited your post to include a direct link. Some of our members cannot view the embedded player.
Ah ok didn't know that sorry. I was going to do that but didn't. apologizes (Bandit)RknRusty wrote:TDbandit wrote:Were you able to get the video to show up? Might just of been a bug. (Bandit)Oldenginerod wrote:Hey, I got the pic but no sign of a video. Wouldn't mind seeing it run 'cos I have an .051 (my only Tee Dee) and I've never got around to running it. I don't think I'd ever mount it to a plane. Tee Dees are just too few and far between out here, plus the falling AU$ is quickly making them even less affordable to import.
Man, that was smooth as silk. Great run. Was that prop a Cox 5-4 Rubber ducky? I thought it looked like one. My favorite for CL is a cut down 6x3 Master Airscrew. I cut them to 5.5, 5.25, and 5". But I know propping for RC is different. What kind of tank and plumbing were you using?
EDIT: Yeah, we've started putting in the links along with the embed. Theo in South Africa and Rod in Australia can't watch the embed and I think there are a couple more members who have that problem.
Rusty if the question is about my video (I guess because you refer to RC), the prop is the 5x4 Thimble Drome sold by Bernie. The engine revs unloaded between 22-24k. I have just tached the vid with my smartphone app again. I have a party balloon for the tank in the nose that carries 2 oz fuel which lasts for about 10 minutes depending on how often I throttle the engine with the exhaust throttle barrel.
Here is my birdie the nitro-convert electro Toucan a bit disemboweled to display the party balloon tank in its nose.
My flight vid shown in this thread a few post back way shot a year ago, since then I have re-propped the TD with a 5x3 Thimble Drome competition prop (some on CEF suggested it is way more efficient than the 5x4, yet to be proven, I did the repropping yesterday after the 5x4 broke being brittle yesterday in a freezing flight) and changed to oracover on the fuse.
Otherwise the plane is just the same very forgiving and friendly. Maybe a few grams fatter because of the inadvertently soaked up castor notwithstanding the sealing layers inside the fuse and the oracover outside.
(http://www.westwings.co.uk/toucan.htm)
[/quote]
Yeah I've had my share of bites too. my worst one happened when it was being stubborn and out of frustration, I forgot about the dang battery which was still attached and I was trying to flip a flood out of it it suddenly decided to give me a little supprize by starting while I was giving it an experimental flip which startled me and I managed to put my finger right back into the then master airscrew razor-prop equipped mouth of a really mad Tee Dee and you can guess what happened next. Required 4 stitches too. (Bandit)
[/quote]
O yes sometimes they will let you know who is maddest. I am a chicken stick or elect. start man and try to keep my fingers out the prop but have had some close calls Eric
Last spring I shook hands with the 12x6 prop on my OS FS56 4-stroke....luckily it was just idling on the ground but the prop cut a deep wound in my hand...
So at the end I gathered no matter if you use chicken stick or an electric starter (which i also use) if the beast wants to bite you she will find the opportunity. May be in retaliation of some abuse we do on them?
