» Introducing the new - "QZ" RR-1by Boats13 Today at 10:19 am
by latole Today at 9:36 am
» Indexing COX cylinders
by Yabby Today at 7:47 am
by Yabby Today at 6:33 am
» 1/2a Skyray plans?
» Postage stamp backplates
» Parts Cox TD-4
It's either here or Facebook.
Well, the weather is not conducive to flying, so I figured I’d do some engine work today. I mounted up a couple of engines for the most recent projects, a couple that I got at the swap meet last week, and a couple that have been sitting on the shelf waiting for attention. Here they are on my trusty test stand.
The two Medallions are the one that I made the pressure tap on, and one that’s been giving me fits. The one that’s not been cooperative just wouldn’t run. I’ll pull it apart and see what’s going on inside. The one that I made the pressure tap for was a real dog before I messed with it. Now, with the pressure port blocked off, it’s turning 20K with a Cox 5x3 safety prop. Next thing to do with it is to plumb up a tank and see how it runs using the pressure port for tank pressure.
On the TD .051 I was going to try my hand at bladder pressure, but my forceps suck. I can’t get them open in time and the prime runs out too fast. I’ll make up a different system and try again.
Of the engines I got from the swap meet, the Golden Bee ran like a champ. The Black Widow and the Silver Bee didn’t want to cooperate. I’ll have to tear them apart and rebuild them.
The interesting things were the two Testors .049s I tried. One came from the swap meet, and one I’ve been holding for a while. The last Testors engine I tried to run was in one of the Fly ‘Em series when I was a kid, and it wouldn’t run for me at all. So I had no grand hopes for these. I looked online for operating instructions or starting detail, but there’s nothing for Testors engines like this site. So, I hooked up a tank and the starter battery and guessed from there. For anyone who’s curious, a good needle setting for starting is 2 turns open. Peak RPM was at 1 ½ turns open. For comparison to Cox .049’s, I used a Cox 5x3 safety tip prop bored out for the Testors shaft. One engine turned 17.7K and one turned 18.6K.
MUCH better than I expected. I ran about ¾ of an ounce through both, and they ran smooth and steady. I’m gonna have to clean up the other Testors, McCoys, and Wen-Macs I have and see what they can do.
The Beguiled Mark
The Beguiled Mark
batjac- Diamond Member
Re: It's either here or Facebook.
For the bladder, how 'bout I send you a pair of my short plastic toothless hemostats. You keep one hand on them unlocked while you spin the prop with the other hand. It's very easy to remove them while it's burning off the prime. PM me if you're interested. To see them, look at my bladder cranking and running sticky.
https://www.coxengineforum.com/t3317-pressure-bladder-how-to-videos-parts-one-and-two#45901
Once I'm at the point of actually flipping the prop I have the hemos clipped to the sleeve of my t-shirt and I have the fuel line pinched with my fingers.
JPvelo- Diamond Member
Since I've started putting the bladder on top of the inboard wing and running the tube over the top of the fuse, I too sometimes use my thumb to pinch it off while in the final stage of cranking.JPvelo wrote:Once I'm at the point of actually flipping the prop I have the hemos clipped to the sleeve of my t-shirt and I have the fuel line pinched with my fingers.
I always fill through a Fourmost check valve in the butt enf of the bladder. I no longer worry about the bit of air in it because the Texas Timers cone shaped insert prevents air from entering the fuel line until the very end, and it gives you a nice warning to level off and prepare to land.
P.S: I want to see all of them running at once!
Amen brother!
Amen brother!
Better add some downthrust to the engines, otherwise you will lose your trusty old sawhorse
I like your style Mark!
My hopes are to get to a swap meet next time one comes our way.
I remember one of my first experiences with these little engines was a Testors .049 in a Indy Sprite racer.It was given to me as a Christmas present by my Grandparents in the early 70's.AHHHHH the good ole days!
In missing times of my childhood,I did manage to purchase a brand new never run Testors Indy Sprite car.The original box is a little tattered,but everything that it came with was in the box,unused!
Steve
Steve
70sChild- Moderate Poster
» Facebook, do you have a profile there?
» Looking for contributions for our upcoming Facebook page
» Trying to reach 1,000 likes on Facebook
» facebook photos
» Cox Facebook page
» facebook photos
» Cox Facebook page
