» Enya .09 II Questions
» Testers Sprite engine swap
» Post edit??
[solved]Medallion .09
Medallion .09
My EBay purchased Medallion .09 arrived today, basically it's in pretty fair condition, clean and turns over with quite a bit of compression, so I'm hopeful.
However, as you will see from the picture, some idiot has had pliers on the propdriver!
Two questions....1. Does anyone know where I can get a replacement propdriver?
and 2. Can anyone tell me how I remove the existing driver and fit a new one? (If I can find one, that is)
I've looked on everyone's shop site, but no joy
Wilf
Edit: Just had the engine running, runs very well and started first time, but I now find that I'm missing the little "C" clip that holds the spraybar in, anyone know where I can get one?
Wilf
Ivanhoe- Diamond Member
Re: [solved]Medallion .09
Clip and spraybar
http://coxengines.ca/product.php?productid=467&cat=26&page=2
This drive plate might fit but it doesn't say so. It's for a Tee Dee.
http://coxengines.ca/product.php?productid=570&cat=26&page=3
Thanks folks, I've just found that EX Model Engines has both bits in stock! Should have looked there first.
Thanks for the help anyway.
Wilf
Wilf
nitroairplane wrote:Hope you get her running.
Will you be wanting Gamine plans?
Yep, engine runs great! Started first try, but I was running it on an 8 x 6 which was way out of balance but was the only vaguely suitable prop I had to hand, of course it was viabrating pretty bad so I only let the engine run for a short time, just need to tart it up a bit now with a new propdriver.
I've been considering that Gamine plan you offered, but I really mustn't start anything else until I have the three models I have 1/2 finished done! Then I must have about 50 plans for models that I want to build lined up after that! I don't think I'd better add to that!
Wilf
nitroairplane wrote:So true
We should make a plans trading page
Good idea, but nearly all my plans are downloads from RC Groups plans thread.
Now I've found the 09 bits I must put a new request on here to see if anyone knows how to remove & refit the propdriver, 'cause I'm damned if I do!
Wilf
Ivanhoe wrote:nitroairplane wrote:So true
Wilf
Put the prop screw in by itself then tap the screw genlty with a hammer of mallet until it disengages from the crankshaft.
I find that thrust washers (correct name) come off with a light tap on the end of the crankshaft with the thrust washer holding the engine about the work surface.
To seat a new thrust washer, apply it to the crankshaft, intall a prop and prop nut then tighten the prop nut securely.
Both the crank and the thrust washer are splined to mate together.
SuperDave- Rest In Peace
SuperDave wrote:I find that thrust washers (correct name) come off with a light tap on the end of the crankshaft with the thrust washer holding the engine about the work surface.
There is more than one correct name for it.
It has been called:drive plate,thrust washer and many other things by different people.
What i call a thrust washer is what norvels have where it is not actually fixed to the shaft and when the prop is not on it is lose.
Indra:
The engine is question is a Cox and Cox calls that part a thrust washer.
What more need I say?
Really,
Thats not what Bernie's site says!
http://coxengines.ca/product.php?productid=130&cat=26&page=2
again
http://coxengines.ca/product.php?productid=389&cat=26&page=2
once again
how many more must i link?
Matt says otherwise too.
http://www.exmodelengines.com/product.php?productid=17809&cat=266&page=1
again
http://www.exmodelengines.com/product.php?productid=17680&cat=266&page=3
again
http://www.exmodelengines.com/product.php?productid=17679&cat=266&page=3
again
this is what Cox call a thrust washer.
http://www.exmodelengines.com/product.php?productid=17658&cat=266&page=3
and this
http://coxengines.ca/product.php?productid=114&cat=26&page=1
and this
http://coxengines.ca/product.php?productid=407&cat=26&page=1
again
once again
again
again
again
and this
and this
nitroairplane wrote:Really,
again
once again
again
again
again
and this
and this
Fellows, fellows, stop arguing, you are talking about two different parts! The thrust washer goes BETWEEN the propdriver (driveplate) and the nose of the crankcase, they aint the same animal!
The Medallion instructions say: To remove the drive plate, use the engine tool and unscrew the collett that secures the carb body and it will push off the plate. It works on a TD too.
Dunno if it's any good to you Wilf but there's an 09 glow n.i.p. on Ebay at the mo.
J
J
John Goddard- Diamond Member
» [solved]Medallion 09 Propdriver removal?
» [solved]Cox Parts Interchangability?
» [solved]WOW They came!!!!
» Varnish seize?
» Varnish seize?
