» Another of C.T. engines cleaned ---- Cox Tee Dee .09 --- Just today (3/26/2024) more Cox partsby Yabby Today at 6:19 am
by latole Today at 5:44 am
» Indexing COX cylinders
by balogh Today at 1:10 am
» 1/2a Skyray plans?
» Postage stamp backplates
by Cox International Yesterday at 12:27 pm
» Parts Cox TD-4
How to know which cylinder I have
Hi friends, I have been reading about all the different numbered cylinders cox has produced and I was wondering if there are actual markings on them. I'm trying to find a #4 or #1.
Thanks for any help!
Glenn
Glenn
Glenn Quarles- Beginner Poster
Re: How to know which cylinder I have
Hi Glen
Some do not have a mark, many do usually the 2, 4, 5, or 7, are stamped some where on the lower part of the cylinder- others are stamped inside the exhaust slit and very hard to see without a magnifier
on the left side of this page (and all others) is an INFO area with History, Instruction sheets, and Cylinder identification
Here is a link
https://www.coxengineforum.com/h23-cylinder-identification
Here is a link
Great, thank you!!
Glenn
Glenn
I found the numbers!!! I have a couple number 1's, a couple 2's, one 4 and a bunch that didn't have numbers!
Thanks again for the help!
Glenn
Glenn
Hey Glen I see you want ad over on the other forum
I suspect you know this but if not---- Bernie at Cox international has every thing you are seeking
http://coxengines.ca/cox-.049-tee-dee-cylinder-and-piston.html
They have the timing and top end shims and a whole host of other goodies
Matt at Ex Model Engines has a bunch of stuff for cox also
http://www.exmodelengines.com/home.php?cat=267
The original #4 TeeDee cylinder had 2 bypass and each had two boost ports...later Cox engineers decided that twin bypass with a single boost port made on each side more power....just a FYI
the twin boost ports were too symmetrical and interrupted good fuel charge to the top end...the off set single boost per side creates a sort of swirl, so they claim
Seems to make sense and my experimenting with original #4 and Bernie's Cylinder / Piston set on TeeDees and Black Widows bears this out
Thanks Fred, the parts are ordered!! Good info!
Glenn
Glenn
Hey Glenn, welcome to the forum!
Lots of info and fun here. Glad you found us.
dckrsn- Diamond Member
Glenn. If you check out the "Tach Race" link on the left, you will see that the engine I entered won it's class (mouse) using not much more than one of the reproduction Tee Dee cylinders from Cox International, so they work pretty good. With the results I got, I wouldn't bother with an original #4 if performance is what you're after.
Thanks Bob and Rod! I have been intrigued by the scale reed race and am starting to gather the stuff required to make a decent motor. I always liked the Space Hopper layout and finally found one to buy now I just need to make it competive!
Glenn
Glenn
Hmmm deja vu, I think I just posted in your thread on SH too. Well welcome to CEF, you found the hidden treasure and repository of Cox Knowledge!
To the CEF Got a airplane in mine for that hopper ?
I'm thinking of a Lancair 360. I looked at all the different warbirds but didn't really find anything original that had the features I wanted. The Lancair is really swoopy so it will be good!
Glenn
Glenn
We're still after some cylinder info, mostly for the other engine sizes. https://www.coxengineforum.com/h23-cylinder-identification
I'm still working on the history section, It'll be awhile before it's ready to be displayed. Been working on it in spare time. For now, I think I'll link it to the Wiki page.
» #0 cylinder
» .09 Cylinder
» #7 .049 cylinder
» #0 cylinder
» .09 Cylinder
» #7 .049 cylinder
