» my attempt at making an exhaust throttle for Cox .049by roddie Today at 7:00 pm
by dan vincent Today at 6:15 pm
by sosam117 Today at 5:55 pm
by roddie Today at 1:08 pm
by latole Today at 9:36 am
» Indexing COX cylinders
by Yabby Today at 6:33 am
» 1/2a Skyray plans?
» Postage stamp backplates
does anyone have some golden hawk plans
does anyone have some golden hawk plans?
cox24711- Platinum Member
OVERLORD- Diamond Member
Re: does anyone have some golden hawk plans
I've always loved the look of the Golden Hawk and had hoped to get a kit from Blackhawk Models, but bringing kits out from the U.S. is just getting too expensive. Looks like scratch build for me, although I'm looking forward to the Ringmaster Bipe kit coming from Roger.
Looks like a good candidate for a piece of sig's air foil and just add,a. I'd go the trailing edge. Mabee a built up fuse instead of the hollow log?
rogermharris- Platinum Member
Yeah, it could definitely be helped by a little tweaking, though a lot of the appeal (for me) is nostalgia of the hollow log design itself. Mr. Musciano designed several Scientific Planes with both built-up fuses and wings. I keep threatening to start a "Zipper" project, rounding out the airfoil a bit to make it a happier up-side-down plane. Maybe get it started at some point!
il just buy a raven kit off hobbyking because i don't want to spend a lot of time building and it crashing because it will be my first cl plane!
Oldenginerod wrote:I've always loved the look of the Golden Hawk and had hoped to get a kit from Blackhawk Models, but bringing kits out from the U.S. is just getting too expensive. Looks like scratch build for me, although I'm looking forward to the Ringmaster Bipe kit coming from Roger.
you can get them from hobbyking!
The width of the wing on the side-view. If you adjust the enlargement until it is 4 3/8 inches, you'll have the correct width, and also the right size for it's body and rudder shape.
Cut your wing panels to a span of 18" and shape their tips to match those on the top-view. I forgot to measure the stabilizer width, but it will be whatever you get when the plan is enlarged.
Hope this helps!
