» Testers Sprite engine swap
» Indexing COX cylinders
» 1/2a Skyray plans?
Cleaning Starter Springs ?
I know these things for the most are inexpensive but when you have a hand full that are corroded , What do you guys use to clean them or you just run them on your model that ur fling for fun ! Thanks , Eric
Re: Cleaning Starter Springs ?
Maybe Dremel with a wire wheel? That will mostly remove the zinc coating too so you'd have to keep the springs oiled or re-clean them every now and then.
steel wool will brighten them up but they will rust easy. I have been looking at possibly tin plating some with this:
http://www.allelectronics.com/make-a-store/item/er-18/tinnit-bright-tin-plate/1.html
It states for copper but I have some to try it. I also have silver plating powder that I can try.
Otherwise Caswell plating have electroless zinc plating kits available.
Jason_WI- Top Poster
I heard somebody say there were stainless steel ,, but all I have come across are spring steel ?? Stupid Dreimal scares me with a wire brush on a spring ?? That plating might work I have cleaned a couple in vinegar (white) and blued them With gun Bluing , just 1-2 coats but didn't act like it wanted to adhere , I pasted them on so I don't know what happened
Vinegar will dissolve the rust, and take any zinc coating with. Wash with ammonia (Windex) or baking soda and water to neutralize. Rinse very well and oil.
If they are stainless after cleaning with vinegar they need passivised, so clean with citric acid. Many grocery stores sell small containers of citric acid powder in the canning and spice sections.
» Starter springs...
» 049 medallion starter springs
» TeeDee 020 Starter Springs
» 020 Tee Dee starter springs - Finally available!
» Starter springs and Throttle rings
