» You got dope
by rsv1cox Today at 10:08 am
» Bore-Sighting Your Mustang
by rsv1cox Today at 7:09 am
by getback Today at 5:26 am
» Pen Pals of Younger Days
» Enya 11CX diesel carby
Using Cox 0.049 Glow Plug engine with HobbyKing Mini Stick 580 mm
I have a Cox 0.049 cu.in glow plug engine in working order. It was purchased with a control line model which is now damaged. I want to use in 0.049 cu. in glow plug engine with a HobbyKing Mini Stick 580 mm. I was told that it can be done. However, I have not been able to learn what modifications are needed to fit and fly with Cox engine. I will also need a appropriate fuel tank to fit in to Mini Stick. Which fuel tank to get and how to fit. Initially i want to fly a crash model and later as RC. Can someone help and guide me?
I am normally based in India but presently in USA and will be here for next two months.
Nirmal Sinha
Nirmal Sinha
Nirmal Sinha- New Member
Re: Using Cox 0.049 Glow Plug engine with HobbyKing Mini Stick 580 mm
Hi Nirmal, your first response is a dud, though
I'm sure some of the guys will chime in with help.
I just wanted to welcome you to the forum.
I think you're our first member from the subcontinent.
In the meanwhile, here's a thread to pique your interest.
https://www.coxengineforum.com/t3408-hobby-king-mini-stick-580mm-electric-to-cox-conversion
You can also try the search box in the upper left of the page. Works well.
Again, welcome
Again, welcome
dckrsn- Diamond Member
dont worry i've almost finished mine with a rc flyer from bernieNirmal Sinha wrote:I have a Cox 0.049 cu.in glow plug engine in working order. It was purchased with a control line model which is now damaged. I want to use in 0.049 cu. in glow plug engine with a HobbyKing Mini Stick 580 mm. I was told that it can be done. However, I have not been able to learn what modifications are needed to fit and fly with Cox engine. I will also need a appropriate fuel tank to fit in to Mini Stick. Which fuel tank to get and how to fit. Initially i want to fly a crash model and later as RC. Can someone help and guide me?
Nirmal Sinha
cox24711- Platinum Member
» Killer bee clone/ hobbyking mini stick
» *Cox Engine of The Month* Submit your pictures! -July 2015-
» Mini Ultra Stick Arrived.......
» Hobby King Mini-Stick 580mm "Electric to Cox" Conversion
» .049 glow plug ?
» .049 glow plug ?
