» STUKA bomb dimentions neededby Gordinir8 Today at 9:04 am
» Indexing COX cylinders
by Yabby Today at 7:47 am
by Yabby Today at 6:33 am
» 1/2a Skyray plans?
» Postage stamp backplates
» Parts Cox TD-4
Thermal Hopper Crankshaft wanted
I was a proud owner of a brand new Thermal Hopper - dating back to before 1955- until today. The crank-pin broke when I simply flipped the prop over....I removed the backplate and saw the crank is made of a very thin material in the pin area so no wonder it broke.
Anyone has an idea where, apart from feebay (where it is not available), such a crankshaft could be found?
Re: Thermal Hopper Crankshaft wanted
I don't know if you want to do this but I've seen a thermal hopper with the case shortened to accept a killer bee crankshaft.
JPvelo- Diamond Member
Uhhhhhhh a but bizarre. ..I cannot see myself amputating the nose of an antique COX....but not a bad idea from technical point of view. Do the cranks have the same diameter? Thank you.
balogh wrote:Do the cranks have the same diameter? Thank you.
As far as I know they are the same. I would definitely to a test fit before I took the nose off the case.
That looks like a regular crankshaft with a prop hub fastener (Not sure that is the right word) screwed into the front. You should be able to unscrew the hub. Andy
anm2- Gold Member
crankbndr- Top Poster
The early cranks don't fit, they're a smaller diameter. They're also kinda rare as they didn't survive crashes very well
» Wanted to buy - Crankshaft for Early Thimble Drome 049 - Space Bug Jr Thermal Hopper Ect
» Two new in package Pre 1955 glow heads Space hopper/ Thermal hopper etc
» Thermal Hopper Crankshaft?
» theraml hopper parts wanted
» engine wanted - twin screw Thermal Hopper
