» Introducing the new - "QZ" RR-1by Boats13 Today at 10:19 am
by latole Today at 9:36 am
» Indexing COX cylinders
by Yabby Today at 7:47 am
by Yabby Today at 6:33 am
» 1/2a Skyray plans?
» Postage stamp backplates
» Parts Cox TD-4
Wanted #2350 Muffler throttle medallion .09
Re: Wanted #2350 Muffler throttle medallion .09
jmcalata wrote:I have a Medallion RC venturi but has a standar muffler
What does it look like?
Seems as if someone replaced the assembly with the trottle-ring version (leaving the arm on the venturi, which, by itself, has no function).
That "slider" assembly is bound to be quite difficult to find but, should we come across one, will advise.
check ebay
they show up on ebay occasionally. Sometimes for .049, sometimes for .09 and sometimes for both from the same seller.
happydad.
happydad.
happydad- Rest In Peace
heres one on a Cox .049, keep looking
jm: here is a link to a Cox .049 with the same type muffler. Like I said, sometimes you see the .049 version, sometimes the .09 version and sometimes both.
link:http://www.ebay.com/itm/EXCELLENT-OLDER-COX-MEDALLION-049-R-C-NITRO-MODEL-AIRPLANE-ENGINE-wMUFFLER-/141821033046?hash=item2105313a56:g:0kwAAOSwAYtWPBd2
happydad
I have a couple of the slide mufflers and really like them, they idle nicely. And I would say yes, get yourself a complete one. But, how about trying an experiment? Since you have the rotating spray bar, how about using that in conjunction with the rotating muffler. Move the linkage holes to the left side and link the muffler to the spray bar. Might work, might not. But if it were me I'd give it a go.
The Experimenter Mark
batjac- Diamond Member
That's an idea Mark it would be interesting to see if it worked , the .09 medallion is at 12$ you would be lucky to ever get one without buying the whole engine , I have never seen one by it self that I can remember the .049s I have been seeing go for 60-70$ http://www.ebay.com/itm/COX-MEDALLION-09-MODEL-AIRPLANE-ENGINE-/291614233365?hash=item43e5901315:g:Yx0AAOSwYHxWQ4hu getback
i have a normal muffler for a .09
but i dont think that would help you
robot797- Platinum Member
Doesn't look complete
Eric, that Med .09 you posted a link to the auction of, doesn't look like it's muffler assembly is complete either. It appears to be missing the linkage lever at the back of the 'muffler slider'. Not sure how you would connect the throttle linkage up to this.
VUgearhead- Gold Member
Good thing you seen that I guess I missed it in a heist , I would suppose you could heli arc a arm to it , it will probably go cheap since its not complete 3 bidders . getback wants a heli arc to go with his stick welder
It's just a small bracket screwed to the spindle. You could make one up in 5 minutes. No deal breaker.
The Fabricator Mark
The Fabricator Mark
Thanks for your comments, I have not bid yet, I asked the seller about shipping cost.
I´m waitting
I´m waitting
» Med .09 Intake Throttle
» Medallion .049 Exhaust Throttle Muffler RC Conversion
» Medallion .09 throttle/muffler part no. 20497
» Wanted - .049 Dragonfly throttle/muffler assembly
» Tee Dee09 or Medallion 09 exhaust throttle ring wanted
