» Enya .09 II Questions
» Testers Sprite engine swap
» Post edit??
cox gtp parts needed
hello i got a gtp today
and one of the steering hubs is broken
does anyone have a spare here (some screws and a radio box would also help)
robot797- Platinum Member
Re: cox gtp parts needed
just to let u know there is a a lot of spares on fleabay hope this helps
cox24711- Platinum Member
i know but the part i need isnt
The part you need is GTP21? This is the steering arm where the front axle is mounted to.
These parts are extremely brittle. New parts out of the bag will be brittle. The type of nylon they were molded from did not age well. The holes where the ball joint threads into like to split out or the thin arm breaks off. It would be nice if they were CNC machined from aluminum but with the low volume it would not be feasible to keep it cost effective.
Jason_WI- Top Poster
CNC help needed
Jason_WI wrote:The part you need is GTP21? This is the steering arm where the front axle is mounted to.
Who is the guy who has access to a CNC mill, Roddie? I can't remember, but I'll look at old threads for wheels and it will pop out.
hello it is Roddie: read this post:https://www.coxengineforum.com/t7113-racing-wheels?highlight=ultra+light+wheels
happydad
Last edited by happydad on Wed Sep 30, 2015 7:34 pm; edited 1 time in total (Reason for editing : add info)
happydad- Rest In Peace
Find it yet?
robot797 wrote:hello i got a gtp today
Hi
Still need the parts?
Alejo
garza2014- Bronze Member
Yes I still do need the parts
My epoxy isn't holding as good as I want
plastic parts and epoxy don't mix
robot797 wrote:Yes I still do need the parts
can you post a picture? If garza2014 can't help you gascarman on ebay can. or maybe a small long screw in the right place will work temporarily.
link to entire suspension block assembly: http://www.ebay.com/itm/COX-KYOSHO-GTP-VINTAGE-R-C-RACE-CAR-PARTS-GAS-POWERED-GTP-SUSP-ASSY-/151853225523?hash=item235b285633:g:xzMAAOSw14xWJCWI
or just the suspension blocks: http://www.ebay.com/itm/COX-KYOSHO-GTP-VINTAGE-R-C-RACE-CAR-PARTS-GAS-POWERED-GTP-20-/111664019913?hash=item19ffb1b9c9mh2UxpQ02xP1PkGGx-Y_nag
happydad
Parts
As happydad says which part do you need?
This is my epoxy repair (Left) and new one GTP 21 (waiting for a new aluminum part )
Alejo.
hy
part 20 (in the drawing)
is the one that broke
On eBay
robot797 wrote:hy
Search for gascarman on eBay as happydad says, if you just need GTP 21 write to seller.
I'm from Colombia, look on ebay, if gascarman don't have it I'll help you.
Alejo.
Parts
robot797 wrote:hy
Did you find the seller? And the parts?
Alejo
i did find it
but i lost it nwhen the power went out
and now i cant find it again
» .049 TEE DEE parts needed
» cox 049 parts needed
» Cox Sandblaster parts needed
» P-40 propeller needed!
» Kustom Kraftmanship Parts Wanted Remote NVA needed.
