» Help with Disassembly
by Jason_WI Today at 1:25 am
» Question re. small red rubber spinners
by KariFS Yesterday at 11:53 pm
» Charlie Brown, a West Virginia hero
by Marleysky Yesterday at 9:51 pm
» Fredvon4 sent me a tee dee and I didn’t know!?
by NEW222 Yesterday at 9:44 pm
» messing around with flywheels
by roddie Yesterday at 7:40 pm
» Texaco Running Steady
by Cribbs74 Yesterday at 7:30 pm
» SPI or Free Porting
by crankbndr Yesterday at 5:35 pm
» Not a Cox Engine
by ffkiwi Yesterday at 4:44 pm
» 6 new glow heads
by Marleysky Yesterday at 3:19 pm
» Follow The Traveling Engine!
by dckrsn Yesterday at 3:19 pm
December-2018
Dave P.'s
"RC Tee Dee 049"
Speed Contest 2018
The Traveling Prop
World of Aviation
Cox .01 /.02 /.05 Engines & Mods / Nano Speed Planes
Page 22 of 22 Previous  1 ... 12 ... 20, 21, 22
Happy Re: Cox .01 /.02 /.05 Engines & Mods / Nano Speed Planes
Post  1/2A Nut on Sun Jan 06, 2019 10:13 pm
Thank you Eric, I am using a AR 400 RX / note there is a new version out AR 410 has new features.
I have finished covering the plane, also set up the throttle and elevator servo throws / trims.
Down to setting up the wing servos and putting a name on the wing and race number, will go
with neon yellow it really pops off the carbon pattern.
Weight came out to 8.2oz, the pipe / manifold / extra servo took away a chance at 7oz.
Near matching weight to the NANO III.
The snug fit of the wing servos should only need a patch of black or clear tape to keep them in
place / easy to change out if I have one go bad. Surface throws for the maiden will be kept at
35% / CG came out good / bit nose heavy when fueled up.
This was a fast build for me from Dec 29 to the 6th / the holiday free time helped.
Small Cox Logo RC Plane Christmas Tree Bad Xmas Gift Lighting The Tree Rudolph
View user profile
Post  Dave P. on Sun Jan 06, 2019 10:53 pm
Popcorn
Dave P.
View user profile
Post  1/2A Nut on Mon Jan 07, 2019 2:04 am
TD .020 is a exact scaled down version of the larger NANO III that flew with a TD .05 RC engine.
Small Cox Logo
View user profile
Post  getback on Mon Jan 07, 2019 7:56 am
Nice and straight she should really move out . That was a fast build , time off to put your all into it makes a big difference. Small Cox Logo RC Plane Small Cox Logo
View user profile
Post  ticomareado on Mon Jan 07, 2019 9:21 am
Jawohl !! It has BF-109E written all over it.
ticomareado
View user profile
Post  1/2A Nut on Mon Jan 07, 2019 10:58 pm
Need to name this one the last version  TD 05 RC was the NANO III.
This one has the X factor with the tuned pipe and the fact that it a honed down version from what was
learned with the N-III version. So will call it Nano X this size lettering and numbering maxes out as much
neon yellow as possible without going out of bounds, here is the rendering:
View user profile
Post  1/2A Nut on Tue Jan 08, 2019 3:29 am
Ok this turned out to be a great visual aid for quite a good distance away.
I tried a new trick wet the paper put it over the neon shrink film after the backing was removed then cut most
of it out with scissors. Only needed the razor blade for the (a and the o) took about 35 mins. from start to finish.
Sure makes it a sexy beast with some shizzle... Eyebrows
View user profile
Post  Marleysky on Tue Jan 08, 2019 4:47 pm
Awesome, awesome, I can’t wait for the flight video! Very nice job Brad.
I Support My Forum
View user profile
Post  ticomareado on Tue Jan 08, 2019 4:57 pm
I wonder if it will haul a GoPro.
ticomareado
View user profile
Post  GallopingGhostler on Tue Jan 08, 2019 5:11 pm
Speaking of nano speed planes, here's a slick looking design just posted on Outerzone, that reminds me of the various nano planes posted in this forum. A 36 in. span Coupe d'Hiver that is rubber powered, won the 1970 King Orange Internats and the Nats two years later. It is very streamlined, seems a bit ahead of its time.
https://outerzone.co.uk/plan_details.asp?ID=10782
View user profile
Post  getback on Wed Jan 09, 2019 7:05 am
Plane looks Great Brad in Texas ! Very Sleek I hope you get the Speed your after Horsing Around Friends/Meeting Jaw Drop
View user profile
Post  1/2A Nut on Wed Jan 09, 2019 10:01 am
Thank you gents Thumbs Up
Should do 140+ down wind passes in front of the camera with a carbon 4x4.5 pitch prop.
The real testing will be trying modified props such as a 4x5 / 152 mph pitch speed is possible.
Really just hope for a good solid running / flying trimmed up plane on the maiden first day
fights. Hope to get some up close passes for some good still shot pics.
I have a AR410 in the mail will use that as the servo plugs orintation
don't stick up will allow me to adjust the CG better scooting the RX
back further in the fuselage. Also have a lighter 220mah LiFe cell I
will use to fly with in the mail as well. Soon as that gear come in
will head out to the flying field with it. Will at least be able to fire up
the engine this weekend and check the servo movement under engine
vibration to insure no issues there and setup the idle / will post the
pre maiden engine test to also check rpm one last time as things
can change from bench to plane / fuel tank configurations.
Flying
View user profile
Post  Dave P. on Wed Jan 09, 2019 9:49 pm
That's sweet Brad.  Really cool.  I'm really looking forward to seeing what you get.  Especially with that header and crankcase pressure setup.  If you don't mind me asking, are you using a check valve or straight crankcase pressure?
Dave P.
View user profile
Post  1/2A Nut on Thu Jan 10, 2019 2:29 am
Thank you Dave! Thumbs Up
Here is the first bench test, from there built the plane now ready to do a pre flight run up
set the NV and throttle throws for good low idle and see what the inboard fuel tank gives
me run time wise. Don't want to have to fuss with this on the maiden flight day out in the
field. Straight pressure to the tank no check valve. You do not want high pressure when
the engine is at idle with this air bleed carb. Using a KK backplate pressure tap.
Also set up the servos on the wing tonight need the AR 410 to come in the mail next.
View user profile
Post  1/2A Nut on Sat Jan 12, 2019 2:40 am
Carbon rod for the wing dowels AR 410 came in the mail much better with the leads facing forward.
Was able to push it back into the tail area further to improve the CG. Lower weight than the AR 400
with the case off, used thick mil heat shrink.
View user profile
Post  getback on Sat Jan 12, 2019 9:13 am
Nice , i presume you are going to us the RX without the case ? I am about to order one of those and some servos , i am looking at these Hitec one but don't know if they are compatible https://www.towerhobbies.com/cgi-bin/wti0004p?&I=HRCM3402 I have seen were you can get a wire adatptor to make futaba servos work , i have a few s148 would be for another plane that don't need micros .
View user profile
Post  1/2A Nut on Sat Jan 12, 2019 10:18 am
Yes and yes (see added pic in previous post) the servos will work just fine Eric.
N-III vs N-X comparison.
View user profile
Post  getback on Sat Jan 12, 2019 1:49 pm
OK Thanks for some reason didnt load the last pic before ??!! Surprised Thumbs Up
View user profile
Post  1/2A Nut on Sat Jan 12, 2019 10:58 pm
First bench test with the plane / engine combo.
I had the engine held back with a full size crescent wrench .9 lbs via rubber band around the rear
stabs and the hole in the wrench handle. Engine thrust managed to drag that and the plane forward.
Typically the wrench has always been heavy enough to hold back the other TEE Dee .049's. NV was
left a bit rich to make sure there is plenty of fuel flow when the engine unloads, idle was good to go.
AmpAbuser
Published on Jan 12, 2019
Per prop thrust calc:
4 x 4.5 Static Peak 26,086 rpm / 111 mph pitch speed
.147hp / 110w / 7.8oz thrust
View user profile
