Caravan 1/2 A Cox_ba12
November-2022
cmulder's
"Throttle and muffler contraption"
Caravan 1/2 A Empty
Caravan 1/2 A
Caravan 1/2 A Empty Caravan 1/2 A
Post  jmcalata Fri Apr 29, 2016 5:04 pm
Here is the plan of my new project.
Caravan 1/2 A Carava10
Vintage american motorglider configuration wasalmost like tandem wing with big stab and center of gravity about 70% very stable
jmcalata
jmcalata
http://aeroguada.com
Caravan 1/2 A Empty Square fuse
Post  jmcalata Fri Apr 29, 2016 5:21 pm
Building square fuse it´s not complicated, not necessary paper plan copy scale 1:1
Caravan 1/2 A Img_2010
jmcalata
jmcalata
Caravan 1/2 A Empty Re: Caravan 1/2 A
Post  duke.johnson Fri Apr 29, 2016 11:35 pm
Very cool. I love free flight.
duke.johnson
duke.johnson
Post  MauricioB Fri Apr 29, 2016 11:42 pm
Jose Excellent !, I will be visiting the post sharing your progress! ... A hug, Mauricio Thumbs Up .-
2020 Supporter
Post  KariFS Sat Apr 30, 2016 1:18 am
Nice! I like those pylon style models too. Are you going free flight or radio assist?
Post  OVERLORD Sat Apr 30, 2016 1:57 am
Hi José, looking forward to the build. Will you install a timer?
Post  jmcalata Sat Apr 30, 2016 3:44 am
Thanks for your comments friends.  I Love This Forum!
Yes, I also love very much "free flight" over all categories.  cheers
I think is a pure art. Trimming airplane to circling thermals.   sunny
But today at XXI Century better radio-assisted  RC Plane  because here there are many trees roads and railway close.  Sad
But normally I don´t touch transmiter during the flight but is to bring him or avoid an accident.
I just enjoy seeing flies free lying on the floor.  Popcorn
Caravan 1/2 A Pilota10
We have several vintage motorgliders.
Two super high pylon wing "Timer´s Nightmares" of Frank Ehling
Caravan 1/2 A Timers10
Caravan 1/2 A 62806810
https://www.coxengineforum.com/t1325-timers-nightmare-frank-ehling-1942
The "Frisco Kid" of John Tatone very similar to this Caravan.
Caravan 1/2 A Plan10
Caravan 1/2 A Frf10
https://www.coxengineforum.com/t1374-frisco-kid-john-tatone-1955
And "Engendrus" a personal design home-made with recycled free fligh gliders parts and powered  Small Cox Logo  Tee dee .020.
Caravan 1/2 A Piezas10
Caravan 1/2 A Bueno10
jmcalata
jmcalata
Post  jmcalata Sat Apr 30, 2016 4:08 am
I want to buid the Caravan strongest than Frisco and Nightmare, they are very light and low weight for quite weather, and I want the Caravan for fligh in all conditions.  Airplane
If Small Cox Logo Babe Bee .049 .049 it is not enaugh  power to clim higher and fast, I could mount a big engne OK .074 with auxiliar tank into the fuse and Tatone timer to cut fuel to practice vertical takeoff "V-tol".   affraid
Caravan 1/2 A Img-2010
Now assembling the fuselage, note the top and bottom veneer with cross grain to improve the torsional strength and two steel wires 1/32" diameter transmission for rudder and elevator.
Caravan 1/2 A Img-2012
Last edited by jmcalata on Sat Apr 30, 2016 4:12 am; edited 4 times in total (Reason for editing : Language always spelling corrections)
jmcalata
jmcalata
Post  jmcalata Sun May 01, 2016 4:23 pm
The fuselage and the rudder will be covered with very bright colors
Caravan 1/2 A Img-2013
I have made a modification to the plan and I build the wingtips trapezoidally
Caravan 1/2 A Img_2011
I used wooden harder in the central wing panels as they work to greater bending stresses.
jmcalata
jmcalata
Caravan 1/2 A Empty Dihedral joint
Post  jmcalata Sun May 01, 2016 4:30 pm
It is very important to make a good joint wing panels, I used dihedral reinforcement ply sheets on all spars.
Caravan 1/2 A P1010813
Caravan 1/2 A P1010910
jmcalata
jmcalata
Caravan 1/2 A Empty Wing
Post  jmcalata Mon May 02, 2016 4:21 pm
Gluing dihedral joints
Caravan 1/2 A P1010911
Wing finished ready to cover
Caravan 1/2 A P1010912
Horizontal stabilizer is very easy (no dihedral joints).
jmcalata
jmcalata
Post  jmcalata Tue May 03, 2016 2:37 am
I use clear oracover at centre wing panel because oracover is strong, and blue clear oralight at tips wing panels.
Caravan 1/2 A Img-2014
Wing weight 125 g (4,41 oz) span 1130 mm (44,5 ") coord 190 mm (7,5 ")
jmcalata
jmcalata
Post  OVERLORD Tue May 03, 2016 3:33 am
Looks great!!
Post  fit90 Tue May 03, 2016 7:41 am
Beautiful work! It looks super. I bet it flies really well.
fit90
fit90
Post  pkrankow Tue May 03, 2016 2:31 pm
dihedral can be a trip to glue right. Looks good. I like the colors.
Caravan 1/2 A Empty Horizontal stabilizer
Post  jmcalata Tue May 03, 2016 2:43 pm
Thank you for your comments. I'm glad you like it, someone knows the name of the designer ???
I choose vivid, bright and colorful and above all visible colors height, flourescent is the most visible.
Caravan 1/2 A Img-2016
High visibility can make the difference between seeing or not seeing it.   RC Plane
Caravan 1/2 A P1011011
Although I have built a larger elevator to desthermalizer tilting 45 degrees with servo.
jmcalata
jmcalata
Post  jmcalata Tue May 03, 2016 4:54 pm
Flying surfaces covered
Caravan 1/2 A P1011012
Fixing system of the horizontal stabilizer with rubber bands
Caravan 1/2 A P1011014
Hole between stab and elevator to put rubber bands
Caravan 1/2 A P1011013
jmcalata
jmcalata
Caravan 1/2 A Empty Babe bee .049
Post  jmcalata Wed May 04, 2016 8:37 am
I mount this Babe bee .049, it has a shim at botom cylinder, I think to remember it was to modify timming to use larger props ?
Anyone can confirm it to me?
Caravan 1/2 A P1011015
Caravan 1/2 A Img_2012
At first, I mount this plastic yellow 6x3 " ... if don´t pull enough ... I can change by grey 7x3,5" to increase thrust.  Babe Bee
If it is not plenty power ...  I will mount this Tee dee .049
Caravan 1/2 A _5710
jmcalata
jmcalata
Post  jmcalata Thu May 05, 2016 6:40 am
Finished
Caravan 1/2 A Img_2013
Ready to fly
Caravan 1/2 A Img_2014
Caravan 1/2 A Img_2016
Caravan 1/2 A Img_2015
jmcalata
jmcalata
Post  pkrankow Thu May 05, 2016 8:30 am
I'm not sure how I feel about the checkerboard fuselage... Then again it is YOUR plane. In any case that is a good looking plane.
Clapping
Nicely done!
Post  jmcalata Thu May 05, 2016 10:36 am
Thank you Phil, may 2016 is the Small Cox Logo Chess month lol!
Caravan 1/2 A P1010814
Check Mate ! Small Cox Logo Reds win !
Caravan 1/2 A 55236910Caravan 1/2 A Imager10
This afternoon I flew it for the first time, I could not wait any longer ...  sleep
Tonight upload Youtube video maiden flight.  lol!  affraid
Caravan 1/2 A P1010913
Sad Goodbye
jmcalata
jmcalata
Post  fit90 Thu May 05, 2016 2:40 pm
Looks great! I am looking forward to watching the video.
fit90
fit90
Post  jmcalata Fri May 06, 2016 2:45 am
Here´s the Caravan stressfull maiden flight video.  RC Plane  lol!
I´m still tired .. Warm Warm Warm
JMCalata sunny Spain
jmcalata
jmcalata
Post  OVERLORD Fri May 06, 2016 3:47 am
That's a fantastic video José: innocent beginning followed by suspense and a happy end ; all with dramatic Wagner!!
Glad you found the plane back.
Post  Oldenginerod Fri May 06, 2016 3:54 am
It does teach us a lesson.  Don't assume that you remembered everything.  affraid  Always do a pre-flight check of your controls. Airplane
