Cox .020 Pee Wee Needle valve question Cox_ba12
Cox .020 Pee Wee Needle valve question Pixel
» Top Flight props
by 944_Jim Yesterday at 10:38 pm
» What RTF plane is this from?
by dckrsn Yesterday at 9:30 pm
» Svenson Coxy plan
by NEW222 Yesterday at 8:18 pm
» Cox 140 Beaver
by davidll1984 Yesterday at 8:17 pm
» Cavacraft Fokker D-7
by rsv1cox Yesterday at 3:31 pm
» Ohisson & Rice what-ever and Champion V (3/8" by 24 tpi) arrives
by rsv1cox Yesterday at 2:18 pm
» General TD 049 Assembly
by Yabby Yesterday at 3:47 am
» *Cox Engine of The Month* Submit your pictures! -August 2021-
by balogh Yesterday at 12:47 am
» Testors P 51 Mustang, how to disassemble?
by rgbolen Mon Aug 02, 2021 9:10 pm
» A Flying Clown Friday (and Sunday)
by getback Mon Aug 02, 2021 8:38 am
» Cox RTF Wheels
by rsv1cox Mon Aug 02, 2021 8:27 am
» Oh Deere............
by rsv1cox Mon Aug 02, 2021 7:36 am
July-2021
"Rusty's RR-1 runs up on the Q-Tee on a beautiful Summer S.M.A.L.L. Day."
Forum Store
CEF Ear Savers
Cox .020 Pee Wee Needle valve question Empty
Cox .020 Pee Wee Needle valve question Empty Cox .020 Pee Wee Needle valve question
Post  hawkeyebill@earthlink.net Mon Aug 08, 2016 6:18 pm
I have a good number of Cox Pee Wee .020 engines and they all seem to leak a slight amount of air trough the needle valve. In order to keep the engine running, I have to keep moving the needle valve. Even just touching the needle valve can make the RPM's change dramatically. These engines are extremely sensitive on needle valve settings. So, any thoughts on using teflon on the threads of the needle valve to make a better seal? Open to any suggestions or cures. Sure wish they had O rings.
New Member
New Member
Cox .020 Pee Wee Needle valve question Empty Re: Cox .020 Pee Wee Needle valve question
Post  Marleysky Mon Aug 08, 2016 7:01 pm
Yea!   New member, WELCOME to the forum. Pee Wee 020 is the baby sister to the BabyBee 049. Start reading on page 7 to 10 of this important information:  RC Plane
https://lookaside.fbsbx.com/file/newsletter4.pdf?token=AWw01BESBQ2r406cRHtW01WodwwvRE0tU9fv8t_SuBSOi9SLzKouBD5hllDZi3uYGFkijyBPxzxu2uPGBD7Aa0mFeuv4WlZt7oWlYb8YkRZ8FK_9lYXf-IhZAD6gwxGKRo-QH2c5wvKOOmldS1NtpR_r-B1oGCVzcT3CU1FKZSqYfQ
Try the short section of silicon tube with a small washer to seal the needle valve. RC Plane
You can read the whole newsletter, Rusty built a really cool cat airplane, too!! lol!
2019 Supporter
2020 Supporter
Cox .020 Pee Wee Needle valve question Empty Pee Wee needle valves
Post  706jim Fri Aug 12, 2016 9:58 pm
Be REALLY careful when closing this needle. Too much pressure and the tip will break off and get stuck in the backplate. No fixing it when this happens.
As to the rpm variation I'd go with the silicon tubing if it were a problem.
706jim
706jim
Post  batjac Sat Aug 13, 2016 12:11 am
I third the fuel tube suggestion. I have several .020's that I've played with the last couple of years. The ones I like the most are off of the little helicopters, and they have the spray bar seals like the later .049 engines, but the other PeeWee engines didn't come with it. So the tube and washer solution is it. Just do a little measurement first. Open up the needle to where you had it running before, and measure the distance between the tank and the flat part of the needle where the washer is going. Then cut your tube just a tiny bit longer. You don't want an excess of tube.
The Wee Mark
2019 Supporter
2020 Supporter
