» Project Cox .049 r/c & Citabrian Championby MauricioB Today at 6:08 pm
» Fox .35 Modifications
by GallopingGhostler Today at 5:58 pm
by rsv1cox Today at 5:56 pm
» Happy Anzac Day!
by GallopingGhostler Today at 2:44 pm
by rsv1cox Today at 9:17 am
by getback Today at 8:20 am
by Levent Suberk Today at 2:23 am
by roddie Today at 12:25 am
by rdw777 Yesterday at 10:15 pm
by rdw777 Yesterday at 10:06 pm
by GallopingGhostler Yesterday at 7:12 pm
by roddie Yesterday at 5:39 pm
cox engines props
cox engines props
what would be better a smaller prop or larger on a stander stock .049 ?
cjuliano- Bronze Member
Re: cox engines props
It depends on the particular application.
I'd usually recommend a 5x3 or 6x3 prop. The 6x3 may be better for slower, 'sport' flying be it control line or R/C. The 5x3 is a good all around propeller, and is available in a basic variety as well as a competition series.
Regards, Matt
Regards, Matt
with Matt, it depends on the application. I usually run 5x3s but I have played with the 5x4s, 6x3s, 6x4s, 5.5x3s as will as some 3 bladed props (not so easy to get these days) on my .049s
my friend has a three blade prop that he is going to give me.
how are those
how are those
A 3-blade isn't a bad prop in the right application, but they usually restrict power in .049's in my opinion.
If its an aircraft where power will not be an issue then a 3-blade will work fine.
What are you looking to do with your engine?
Matt
Matt
I think the 3 blade props cavitate at the comparatively extreme RPM model engines turn, thus the power loss.
3 blade props:
http://coxengines.eu/parts.html
http://www.wightsmodelaircraft.com.au/wmaPropellers.html
http://coxengines.ca/propellers/
http://stores.ebay.com/Model-Engines-and-Parts-Warehouse/Cox-Propeller-/_i.html?_fsub=200584017&_sid=2265057&_trksid=p4634.c0.m322
http://masterairscrew.com/3-bladeseries.aspx
RknRusty wrote:I think the 3 blade props cavitate at the comparatively extreme RPM model engines turn, thus the power loss.
Ya got me Rusty
John Goddard- Diamond Member
cjuliano wrote:what would be better a smaller prop or larger on a stander stock .049 ?
As above CJ depends on what model and What you want it to do.
Easiest way to imagine it is the bigger a prop is, is akin to a higher
Gear on your car or cycle. Low gear great for quick getaway and going
Up a hill. High gear not much fun going up a hill but fast going
Down.
Sorta but that being said, why do 3Ders use late diameter low pitch props?
Because they climb better.
nitroairplane wrote:Sorta but that being said, why do 3Ders use late diameter low pitch props?
Exactly because it's like being in first gear all the time.
If you get into trouble you just open the throttle and point the
Nose up. Also coming down they act like a brake.
On my QQYAK I run an APC 16x4 Wide, on the down lines
You can actually hear the hisssss as the prop slows the
Thing down.
» Spacers for 7" & 8" props on 049 & 09 engines now available
» Now Available - 7" Props for Cox 049 diesel and 09 engines
» Selling kits and engines. *NEW added 1/2A engines!
» need a bidder
» need a bidder
