» My Cox .049 Marine inboard engineby F4D Phantom II Today at 9:44 pm
by F4D Phantom II Today at 9:06 pm
by HalfaDave Today at 8:50 pm
by rsv1cox Today at 7:59 pm
by rsv1cox Today at 7:19 pm
» need info on this
by lla Today at 5:19 pm
» Post your Older books
by GallopingGhostler Today at 2:49 pm
by rsv1cox Today at 12:17 pm
» O&R 23 & Brown Jr
by lla Today at 11:15 am
» Fox .35 Modifications
by rdw777 Today at 8:51 am
by rdw777 Today at 8:30 am
» "SOLD OUT" Cox .020 silencers -- currently
by GallopingGhostler Today at 5:12 am
Hobbico's "Cox Super Fuel"
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: Hobbico's "Cox Super Fuel"
She probably doesn't know the difference. Hobbico is considered a reputable marketeer. They do have some good people working for them. In this case, this decision by someone, whoever that person was, did not research into the requirements of these small engines with foks like Bernie at Cox International, Larry Renger, Joe Wagner or any of the other modeling authorities on small plain bearing engines with ball and socket piston/con rod joint.batjac wrote:I was at the hobby shop this afternoon and they had two bottles of the Hobbico Cox fuel. I was talking with the owner's wife about a couple of things, and pointed to the bottles and explained how the stuff would kill the engines of any customers who bought it for their Coxes and why. She just tuned me out. Oh, well. I've steered a couple of people away from the fuel, and I'll continue to. The Trying to be Helpful Mark
So, you being a relative stranger to her, figured you weren't an authority and thus to her it was just another complaint, probably.
About the only way would be someone with some modeling knowledge and authority to speak directly to Hobbico and explain the problem. Problem probably is that bean counters are in control, and if they don't see a drop in sales, will continue what they are doing, just like Testors did with the old Testors 39 fuel eons ago, IYKWIM.
I doubt she has even heard of Bernie, Matt, Joe or Larry either.
How about this for a conspiracy theory -
A collector of Cox engines is a major model fuel manufacturer. The manufacturer creates a fuel at a reasonably low price that wrecks Cox engines.
His collection increases in value as engines and parts become rarer.
Here it is easy to get fuel made up or the liquids to make your own - but difficult to get it delivered. Buy and collect - either from the manufacturer or make an arrangement to collect at a show where they are exhibiting.
"Buggy" fuel (non castor) is easy to get in model shops, diesel fuel is difficult along with castor based fuel. (Diesel fuel is usually castor only because of the higher temperatures)
From what we understand the Hobbico (rebranded Cox) fuel is 20% oil, of which 1/2 is castor oil; so it should be fine for Cox engines.
Following is stated from Tower Hobbies Tower Hobbies: Cox Super Power 1/2A Fuel 25% Nitro QuartCox International wrote:From what we understand the Hobbico (rebranded Cox) fuel is 20% oil, of which 1/2 is castor oil; so it should be fine for Cox engines.
Tower Hobbies wrote:NOTES FROM OUR TECH DEPARTMENT
This is the quart (946ml) Bottle of Super Power 1/2A Fuel from Cox. FEATURES
- Premium blend 25% nitro formula is ideal for model airplane, car, or boat use
- Special 18% oil package consists of 90% synthetic, and 10% castor lubricant blend
- Latest high-tech synthetics combined with castor protects and lubricates the aluminum journals and plain steel bearings used in small displacement engines
http://www3.towerhobbies.com/cgi-bin/WTI0001P?I=LXDBNH&P=8
If you scroll down to the product features, it states "Special 18% oil package consists of 90% synthetic, and 10% castor lubricant blend"
**Oops, GallopingGhostler beat me to it!
OUCH!
I thought they once told me the mix had 10% castor oil. I guess what they meant was 10% of the oil was castor. Definitely DO NOT use this fuel on Cox engines.
I just called them and will follow up with an email.
Pete,
I guess you are the gent that sent us the mail re. fuel you bought from us. Theresa responded to let you know that we do not sell fuel; hence we could not have supplied it to you.
We would like to make it clear that we are in no way involved with Hobbico and / or the fuel they sell. If the mix of their fuel is indeed 10% castor / 90% synthetic then we would not recommend it, as it will invariably lead to engine damage.
We are currently compiling an email to Hobbico to make them aware of the fuel issue.
PeterJGregory wrote:
Cox engines are rather peculiar in lacking a wrist pin. The required motion is done with a ball and socket joint, and the socket part of that bearing is the piston. Very few other engines do this. The piston gets very hot, and it will cook out any oil other than castor.
Thank you for a clear explanation about this castor oil issue.
I am absolutely mesmorized by this discussion. I paid almost $50 for a gallon of Cox Super Fuel from Tower, to find out it doesn't work!!!
I just sent Tower a question about why they sell this stuff when it destroys Cox engines.
Very interesting that the ultimate problem is not the cylinder wall varnishing, but the breakdown of the ball-and-socket.
Now to hear back what Tower has to say about this.
Better yet, I need to contact the Cox people putting this stuff out.
What can you use the Cox Super Fuel for if not for Cox engines? The other small engines are OK with this stuff?
Thanks, Poughkeepsie Pete
I guess it never really dawned on me, but even though this is a Cox brand (sort of) it only says 1/2A fuel on the bottle.
1/2A is a pretty broad spectrum and on some engines that mix may work just fine.
That's true, if not for the ball socket they might be okay with less castor. Out of curiosity I just looked at NVengines.com and they say, "Use the proper oil mixture. Requirements - minimum 18-22% oil in the fuel with 50% being Castor oil in engines smaller than .15 and at least 25% castor in larger." The MP Jets say no less that 20% castor too, so Cox isn't alone in the high castor requirements.Cribbs74 wrote:I guess it never really dawned on me, but even though this is a Cox brand (sort of) it only says 1/2A fuel on the bottle.
We sent the following email to airsupport@hobbico.com
Hello Justin,
As discussed on the phone with you, Hobbico product # COXP1005 Cox Super Power 1/2A Fuel, if indeed a mix of 90% synthetic and 10% castor oil, will almost certainly damage Cox engines if used in such.
There have been extensive tests performed with various castor / synthetic oil mixes and although, under some ideal circumstances, one could use as little as 25% castor / 75% synthetic mix, the consensus is that a 50% castor / 50% synthetic mix or better should be used to prevent engine damage.
This is due to the unique nature of Cox engines, with no piston rings, OEM tolerances of 2 /1,000,000” on cylinder / piston fit and Cox’s unique ball and socket joint for the piston / conrod assembly. Basically, Cox engines were engineered to require castor oil and no synthetic oil currently available (that we are aware of) would be a good substitute for castor oil.
In 2009 we purchased over 25,000 Cox engines, together with several pallets of other Cox items and are currently the world’s largest distributor of legacy Cox products. We would be most happy to include Hobbico as a recommended vendor for Cox engine fuel but can only recommend fuel that does not potentially lead to premature engine failure.
Perhaps you could forward our email to the person or persons in charge of fuel procurement. Please feel free to contact the undersigned at any time should you or someone else have any questions. FYI, there is an ongoing thread about your fuel on the Cox Engine Forum, located here: https://www.coxengineforum.com/t5113-hobbico-s-cox-super-fuel which should give you more technical insight as to why synthetic oils alone should not be used with Cox engines.
Thanks in advance and have a great day!
Bernie
For Cox International
Hello Justin,
Bernie
My Mehanite iron piston steel sleeve Enya instructions state 20% all Castor oil, but those are at least 35 years old. My ABC Fuji instructions, 30 years old, state 25% all Castor oil for general (CL stunt I imagine) and 20% for other uses (RC, speed, free flight). My Mehanite iron piston steel sleeve OS Max .10 RC cross scavenge engine instructions of 40 years ago states 25% Castor oil. My OS FP ABN Schneurle manual of 20 years ago states 25% Castor for (FAI fuel) general use, 20% Castor with 10% nitro.Cribbs74 wrote:I guess it never really dawned on me, but even though this is a Cox brand (sort of) it only says 1/2A fuel on the bottle. 1/2A is a pretty broad spectrum and on some engines that mix may work just fine.
Overall for engine health, whether steel or ABC/ABN, I gather that 20% oil is a standard. Use of 50% Castor and 50% synthetic is reasonable. Older engines with softer metals, such as the Testors McCoy's should use 25% oil.
Granted we oft don't find ideal fuels. I'm still learning, but I'm adding Castor oil to the standard hobby store shelf blends for aircraft. Couldn't hurt and I have nothing to lose and all to gain.
Thanks Bernie, I missed your message while complying mine, then got side tracked in a discussion with someone else meanwhile.Cox International wrote:We sent the following email to airsupport@hobbico.com Hello Justin, As discussed on the phone with you, Hobbico product # COXP1005 Cox Super Power 1/2A Fuel, if indeed a mix of 90% synthetic and 10% castor oil, will almost certainly damage Cox engines if used in such. [...]
I'm glad that you are taking the lead in contact Hobbico. I hope they reformulate to standards or focus on another supplier for fuel. That basically leaves Sig Champion 25% fuel as meeting the requirement.
Here is our list of recommended vendors (from our on-line fuel guide). Ritch's Brew seems to be a favourite.
Hello Justin,
Bernie
Thank you Bernie. A very well written letter IMHO. Hobbico could easily re-brand the stock that they have out there; by contacting their distributors with a letter of explanation.. and instructions to temporarily remove stock from inventory, until a new "label package" is sent out. Hobbico could also offer some incentives to these distributors.. for this inconvenience. It's a small price to pay, to protect their modeling reputation. The fuel that's already out there is certainly useful.. but it's irresponsible for them to continue to use the "Cox Super Fuel" trademark packaging.. if their product prematurely destroys "Cox" engines.
Towerhobbies still selling cox super fuel. From their info, coxmodels.com supply them.
I think we should email to coxmodels.com about this?
tru168- Gold Member
tru168 wrote:Towerhobbies still selling cox super fuel. From their info, coxmodels.com supply them.
I believe they are a company of the Hobbico consortium. Since as far as I know, Hobbico bought O'Donnell Fuels, I think it may be a product from them.
coxmodels.com is a domain of Hobbico and was registered by them after they bought Estes/Cox.
It is pretty amazing how fuel sensitive these things are. The first Cox engine I had flown in decades was a Hyper Viper back when those first came out. It didn't even occur to me to use any special fuel, so I flew it on the Powermaster 15% that I was using in my ABC stunt motors. After three flights it became impossible to start and the plane got shelved
I now use that motor as a set up motor when I'm building a new plane because it is basically ruined. The crank wobbles, the rod has something like ten to fifteen thou worth of play and there is very little compression. I won't make that mistake again...
Mike
Mike
You probably already know this, but http://www.coxinternational.ca has parts for your engine to restore it.Mike Mulligan wrote:It is pretty amazing how fuel sensitive these things are. The first Cox engine I had flown in decades was a Hyper Viper back when those first came out. It didn't even occur to me to use any special fuel, so I flew it on the Powermaster 15% that I was using in my ABC stunt motors. After three flights it became impossible to start and the plane got shelved. I now use that motor as a set up motor when I'm building a new plane because it is basically ruined. The crank wobbles, the rod has around 25 thousandths play and there is very little compression. I won't make that mistake again... Mike
Since coxmodels.com is actually under Hobbico, they still keep selling the same fuel even knowing that low castor contain will harm our Cox engine. Really hope Hobbico will change their ingredients to proper one.
tru168- Gold Member
Sacrificial Engine(s) for Cox Super Fuel test
Some of the best info on Cox Super Fuel (CSF) I have found on the internet is in this thread.
Some of you here have related ACTUAL personal experience with low- or no-castor oil fuels destroying your engines.
Well, as a test of how appropriate CSF is, I just ordered up two new SureStart engines from eBay to perform an experiment .
I'll run Sig 25% Champion Fuel in one, CSF in the other. Both will be broken in per Cox's old guidelines - 3 tanks of fuel with the engines set rich.
No mention was made in the Cox guidelines about how big a tank - I'll use an ounce for each run.
Cheers-
Cheers-
PeterJGregory- Gold Member
Considering the instructions are the same for a baby bee, 5ml is a tank full, 60ml is a long run.
Larger Golden Bee / Black Widow tank is 8 cc. 1 oz. is 30 cc. That it 6 times the volume of the 5 cc Babe Bee tank. Depended upon prop, if run time is 2.5 minutes on 5 cc, that is 15 minutes on 30 cc. 48 flights would be eight 1 oz. tank fulls, about 2 hours. It would be interesting to see what tankful the engine would start to lose compression on the Cox fuel.
YMMV (Your mileage may vary)
I'll be interested to see your results Peter. More proof adds to our credibility on this issue, thanks for your sacrifice. If you can document it on video that will be even better.
» Cox Super Power Fuel
» New Uploads: 1982 and 1990 Cox Catalogs, and Hobbico-Cox Super Power Fuel Flyer
» Fuel line that stays on a td fuel niibble
Page 3 of 4
