» Norvel Needle Neededby F4D Phantom II Yesterday at 11:25 pm
by rsv1cox Yesterday at 6:07 pm
by MauricioB Yesterday at 8:05 am
by MauricioB Yesterday at 7:39 am
by 1/2A Nut Yesterday at 2:52 am
by DanMc Fri May 10, 2024 9:07 pm
by roddie Fri May 10, 2024 9:02 pm
by mike in SC Fri May 10, 2024 7:42 pm
by roddie Fri May 10, 2024 5:13 pm
by roddie Fri May 10, 2024 2:51 pm
» Fox .35 Modifications
by Onelife Fri May 10, 2024 2:07 pm
by cstatman Fri May 10, 2024 2:03 pm
Enya SS 25 "Super Sport"
I was given this engine as a "non runner" and so I put it on one side. I decided to run it up today and could only get it to splutter.
I took the plug out to check it and it glowed nice and bright but I dropped it and it went into the pond.
I fitted a new Enya plug and it started first flick - the way I like an engine.
Re: Enya SS 25 "Super Sport"
A very good engine Ian. I had a SS .30 which was pretty much identical and it was outright awesome. Enya made things a bit confusing because these were offered BB and bushed. The .25 also was offered in a AAC version which from what I've read is a impeccable engine.
A thing of beauty Ian. The SS engines command top dollar at swap meets so I always pick them up, admire and then put them back down. Glad it works well for you. Glow plugs are funny little devils.
That's a stout looking engine ,How did the run go other than the plug dropping ?
As far as I could tell - not knowing the true history - this negine had not been started before and it is certainly not run in.
So I ran it rich (for a couple of minutes) and didn't open it up. I need to check it over to see if it is AAC or standard build before I run it in.
It is not ball bearing but sadly - it doesn't have that diesel bark!
I also used a 10 x 4 propeller which is probably a bit too much for this motor.
The AAC version has a red prop washer.
» Super sport 049
» Cox Super Sport II
» COX Super Sport Trainer
» In Search of a Super Sport II
» Almost "NEW" Enya .29-III Super Typhoon purchase (last week)
